Old 05-13-2016, 03:22 PM   #1
Stream Weaver
romakdaddy's Avatar
1989 37' Airstream 370
pamplico , South Carolina
Send a message via Skype™ to romakdaddy
Water leaks....Water leaks everywhere...
so its been a while since I posted and for that fact its been a while since I even did anything to the "B-37 Wallet Bomber" AKA 89 370. I had it towed to my new shop a month ago so it would be closer to me to work on since by the time I got home in the summer it was too hot and in the winter it was dark. I finally got the carb sorted and the ignition situated(a GM/Ford hybrid dizzy did the trick) and I decided to hook water to it and see if all the sinks and whatnot worked.......holy crap! its been probably the better part of 8 years since the lines saw pressure and let me tell ya...they protested...lol first there was a gusher under the stove all it was was a hose had popped off, fixed that and pressure test #2 revealed the ice maker line was spraying everywhere. I removed the stove and ice maker to find the line going to the ice maker was fitted with a 1/4 inch copper pipe and it was never drained at last use so it split in 4 places. I replaced it with 1/4 inch plastic tubing with proper compression and push in connectors and went for pressure test #3...nope! heard a gusher in the shower area and turned out in the closet behind the shower where the lines hook up had decided that both 90degree elbows didn't need to be one piece any more. I spent all day and 3 trips to lowes sorting that out and making it better than before and went for test #4....aaaaaaaand its leaking in the bathroom behind the cabinet...I give up for the day but stay tuned same stream time, same stream channel...lol rant over.
romakdaddy is offline   Reply With Quote
Old 05-13-2016, 05:36 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Good luck with the rest of the tubing!
And the hot water heater.
Superat stultitia.
Old 05-13-2016, 07:19 PM   #3
Retired.
. , At Large
We call that "chasing leaks".
Old 05-13-2016, 08:04 PM   #4
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I hate to tell you this but I had the same problem. Those plastic fittings get brittle and fail. I fixed 3 or 4 and every time i fixed one another failed. Eventually I just gave up and replaced the entire system with pex. Maybe $300 for parts and $150 for specialty tools. The problem becomes gaining access to all the pipe. Airstream did not give much consideration to servicing the plumbing system.
Gregsch is offline   Reply With Quote
Old 05-13-2016, 09:22 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I am going to kinda agree on the total PEX refit.
It wasn't that bad of a job on my 75 Sovereign. A couple of days at worst, and no more problems.
Superat stultitia.
Old 05-14-2016, 06:00 AM   #6
Stream Weaver
romakdaddy's Avatar
thing is...its already 3/8 pex throughout so hopefully it will just be fittings and elbows. im using the latest advanced technology to replace the flimsy fittings ie: brass instead of plastic and gator grip push fittings.
Old 05-14-2016, 06:22 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Are you sure it is pex and not the old grey poly-bute?
They are not same, not even close.....
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 05-14-2016, 07:15 AM   #8
1972 27' Overlander
Denver , North Carolina
Pex is the word...
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 05-14-2016, 07:16 AM   #9
1981 31' Excella II
New Market , Alabama
Make sure your pressure regulator is working. Put a gage on it.
Perry
Old 05-14-2016, 07:37 AM   #10
Weldon Spring , Missouri
Lowe's motto is: "never stop improving"
it should be: "you'll be back here in an hour"
fmr.capt.evi is offline   Reply With Quote
Old 05-14-2016, 09:48 AM   #11
Stream Weaver
romakdaddy's Avatar
Regards,
JD
its grey so you are most likely correct...its the same size as pex and flexible but I guess its cheaper and weaker than pex. I bought some pex sticks to patch the leaks so far. if I have to expose a bunch of it I may just replace the whole works with the real deal.
Old 05-14-2016, 09:50 AM   #12
Stream Weaver
romakdaddy's Avatar
heres what was hiding under the oven/stove....water heater.
Old 05-14-2016, 09:52 AM   #13
Stream Weaver
romakdaddy's Avatar
and my ice maker replumb...
Old 05-14-2016, 09:53 AM   #14
Stream Weaver
romakdaddy's Avatar
Perry
any idea where that would be located? didn't even know it had one...I know, I'm a noob...lol
Old 05-14-2016, 10:27 AM   #15
Olroy
1976 29' Ambassador
1986 34.5' Airstream 345
Barbourville , Kentucky
PEX works great 100% 1 day with stuff bought at Lowes.
Superat stultitia.
. Don't know how to post???
Olroy is offline   Reply With Quote
Old 05-14-2016, 10:35 AM   #16
Olroy
1976 29' Ambassador
Just found where to post. Trying to say worked 1 day and changed out my Castle 76 Ambasitor. PEX all the way. All parts were avail at LOWES. Buy a good clamper and use crimped fittings. Lot easier then it sounds. If you can't get to a place with crimper use slip on connectors but they are $. Olroy
Old 05-14-2016, 10:38 AM   #17
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I'm told by the ultimate fixer-upper (hubby) that he's allowed 3 trips to the hardware store for every project. Most of the time now, we get away with only 1 or 2 trips since he's accumulated so many tools over the years. Since what's good for the gander, is also good for the goose, I also use that motto for my quilting projects....
We absolutely had to re-plumb Little Girl, so went with Pex and haven't had any issues in 5 years.
Kay
Old 05-19-2016, 12:57 PM   #18
Stream Weaver
romakdaddy's Avatar
Found the regulator, it was under the bed with about 40% of the rest of the plumbing...lol. I decided I'm going to replace....everything and use color coded pex. Thing is most of what I saw at lowes was 1/2 pipe and my system is 3/8 but since I'm replacing the entire system it really shouldn't matter...any concerns about upping the piping size to 1/2 I should be aware of?
Former owner of the famous AirStream B-370 Wallet Bomber
Old 05-19-2016, 01:05 PM   #19
2007 22' International CCD
Adds a bit more of weight when it is full of water. Parts a bit more expensive. Most modern AS are plumbed with 3/8 PEX.
Pick a size and stick with it throughout.
Color coded pipe is very convenient....
Old 05-19-2016, 01:55 PM   #20
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Many more sources for 1/2" Pex on the road, should you need new connectors.
Dennis
dennis3751 is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
New/vintage purchase, '71 safari 23' leaks everywhere! Help!! andreak General Repair Forum 3 06-14-2013 09:30 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
