Old 12-19-2014, 09:48 PM   #1
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Water in passenger footwell area?
As some of you may have heard, we have been having some much needed rain out here in California. As a result, we are also finding all the leaks in our rigs...
I put new caulking around the windshield in a break in the weather, and this is working really well. I also hit the mirrors.
All good except there is still water soaking into the nice mush of fiberboard and carpet in the passenger footwell area?!!
Any ideas on where this leak could be from?
SebasSF is offline   Reply With Quote
Old 12-20-2014, 12:38 AM   #2
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Is the sliding window track overflowing?
streamquest is offline   Reply With Quote
Old 12-20-2014, 03:48 AM   #3
ottawa (greely) , Ontario
I'm not familiar with your rig but being a auto tech for 34 years a lot of people forget that the a.c. System if the drain line gets plugged can overfill the evaporator case and leaves the floor area around the passengers feet very wet and sometimes the drivers floor depends on vehicle design. The drain line gets plugged when leaves enter the heating ,cooling system from most vehicle hood area near wipers then they brake into small pieces once they hit the evaporator coil and then fall down in the case to the drain area and then plug the drain ,once the a.c has been running for awhile and remouve moisture from the air and then drips into the evaporator case but can't drain do to the blockage the tray overflows in the floor of the vehicle.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 12-20-2014, 04:24 AM   #4
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
As Steamquest said, check your track drainage and you may have to take your interior side panels off to see if Airstream installed drainage tubes in your model. They may be clogged. It all has to do with the overall poor design of the windows and the use of the terrible track material, that rusts and clogs drains.
I even installed drainage tubes on my 79 model, years before Airstream added them, since I was not able to stop the leaking.
If your channel material is the metal kind, you may want to consider changing to this rubber/felt material:
AS1268 Flexible Flocked Lining All-Rubber | Hi-Tech Glazing Supplies
It allows you to cut precision drainage holes, confirms tightly around curves if you slice it on the back every 1/4" at the curves and best of all its cheap and does not rust.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-20-2014, 02:07 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
All of the above ideas are great plus one more....Check your clearance lamps. I removed two and found misplaced drill holes that hadn't been sealed up properly.
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-24-2014, 11:42 PM   #6
1982 28' Airstream 280
Redwood City , California
Hi SebasSF,
As others have said your leak could be from any or all of the sources mentioned. I had the same issue with the passenger floor in the cab. Fixing the damage isn't as bad as it may seem, but finding the actual water leak is a nightmare.
The water that damaged my floor was coming from the top of the windshield area and dripping down the center windshield post. The dash area next to the windshield would fill with water and then leak down the right side and onto the floor.
Issue is that to this day I really don't know where the water is actually getting into the interior. I try to seal the windshield gasket and the windshield still leaks. Once I stop the water from running off the front of the awning rail and down the side of the MH, then my windshield no longer leaks. I'm assuming the water is getting in at the front cap seam or at the top of the front passenger side window.
In fixing the floor, I cut out the worst section of the plywood and patched it. Some of the remaining plywood was only rotten on the first layer or two. I dug out the rot and repaired it some wood filler. I didn't worry about making it look pretty since it would be covered with carpet.
During one of the many, many times I was "under" the dash, I also hose clamped all the A/C evaporator drain lines as scamp has mentioned.
ID:	229193   Click image for larger version
ID:	229195   Click image for larger version
ID:	229197   Click image for larger version
ID:	229199   Click image for larger version
ID:	229201   Click image for larger version
dadstoy is offline   Reply With Quote
Old 12-24-2014, 11:53 PM   #7
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
As Isuzusweet said, I found that the clearance light sealing had dried out and shrank and cracked. One of my parts/repair people confirmed this, said his FIL had the same model as me, and I resealed before the big rains and it is still dry! The front cap to roof is usually visible when you are on tip, but these lights are more challenge to inspect and repair.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
110 volt outlet in passenger area Airstream12557 Land Yacht/Legacy Motorhomes 11 01-17-2013 08:54 AM
what is this passenger front side glass worth? RichardT Airstream Motorhome Forums 7 04-08-2009 10:19 PM
345 motorhome passenger and driver vinyl seals raveson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-11-2006 04:28 PM
Driver/passenger legroom/Argosy MH? pepepepe Airstream Motorhome Forums 4 01-01-2003 06:24 PM
