Old 03-08-2006, 02:56 PM   #1
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Toilet model
My 1986 345 has the original toilet. I have a small leak up high under the seat while flushing. It is a Thetford toilet but I do not know what model. Anyone have any original paperwork on their units?
Thanks, Rob
Robfike is offline   Reply With Quote
Old 03-08-2006, 05:47 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Rob,
I don't know what model you have but it sounds like a vacuum breaker leak. It is usually located in the rear of the unit, high on the back just below the seat. If it is bad, they have to be replaced......very easy task.
Old 03-08-2006, 07:47 PM   #3
Robfike's Avatar
Speedway , Indiana
Lew,
You normally have to pull the toilet to do this job, is that right?
I have seen the exploded view from some newer Thetfords, and I was suspecting that might be it.
Old 03-08-2006, 08:10 PM   #4
lewster's Avatar
It depends on how tight the bowl is mounted to the wall. Sometimes I can get my hand back there and can wiggle out the v. breaker. It usually just slips into a rubber fitting. If it is screwed in.......you're screwed! But really, it's no biggie to remove the 2 or 4 bolts that hold it to the floor and get to the back. If you do......replace the closet flange/wax ring to save yourself the job of doing it again down the line. Use an inspection mirror to check how it's in there.
Old 03-09-2006, 06:48 AM   #5
Robfike's Avatar
Speedway , Indiana
Will do, Thanks
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 06:38 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
