Old 09-22-2015, 07:44 AM   #21
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
That's odd..... I lost my whole post! I'll try again.
That's cheered me up, Streamquest, thanks. I am grateful it is no worse than I have found so far.
Peter.... I am indeed planning on the extra drain holes, since I believe that all RVs leak in multiple places and no one ever thought to build a bilge into one, that I know of. I am patching with heavy rubber stall matting, held down by very adhesive butyl caulk, but shall leave a gap and a series of dimpled drainholes down the edge, including on the main level since my leak had seeped all the way to the outside door.
How did you make your tunnel in the wall?
1989 345LE
Punch is offline   Reply With Quote
Old 09-22-2015, 11:00 AM   #22
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Funnel in the area where I knew of issues connected to plastic tubing out the floor
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 09-22-2015, 09:44 PM   #23
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
When talking drains….. More is always better.
To add additional window track drains, I used a portion of what I recall to be a small brass compression fitting. It's like a short section of brass tube with a widened funnel shaped end. I drilled a slightly chamfered hole in the track, and epoxied the fitting into place. The portion of it that passed downward through the track was perfect for attaching a length of rubber tubing to drain water out through the floor. Sorry… I wasn't taking pics at the time.
streamquest is offline   Reply With Quote
Old 09-22-2015, 10:21 PM   #24
Rivet Loser
Punch's Avatar
I like that suggestion. I guess you can use a flaring tool and brake pipe or similar tubing.
1989 345LE
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
