Old 11-22-2018, 12:55 PM   #1
Constantin's Avatar
1986 34.5' Airstream 345
Clamensane , PACA
Smile Transmission issues
Hello everybody !
A new difficult came out, i have to change this piece and i don't even know the name of that
it's on the left side of the carter of the gear box
If everyone know I'll be happy to have a little help !
Thank a lot
ps : i found those on R-A is that it ? governor/modulator
https://www.rockauto.com/en/catalog/...modulator,8500
Constantin is offline   Reply With Quote
Old 11-23-2018, 12:41 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, vacuum modulator.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-23-2018, 01:57 AM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Make sure you are getting good vacuum from the inlet manifold to the modulator before changing the modulator....if not even a new part will not work.
On Bella, I found a crack in a T-piece just under the carb, that was preventing vacuum opening the modulator and so not changing gear.
martin300662 is offline   Reply With Quote
Old 11-23-2018, 07:38 AM   #4
Constantin's Avatar
Clamensane , PACA
transmission issues
Thanks to guys !!
is this the vacuum ?
https://www.rockauto.com/en/catalog/...um+switch,4604
Old 11-24-2018, 08:43 PM   #5
Constantin's Avatar
Clamensane , PACA
transmission issues
How i could know witch model i have to choose ? there is a serial number or something i can find somewhere ?
My gear box is not usual on the 345, it's an Allison 4 gear and the airstream is from 1985.
Old 11-24-2018, 09:03 PM   #6
Keen amature
1975 20' Argosy 20
Chestfield , Kent
If the transmission is not standard then searching on RockAuto, Napa etc is more difficult. You need the actual transmission model. For example this is for a AT540 (https://www.ebay.co.uk/itm/New-Allis...4VfO:rk:1:pf:0) but it depends which model you have.
Old 11-24-2018, 10:25 PM   #7
Constantin's Avatar
Clamensane , PACA
transmission issues
Yes i know, but it's exactly the problem i know it's allison gear box 4 gear but i don't know the model, is anyone know here witch model it can be ?
Old 11-25-2018, 12:12 AM   #8
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
My 1987 345 has an Allison AT545 with a Cummins diesel witch doesn't mean much for your coach other then that Airstream did use that model. If you can find the tag on the trans you would know for sure.
Cheers, Dan
~ Margaret Thatcher ~
2013 Interstate Transmission issues B Paradox Sprinter and B-van Forum 18 06-04-2017 01:28 PM
Transmission "idiot" light ? Kistler Tow Vehicles 11 03-22-2004 09:25 AM
Allison auto transmission O/D lockout davidz71 Tow Vehicles 0 01-20-2003 10:28 AM
Transmission questions jcanavera On The Road... 6 08-13-2002 09:36 AM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
