Old 05-14-2016, 10:27 AM   #15
Olroy
1976 29' Ambassador
1986 34.5' Airstream 345
Barbourville , Kentucky
PEX works great 100% 1 day with stuff bought at Lowes.
Originally Posted by J. Morgan View Post
I am going to kinda agree on the total PEX refit.
It wasn't that bad of a job on my 75 Sovereign. A couple of days at worst, and no more problems.
Superat stultitia.
. Don't know how to post???
Olroy is offline   Reply With Quote
Old 05-14-2016, 10:35 AM   #16
Olroy
1976 29' Ambassador
Just found where to post. Trying to say worked 1 day and changed out my Castle 76 Ambasitor. PEX all the way. All parts were avail at LOWES. Buy a good clamper and use crimped fittings. Lot easier then it sounds. If you can't get to a place with crimper use slip on connectors but they are $. Olroy
Old 05-14-2016, 10:38 AM   #17
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I'm told by the ultimate fixer-upper (hubby) that he's allowed 3 trips to the hardware store for every project. Most of the time now, we get away with only 1 or 2 trips since he's accumulated so many tools over the years. Since what's good for the gander, is also good for the goose, I also use that motto for my quilting projects....
We absolutely had to re-plumb Little Girl, so went with Pex and haven't had any issues in 5 years.
Kay
Old 05-19-2016, 12:57 PM   #18
Stream Weaver
romakdaddy's Avatar
1989 37' Airstream 370
pamplico , South Carolina
Send a message via Skype™ to romakdaddy
Found the regulator, it was under the bed with about 40% of the rest of the plumbing...lol. I decided I'm going to replace....everything and use color coded pex. Thing is most of what I saw at lowes was 1/2 pipe and my system is 3/8 but since I'm replacing the entire system it really shouldn't matter...any concerns about upping the piping size to 1/2 I should be aware of?
AirStream B-370 Wallet Bomber
romakdaddy is offline   Reply With Quote
Old 05-19-2016, 01:05 PM   #19
2007 22' International CCD
Adds a bit more of weight when it is full of water. Parts a bit more expensive. Most modern AS are plumbed with 3/8 PEX.
Pick a size and stick with it throughout.
Color coded pipe is very convenient....
KE4GNK/AE
Old 05-19-2016, 01:55 PM   #20
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Many more sources for 1/2" Pex on the road, should you need new connectors.
Dennis
dennis3751 is offline   Reply With Quote
Old 05-19-2016, 02:01 PM   #21
Stream Weaver
romakdaddy's Avatar
Dennis
yeah, lowes had a ton of 1/2 stuff but the 3/8 stuff was very limited. I'm thinking of going with the metal fittings hopefully they aren't as prone to bust in a freezing situation.
Old 05-19-2016, 02:26 PM   #22
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Well, I'm glad you're replacing it with PEX. What I saw in post #12 looked very much like the Polybutylene piping that was in my house in San Diego. Which all had to be replaced, courtesy of the manufacturer (I think it was Shell oil). The PB was fine, but there was some kind of chemical reaction where it was fitted/joined. Which eventually resulted in teensy tiny little sprays of water, then bigger sprays of water.... The crimp fittings used with PEX and the PEX itself are the only way to go. I wish my house was plumbed with it rather than copper. I think all new construction uses PEX, and having plumbed hundreds of feet of it myself, it is really foolproof. As long as you crimp it properly. Which you will do if you use the "check-up" gauge for the size of tubing you're installing. The other advantage is "red" for hot water and "blue" for cold. Never a mistake when you're joining lines or adding a line for an ice maker, humidifier, etc.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-20-2016, 12:06 PM   #23
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The only disadvantage with running 1/2" instead of 3/8" is a little longer wait time for hot water to reach a faucet or shower head.
I plumbed with 1/2", to me the little water lost is made up for in better flow when water pressure is low.
Superat stultitia.
Old 05-21-2016, 07:43 AM   #24
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Go for it! You won't regret it. Take before and after pics. Some spots will be so tight that you can only get everything in one way. l had a couple places that I had to redo because I put the wrong pipe in first. Test fit assemblies of several fittings and pipes under cabinets or behind walls, them take them out in the open space where you can get the crimper on them then crimp the assembly together. You don't have to crimp them exactly the way they go. You can twist the fitting a little bit after they are crimped.The sharkbites are expensive but they work good. Don't hesitate to use them to put you subassemblies together in areas where you can't use the crimper. They make life a lot easier.
Gregsch is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
New/vintage purchase, '71 safari 23' leaks everywhere! Help!! andreak General Repair Forum 3 06-14-2013 09:30 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
