Old 06-06-2013, 06:41 PM   #1
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Upper rear Awning mount repair
Last Thursday evening we had a HUGE thunderstorm blast through at Alumapalooza. Our patio awning was out and we wound up hanging on it to keep it from blowing away. I thought we had escaped damage, but after we got home I found that the upper rear mount had been pulled loose from the fuselage. I also realized that it was only held on with 4 sheet metal screws into the outer skin.
Here is how I repaired/strengthened the mount.
First I made a few measurements and found that access to the inside of the mount area would be inside the upper closet in the bedroom. (Out of site)
I took an awl and made s few dimples from the outside through the screw holes. This located the area exactly inside.
Next, I used a roto-zip tool to cut out a small access hole through the inner skin.
I used 1/8"x 1 1/2" aluminum to make a doubler 4 3/4" long.
I used aircraft bolts and fiber lock nuts to secure the mount back to the fuselage, going through the new doubler. I used the Airstream sealant between the doubler and the awning mount.
The last step was to make a small 3"x 4 1/2" patch to close off the new access hole.
That should last the rest of my life!!!
Name:	Awning mount5.jpg
ID:	187604   Click image for larger version
Name:	Awning mount4.jpg
Name:	Awning mount6.jpg
ID:	187606   Click image for larger version
Name:	Awning mount3.jpg
Name:	Awning mount2.jpg
ID:	187608   Click image for larger version
Name:	Awning mount1.jpg
Robfike is offline   Reply With Quote
Old 06-06-2013, 07:39 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Nice work on the repair!
Skatiero is offline   Reply With Quote
Old 06-06-2013, 09:08 PM   #3
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
That was some freak storm, eh?
Steve
t7389sg is offline   Reply With Quote
Old 06-09-2013, 07:30 AM   #4
Robfike's Avatar
Speedway , Indiana
That was the fastest moving storm I have ever seen!!!
