Old 08-08-2016, 03:28 PM   #1
1987 34.5' Airstream 345
bangor , Maine
Trouble in dash A/C paradise...
I cannot get the white vaccuum control tube to retract selector arm under the dash to max air output, any ideas?? I'm about ready to try an old fashioned choke cable... Help, please! Thanks
1987 345 Classic Motorhome
JSargent is offline   Reply With Quote
Old 08-08-2016, 07:51 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Best to check all colored vacuum lines with a manual vacuum pump for proper operation....you can do this with the engine off, key on, with fan on so you can tell what is working and then determine where your problem is. On yours vacuum operates actuator for plenum door to open and close.
bobmiller1 is offline   Reply With Quote
Old 08-09-2016, 01:59 PM   #3
bangor , Maine
Thanks for the info, bobmiller1, and the quick response! Will try this out ASAP.
Boundary Waters Paradise- Sawbill Campground edirwin On The Road... 23 08-02-2011 08:40 PM
Paradise Park has anyone stayed there louski On The Road... 0 01-29-2010 11:29 AM
Greetings from a FL Paradise GoNomad On The Road... 1 06-19-2006 08:51 AM
