Old 06-08-2010, 08:18 PM   #1
Too hot, so I did some Badge Refinishing...
Took the Badges off the Spare wheel cover cos they were badly weathered..
Hit the 345 badge first... lightly sandblasted it and then hit it with some Semigloss black, then hit the polished face with 100, then 150, then 320 paper, then 600wet...
Not sure if I should polish it to a high gloss or leave it kinda brushed finish..
What do you all think?
Old 06-08-2010, 08:34 PM   #2
Central , Mississippi
Those badges look great although I can say I've never seen a red brick tire cover...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-08-2010, 09:20 PM   #3
Thanks!
Mmmm, well, in this case you would have to "Follow the red brick road!"
Old 06-08-2010, 09:34 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I think I'd stick with the lightly brushed finish you have now. Looks good and should be easy to live with.
Vaughan
Old 06-09-2010, 11:51 AM   #5
projector's Avatar
1972 23' Safari
NSB , Florida
Very nice. Hand sand or machine?
projector is offline   Reply With Quote
Old 06-09-2010, 12:10 PM   #6
I have a small sandblast cabinet, that I used to strip the paint, then I used a Ryobi Palm sander, and a Dremel multimax... both worked good.
I finished with 600 wet/dry with a hand block...
Working on the LIMITED Badge now...
Oh, anyone refinished the steering wheel badge?
Mine, all the white is falling or fallen out...
What about using Bath Enamel repair paint to refill it?
Old 06-09-2010, 11:44 PM   #7
Progress and tools...
Old 06-10-2010, 02:27 PM   #8
projector's Avatar
1972 23' Safari
NSB , Florida
I suggest spraying a clear coat to keep the aluminum from oxidizing.
landyacht badge colors digger bear Clearcoat, Exterior Paint & Trim 3 04-20-2009 07:59 AM
Refinishing cabinets valentine Cabinets, Counter Tops & Furnishings 17 02-06-2009 12:31 PM
Cabinet Refinishing Rat Pack Cabinets, Counter Tops & Furnishings 7 10-20-2006 07:41 PM
badge colors? Byron71 1969-1971 Caravel 2 04-04-2006 02:19 PM
Refinishing one segment jhart657 Cleaning, Stripping & Polishing 3 09-16-2005 03:30 PM
