Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 03-16-2011, 08:04 PM   #1
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Transmission woes
Just got back from our longest trip yet. 425 miles one way up to beautiful Ouchita State Park in Arkansas. Pulled back into our home town and gassed back up so as not to leave the tank empty and forming condensation while it sits for awhile. Pulled out of the gas station only to find I had no 2nd or 3rd gear!!! Got it home in first, high range, and checked the trans fluid. Full to the level, no bad or burnt smell, no leaks, not hot or smoking either. Checked the vacuum hose down to the trans, and its fine as well. Coach gave absolutley no trouble on the trip, but gets me home really scratching my head. Any ideas on where I should start looking for a problem? Oh yeah. Original 1987 345 trans with 36,000 miles
1987_345 is offline   Reply With Quote
Old 03-16-2011, 08:22 PM   #2
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
I had the exact thing happen to a pickup, and I mean exactly to your description. I found it to be a large snap ring, I guess you'd call it, that held the higher gear clutches on the shaft in the transmission. I dont really know what all the parts are called I had someone do the work. The trany was completely aprart to find this out, so we rebuilt the whole thing. If it would have been a standard I'd have done the work, but I'm not sure about an automatic. This may not be your problem, but they sound the same.
Have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 03-17-2011, 11:50 AM   #3
2006 19' Safari
Newark , Delaware
I had a similar experience with my 350LE. It turned out not to be the transmission but the ECM or Electronic Control Module. When the ECM fails the vehicle goes into a "Fail Safe" mode [also called the limp home mode]. You are limited to first gear. You may want to check this first as it's less expensive then a transmission rebuild. Good Luck.
Delaware is offline   Reply With Quote
Old 03-17-2011, 12:26 PM   #4
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
Had a similar problem with a Winnebago Brave with a Chevy chassis. We were going down the interstate and the transmission shifts down and would only operate in low gear (safe mode). We located a dealer and after testing the transmission they found a shift transducer had gone bad. They went ahead and replace both, just to be on the safe side, and we were on our way. On the chevy tansmission these are accessible from outside the transmission housing and didn't take long to repair.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-17-2011, 03:18 PM   #5
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
I had that happen just a couple months ago in a 99 1/2 ton surburban it was the ignition switch located on the lower end of the steering wheel. Was told not geting proper power to the electric shift thingy's for the transmission to shift been working fine since....SAM
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 07-19-2011, 09:30 AM   #6
Kenneth
1987_345's Avatar
Waxahachie , Texas
Finally got around to fixing it. It turned out to be the nylon gear on the shift control module. I guess the age of it was more than it could bear. It had just crumbled. I would suggest replacing it at your earliest convenience. It was a little hard to locate one, but an easy replacement.
Old 07-20-2011, 11:22 AM   #7
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
do you have a Chevy Part Number ?
John H. is offline   Reply With Quote
Old 07-21-2011, 09:43 AM   #8
Kenneth
1987_345's Avatar
Waxahachie , Texas
Let me see if I can find it for you when I get home tonight. I searched transmission shops all over town to no avail and ended up urdering it online from a vintage type supplier
Diesel Powered MoHo Question wizz General Motorhome Topics 17 03-20-2011 11:05 AM
