Old 01-07-2019, 06:14 PM   #1
1989 34.5' Airstream 345
Sumner , Washington
Turning over & running engine while plugged in
I have a few Newbie questions related to my 1989 340LE; this is one of them.
Is it safe to start the motorhome (ie turn on and run the engine, in park) while plugged in to 120V AC?
So for instance I have an extension cord to the Airstream to power the fridge, lights, etc but wish to turn on the engine every once in a while to maintain over the winter but is it better to unplug when doing this? or is it perfectly fine to keep plugged in when starting and turning off the engine.
Any insight would be very much appreciated, thanks in advance!
ArStrm345LE is offline   Reply With Quote
Old 01-07-2019, 09:04 PM   #2
Churubusco , Indiana
Perfectly fine plugged in! You have 12v power from the batteries all the time anyway, running the engine won't change anything
Welcome!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 01-11-2019, 06:35 PM   #3
Sumner , Washington
Thank you so much Magnet18 for the reassuring answer!
Old 01-11-2019, 08:14 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The one thing I'd be worried about is what kind of converter you have. Older converters if plugged in all the time will continue to charge batteries until they essentially boil the batteries dry; newer converters will sense the batteries charge level and stop charging when batteries reach full.
https://www.progressivedyn.com/rv/charge-wizard/
Either which way, make sure your batteries are full of distilled water.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 02:14 PM
Stranded Drivable Airstream - engine not turning over GinaParmesan Towing, Tow Vehicles & Hitches 8 09-07-2017 05:21 PM
Turning on Running lights while camping RichHog Lights - Interior & Exterior 137 06-24-2015 09:03 PM
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 09:46 AM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 02:10 PM
