Old 09-20-2007, 06:47 PM   #1
Waste dump hose storage location
Just curious as to whether the little door on our 310 moho thats labeled "Sewer Hose" is a factory installation or some PO add-on. I've not used it yet mainly because I'm not thrilled with trying to push a wet slinky through the electrical/water storage compartment.
The first picture shows the door to the hose compartment.
The second picture shows the underneath view. The tube is about 2' long and reaches to the rear of the wheel well.
I'm still trying to figure out the best location to store the hose. I'll probably rig up something underneath.
bkahler is online now   Reply With Quote
Old 09-20-2007, 08:30 PM   #2
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
I have a compartment on my 345 just like that. I cannot put my dump hose in it. The fitting that is on the end has a hose clamp on it and it will not fit back in there.
jagcb750 is offline   Reply With Quote
Old 09-21-2007, 05:54 AM   #3
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
BKAHLER, that is a factory idea. You can take out the tube and put in a length of flexible dryer vent, bent around to give you enough length for your sewer hose. OR, you could mpount a separate tube crosswise under the rear of the coach, which is lots more sanitary and less shocking. Drill drain holes in the lower side.
Jamie
jking is offline   Reply With Quote
Old 09-21-2007, 02:45 PM   #4
Chuckles's Avatar
Iwerne Minster , Dorset. UK
I found that the small tube will only take about 5 feet of hose compressed, so I fitted a length of plastic underground sewer pipe between the fuel tank and the air bags. It just about fits with approximately 2-3 inches spare between the tank and the air bags.
It is "hinged at one end with a threaded rod through the end of the tube to act as a stop and a fixed but hinged end. The other end just pops on a small vertical rod riveted to a stainless strap on the side skirt. It works very well. The full length hose is outside, the air gets around and through it and it is secure.Click image for larger version
The photos tell all, I hope.
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 09-21-2007, 02:47 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Expanding on Chuckles' post, a piece of PVC pipe with screw on plugs on either end strung under your moho in the place shown above, would be another idea.
Old 09-21-2007, 04:46 PM   #6
Chuckles's Avatar
I was going that way at first but thought it would better if the hose had a good circulation of air and of course it drains well.
When I first bought the 310 the hoses were kept in the rear R/S Compartment! that caused a lot of problems with water, smell and the loss of useful storage, as well as the start of rusting.
Chuck
Dorset UK
Old 09-21-2007, 05:09 PM   #7
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Our Classic trailer has a PVC tube mounted east-west about midway from the hitch to the front wheels that we use for the sewer hose - someone told us once that was for flag poles...(???). Drill drain holes in it which would also serve as ventilation. Twist-end caps to close it up. Works peachy-keen.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 09-28-2007, 06:38 PM   #8
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
on a 345
It is also in the elec compartment but the door is next to the water reel and runs along the back bumper. Works great
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
waste valve 1963tradewin 1959-69 Tradewind 8 05-23-2008 07:27 AM
Sewer Hose Storage Options 66Overlander Waste Systems, Tanks & Totes 2 07-21-2007 08:30 AM
What to do about waste rmacdaddy Waste Systems, Tanks & Totes 4 02-21-2007 07:13 AM
PVC Hose Storage Carrier temcotom Waste Systems, Tanks & Totes 23 07-18-2004 09:14 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 08:25 PM
