Originally Posted by mlmarch
David
The quick connect is like the one you would use to hook up a compressor. Would that have been an accessory to inflate tires etc that works off of the rear bag compressor?
That's exactly what it is - a light weight coiled air hose from one of the "cheapie" tool houses will allow you to air up your tires at your convenience instead of fighting with a heavy air hose on a hot concrete pad at a fueling station. Make sure it is long enough (might have to quick connect two together) to check and air up the front air bags.
If you have to replace the front air bags do a search on "air bags" here in the Forums - several of us have done it by varying methods....not hard to do, and you always have the option of going to a vendor and have it done....either way, be sure to run the fill valve extension hoses to the front of the MoHo where they are easy to get to so you do not have to crawl under the front end whenever you want to check the pressure.
Be sure to check the inside dualies when you do air the tires - they are a bugger to get to, but if one goes flat it will surely throw the tread and most likely crater the outside tire in the process.
