Old 11-12-2007, 04:30 PM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I keep a small space heater in my trailer and it holds the temp in the mid to high 40s. This is certainly enough to keep things from freezing on the few days we get where it drops down that cold. All my lines and tanks are above the floor, and I do drain the water. Mostly I like that it keeps it from getting damp inside, so we don't get that musty smell in the spring. The electricity usage is minimal. We didn't even notice a jump in our bill compared to the years when we didn't do it.
Stephanie
Old 11-13-2007, 09:24 PM   #16
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
STEFROBRTS: What state are you in ? Is your stored indoors or out doors?
myfirstrv is offline   Reply With Quote
Old 11-17-2007, 06:26 PM   #17
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Brad - we drain tanks (all 3) and blow out the water lines with 45-50 psi air on our 310. That and a little pink stuff in the drain traps is the total winterizing necessary unless you expect >4-5 days of temps <30. The use of small 'cube' electric heaters when doing work is adequate, and they can be left on for a week or so during your flooring project. Propane heat generates moisture - not good.
jking is offline   Reply With Quote
What about de-winterizing cosmotini Our Community 14 12-29-2008 06:04 PM
De-winterizing snpotratz Fresh Water Systems 7 03-19-2007 12:48 PM
Winterizing jacobjames Member Introductions 1 10-13-2006 03:32 PM
Winterizing JulianneJ Winterizing, Storage, Carports & Covers 25 11-22-2005 06:15 PM
Winterizing in N. FL ? Soarhead Winterizing, Storage, Carports & Covers 5 11-26-2004 07:29 AM
