Old 04-24-2012, 12:23 PM   #1
1995 36' Classic 36
Ludington , Michigan
Waste Water Level Sensors
My black water sensor has been stuck on 3/4 since I bought it a year ago. Is there any way to get at it without pulling the tank. Any access ports? Any tricks on getting them to work without pulling the sensor?
Thanks, Dave...
Kota is offline   Reply With Quote
Old 04-24-2012, 12:40 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I can see my sensors on the respective pipes that drain each tank and connect to the common sewer outlet. Check back there. Mine could easily unscrew and be replaced if necessary. Keep us posted.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-26-2012, 10:03 AM   #3
I hear that is common in these types of sensors... try flushing the tank, and maybe using a pressure wand?
Old 04-26-2012, 11:42 AM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
On my black water holding tank from under the coach the first two or three sensor are visible. You can check and clean them to make sure they have a good contact with wire connection. They also sell a gauge cleaner you can add into the tank to clean the senors. These senors seem to be one of those little on going problems that never get completely resolved.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 05-06-2012, 04:58 AM   #5
1995 36' Classic 36
I found a work a round. I drove a nail in the wall of the bathroom that we hang a wooden yardstick on.
Just kidding! My tanks have a metal box over them with insulation inside. No pipes, wires, fittings... Visible
Cleaning has not helped. It's hell not knowing when yer full of crap!
Old 05-06-2012, 12:21 PM   #6
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Full-timer RV'r friend of mine told me this 'hint' on cleaning the black tank. Before heading to campground, take a 5lb bag of ice, dump it down the toilet, let the ice move around in the tank while driving to campsite. Once there, go ahead and dump black tank. Sounds plausible to me.
Thanks, Derek
Old 05-07-2012, 07:58 AM   #7
Ice in Black Tank
Ice in the black tank sounds like a great idea! Way back when I waited tables in a restaurant, we would use ice and salt in the coffee pots after someone would leave it on the burner too long. We would swirl the mixture around for a couple minutes and voila!, the pot was amazingly clean!
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 05-11-2012, 03:07 PM   #8
1995 36' Classic 36
20 gallons of water with level sensor cleaner for 2 warm days then a big bag of ice for a 70 mile drive. No joy!
Old 05-11-2012, 09:04 PM   #9
crazeevw's Avatar
Wondering, did you drain the black tank before adding the ice?
Old 05-12-2012, 01:21 PM   #10
Silverton , Colorado
Yep, ice will help. but if the sensor is shot...well...sometimes a senser of humor helps...water in, water out...if it doesn't flush, don't hit the brakes hard until it does...I carry a crap stick for the eventual plugs that occur, and I can throw it away as time and encrustation dictates...this is a sticky subject for some, but it won't go away without attention.m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-12-2012, 01:24 PM   #11
Have you tried a spray wand?
Good info here...
How to Clean an RV Black Water Tank | eHow.com
Old 05-12-2012, 01:48 PM   #12
Been there, worn that, but I prefer a Hawaian shirt...
Michael & Tracy
1989 345 Motorhome
Old 05-13-2012, 09:53 AM   #13
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
My black water sensors show full all the time, also. I've tried every trick listed above to no avail. I am going to try the ice/sensor cleaner one more time when we move the coach. Oh please, don't make me take the tank out.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-13-2012, 11:08 AM   #14
I replaced the black water-gray water connections...not a pleasant thing to do...hauling a 5 gallon bucket 4 times to the toilet was an exercise in careful carrying, and a fairly disgusting process...i used two tubes of plastic to seal the gap...well...1/2 inch I didn't include in my calculations... ya know, cut it twice and it was still too short...? So far, it has sufficed, but the next time this issue has to be addressed, I'm paying the bucks...sensor...not a problem for me...I'm done with doing black water situations...I will simply monitor intake and output, err on the side of conservative, and NEVER try to fix it myself, again.
Michael & Tracy
1989 345 Motorhome
