Old 08-27-2015, 01:04 AM   #1
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
upgrade alternator
Hello. I would like an alternator more powerful on my Excella. But without any other modification ( wires / univolt / batteries separator/...) . Please, what power max would you advise me to buy ( and brand, type). Thank you. Marc
bigbidule is offline   Reply With Quote
Old 08-27-2015, 02:53 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Without modifying wiring or mounting brackets, you will need to stick with the Delcotron type. How many amps is your current one?
Old 08-27-2015, 05:53 AM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
1984-81 GM 7.4L(454) - MG Industries Inc.
I don't know much about their alternators, just been using their excellent, trouble free starters
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-27-2015, 06:44 AM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Rock Auto is your best bet on a Factory new alternator (Delco) brand new about $80.00....Keep your original as a spare. You may also want to replace all battery cables as age becomes an issue with voltage drop problems. The second phase of my overhaul includes replacing all chassis 12 volt wiring pertaining to alternator,isolater,starter.
bobmiller1 is offline   Reply With Quote
Old 08-28-2015, 08:00 AM   #5
bigbidule's Avatar
Ok. I don't know amperage but I have a problem of priming (? , initiating ? I don't know the right word ). I have to run the motor about 3000 rm to start alternator and get between 12.5 - 13V...perhaps the regulator ?
Alternator Mean Green seems very powerful ( gain 300% !!! )...
Rock Auto is cheaper.
Sure, I have to change all big wires which are cracked.
Old 10-04-2015, 01:16 AM   #6
bigbidule's Avatar
ok, my alt is 63 Amp. can I change it with a 100 Amp. without problem (isolator ? )
Old 10-04-2015, 01:33 AM   #7
1979 23' Safari
Wayland , New York
Yes, the rating tells you max amps it can put out, if doesn't always put that many amps out. The voltage regulator will regulate how many amps it will actually put out. Over rated is ok as long as it physically fits in the space available.
Old 10-04-2015, 08:11 AM   #8
You also need to verify the wire gauge size from the alternator to the isolator. It needs to be considerably heavier for a 100 amp alternator compared to a 63 amp unit.
Odds are your motorhome is already properly equipped as I think the motorhomes came with higher output alternators than stock. When it comes time to replace the original alternator it's usually an emergency and most people end up going to their local parts store and buying whatever alternator they can get their hands on which is usually a lower output unit.
Old 10-06-2015, 05:21 AM   #9
bigbidule's Avatar
bkahler, I think you'r right and alternator of excella is more powerful than 63A.... I am just ordering a 140A (!!!) to Summit Racing (120 us$ / 220usd with shipping and taxes). I will change the wire from alt to isolator and....wait and see .
Old 10-06-2015, 10:31 PM   #10
bigbidule's Avatar
And I change also my isolator with that for 45 $ : Victron Cyrix battery combiner (12/24v-120A) : better than a diode system !
Do I need to upgrade the alternator Bex Batteries, Univolts, Converters & Inverters 7 05-20-2014 06:45 AM
Alternator upgrade Surprise Classic Motorhomes 12 04-26-2013 04:11 PM
Alternator type on a '76 - upgrade? MrJ Argosy Motorhomes 5 11-26-2011 11:23 PM
454 LY Alternator & Isolator upgrade?? ddgall Mechanics Corner - Engines, Transmission & More... 1 01-24-2011 04:51 AM
Alternator/ Voltage reg LKappenman Mechanics Corner - Engines, Transmission & More... 7 10-24-2002 10:24 AM
