Old 06-03-2014, 06:04 PM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
Toilet question
strange question here, but besides the air duct for the heater and the obvious toilet discharge piping, can anyone tell me why there is a 9" pedestal under the toilet? Mine has had teh toilet replaced with a thetford high, so the seat height is about 28" off the floor. If I can remove the pedestal and relocate the toilet down 9" it should be a good height for the family. The other option is to replace the toilet with a lower one, but 9" is a big difference from low to high... Input is appreciated, Thanks!
gaiaenviro is offline   Reply With Quote
Old 06-03-2014, 06:27 PM   #2
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
Toilet question
We have the same issue in our trailer. Doesn't seem to be a good solution.
BeachHouse is offline   Reply With Quote
Old 06-03-2014, 06:28 PM   #3
1974 Argosy 20
Kooskia , Idaho
The pedestal is the upper part of the black water holding tank, or at least it was in my '83. 310. It has a flange on it and then the lower part sticks down further. So, there is no way you can lower or remove the pedestal. Hard to believe that someone put a high profile toilet in replacement for the original Thetford low profile one. PO's do some very strange things.
You will need to replace the toilet with a low profile one.
Old 06-03-2014, 06:40 PM   #4
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Name:   ImageUploadedByAirstream Forums1401842364.766197.jpg
Or just get creative!
Air Dog is offline   Reply With Quote
Old 06-03-2014, 06:41 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The original toilet on our '65 caravel was quite high over the black water tank. I replaced it with a low profile Thetford. Nice now.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-06-2014, 07:20 AM   #6
gaiaenviro's Avatar
So not being a good listener I went ahead and tore out the toilet and pedestal convinced I could lower it, which then led to painting the cabinets and walls and redoing the floor. Two thing I learned if you decide to do something similar:
1) The pex line coming up through the floor is actually a gas line inside a pex line, don't cut through it with the propane on...
2) the connection of the toilet flange to the tank is 2 90's (which causes the height) it can be lowered by about 5 inches if you cut off one of the 90's and splice in a 45 degree toilet flange (who knew they made one?).
The end result is that the toilet is now at a usable height, the bathroom looks better, and no more carpet in the toilet room....
Old 06-06-2014, 07:45 AM   #7
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Woohoo!! Good work!
mayco is offline   Reply With Quote
Old 06-06-2014, 11:25 AM   #8
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
before and after pics please!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-07-2014, 03:24 PM   #9
1995 36' Classic 36
Ludington , Michigan
Ya gotta love it when a "crappy" project works out!
Kota is online now   Reply With Quote
Old 06-13-2014, 02:22 PM   #10
gaiaenviro's Avatar
Here are some after pics, didn't think it was going to turn into such a project so no before pics...Click image for larger version
Name:	ImageUploadedByAirstream Forums1402690742.829879.jpg
ID:	214158Click image for larger version
Name:	ImageUploadedByAirstream Forums1402690760.414712.jpg
ID:	214159Click image for larger version
Name:	ImageUploadedByAirstream Forums1402690917.596472.jpg
ID:	214161Click image for larger version
Name:	ImageUploadedByAirstream Forums1402690930.334725.jpg
ID:	214162Click image for larger version
Name:	ImageUploadedByAirstream Forums1402690945.307060.jpg
Old 06-14-2014, 07:41 AM   #11
Vycan's Avatar
Manhattan , Kansas
Looks Good!
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Toilet question Skamper1 Sinks, Showers & Toilets 9 06-28-2010 11:50 AM
Beginner question on value of shower/toilet dhyatt Interior Restoration Forum 6 05-08-2004 12:34 PM
Toilet Bowl Seal Question? JoeW Sinks, Showers & Toilets 1 10-09-2003 10:34 PM
