Old 08-17-2019, 01:54 PM   #1
Kansas City , Missouri
Water leak
This is an odd one; in our 1995 Classic 36’ diesel pusher, the water pump will cycle on about every 7 minutes...and somehow the water seems to be going into the black tank? I even shut the water off to the stool, thinking that I’d isolate the leak, but not so? Any ideas where to look? Even if it’s leaking into the gray tank...how would it get there and where do I look? Thank you very much!
Danny ONeill is offline   Reply With Quote
Old 08-17-2019, 02:38 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
How long is it "on" when it cycles? It must be dumping a good deal of water into the tank for it to be detectable. There is only one way that I know of to put water, or anything else, into the black tank and that's the toilet flushing. Unless it's from the outside dump valve I suppose. When you put water in the toilet bowl does it stay or leak past the slider into the tank? It's possible for the toilet valve to leak into the bowl I guess, but you said you tried turning that off.......that's a good mystery you have going there.
Now if you're not absolutely sure where the water is going when it cycles then that's a different story. That could be the check valve in your water pump has gone bad and dropping your water pressure in your pipes.
mayco is offline   Reply With Quote
Old 08-17-2019, 04:48 PM   #3
It cycles about every 7 minutes and 45 seconds...within 5 seconds. Super consistent. I drained both tanks today so will run another little experiment overnight; shouldn’t be a drop in black tank tomorrow.
Check valve sounds super logical...I’ll look at it, too.
I very much appreciate your help, thank you. I have a new conundrum that I’ll post here as well.
Old 08-17-2019, 04:55 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If there's no visible leakage, chances are the check valve in the pump has a little murmur, and the water isn't going anywhere except a tiny slow backwash to the freshwater tank.
Old 08-17-2019, 05:27 PM   #5
. Thank you very much.
Old 08-19-2019, 07:42 AM   #6
Ran it for 10 hours, no leaking...so to the check valve I go. Super appreciate the help guys!
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
