Old 06-07-2012, 06:13 PM   #1
Brighton , sussex
Water heater/ heater matrix repair
Last one I promise.......As I have joined the heater take off togerth can i still use the Atwood water heater? There are two pipes teed off the dashboard heater pipes which run all the way back to the Atwood water heater. This is the motor assist option. When I fill the fresh water tank and use the heater is the a danger of the water coming out of the disconnected ends in the engine bay? Will I loose all of the water in the water heater? I mean can I actually use it in this state? I plan to oul the heater core out and get a new one made.
D
Loving Life, Chicks, Cars and Mummas Grits baby
montreal is offline   Reply With Quote
Old 06-07-2012, 07:20 PM   #2
1974 Argosy 20
Kooskia , Idaho
You can use the heater without any problems. The engine assist is a coil of pipe around the tank in the heater, on the outside. It is in no way connected to the water inside. This is a code and safety issue. You would never want the engine coolant to mix with the domestic water.
You can leave it disconnected and even buy a replacement water heater without the feature if you would like. Those water heaters with the engine assist are more expensive and a whole less available than the normal ones. I do like the extra coach cabin heater under the seat, which operates from the same lines as the water heater. BTW, that heater will eventually need to be re-cored. When I had mine done it was a stock variety that my radiator repair shop found in a catalog, but I have no idea if it is still available and if you could locate one in England.
(ex '83, 310 owner)
Old 06-08-2012, 06:00 AM   #3
If you have to get into the Aux heater, read this... been there done that!
http://www.airforums.com/forums/f311...ter-72696.html
