Old 03-15-2015, 08:16 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Transbrake adjustment
I need to adjust the driveline parking brake on the 310. Ive got the hand lever type. Ive read the GM manual and it sounds pretty straight forward, star wheel on a drum brake adjuster. Any tips before I get started from those of you that have done this.
Chock wheels, tranny in nuetral, unscrew thumb turn on hand lever all the way out, all four rear wheels off ground, screw driver to stick in the whole to adjust the star wheel, adjust till resistance on spinning rear wheel, back off just a hair.
Its been at least 25 yrs since Ive adjusted drum brakes. Nothing is ever EASY on these old rigs.......
If any of you have any tips or advice Id sure appreciate it. Thanks as always fellas.......I sure owe a lot of beers
Mike
mayco is offline   Reply With Quote
Old 03-15-2015, 10:45 AM   #2
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mike
I had to adjust mine last summer on a trip. All I did was adjust the cable at the clevis just before the drum and it works fine I tried to use a screw driver but could not get it to work, I think you need a actual old style brake adjuster tool.
I would adjust the knob inside then adjust the free play at the clevis and try it. I never jacked mine up you should be able to tell by the tension on the lever when you pull it on
John
shepherd57 is offline   Reply With Quote
Old 03-15-2015, 11:34 AM   #3
mayco's Avatar
Yep.....I must have been reading the GM manual for the wrong year. No star wheel adjuster. Its all threaded rod and connectors before the drum. Much easier to adjust than the old star wheel. Thanks for the response John.
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Ignition timing adjustment PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 9 04-20-2003 08:22 PM
Pilot light adjustment thenewkid64 Water Heaters, Filters & Pumps 9 02-25-2003 04:04 AM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
