Old 07-31-2007, 02:24 PM   #1
1991 35' Airstream 350
Windsor , North Carolina
Water filters in Classics
The Zeppelin (1991 350) has what appears to be a fitting for a water filter under the galley sink, but has no filter in it. It is metal, blue, round, fluted, and screws on and off. It is in the main water supply line to the sink faucet, not the heater for coffee-tea. (No photo before the weekend!)
Does anyone:
1. Have a similar fitting?
2. Know what filter is was made for (if any)?
3. Know a source for the filters?
Lousy water in the campground last week!!
Best,
R
ralley is offline   Reply With Quote
Old 07-31-2007, 02:32 PM   #2
Lee Pace's Avatar
We have one in our trailer. You can buy refills at camping World.
Gloria Pace
72 Sovereign
WBCCI 7287
Greenville, Tx
Lee Pace is offline   Reply With Quote
Old 07-31-2007, 03:01 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I replaced the one in my Excella with a GE from Home Depot. Not only is it better looking, replacements are easy.
Vaughan
Old 07-31-2007, 03:31 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I use a double filter on my CCD. The first being a particulate filter that is white and liike like spun fiberglass (it isn't though) and the main filter is solid block carbon (SBC).
If you're running just one filter, I would go with the SBC and add an in'line screen to the end of your hose fitting. It should work well, and you should notice a definite improvement in the taste and quality of your water.
I like my filtered water better than the bottled stuff you buy in the grocery, which uses a very similar process and is labeled 'spring water'.
Old 08-05-2007, 06:43 AM   #5
Thanks, all. I can see I will need to make a trip or two to sculp out what's available--because it ain't '91 any more!
Best,
R
Old 08-10-2007, 12:03 PM   #6
Chuckles's Avatar
Iwerne Minster , Dorset. UK
I have just removed the standard AS issue filter with General Ecology's Nature Pure.
Very neat - small, take up less space, comes complete with fittings and faucet.
It is much simpler to change and the water tastes good!
Chuck
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
