Old 09-24-2013, 06:41 PM   #15
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by nm1oqrz View Post
Hello fellow Streamers. I also have a U.S. Gear overdrive and it still works fine. It would be nice is whoever has a wiring schematic to post it on the forum for those who dont have it. I know I don't have it. I know that U.S. Gear was the last manufacturer after they took over manufacturing the units from Doug Nash Engineering.
I always keep my unit in the od position as that is where i get the best performance and I disconnect the electrical connector under the hood when Intake the truck in for service, just in case someone get curious as to what the shifter switch does.
One thing I di remember is that you should be under 35MPH to shift and before you press the button to shift, take your foot off the gas, press button, wait for the clung that tells you it shifted and then you can procede as usual.
A wiring schematic sure would be handy!
Happy camping nm1oqrz
I have some files, PM me, because the wiring was different on different brand rigs.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Need wiring diagram...... jedimaster Batteries, Univolts, Converters & Inverters 2 05-11-2010 03:43 PM
Wiring Diagram...HELP!! rlindberg Electrical - Systems, Generators, Batteries & Solar 6 06-22-2009 01:53 PM
GEAR VENDORS overdrive, same as units IPM Mechanics Corner - Engines, Transmission & More... 12 07-02-2004 09:13 PM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
