Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-02-2014, 09:26 PM   #21
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
That gives me hope
Bandit weights 50 pounds....a small boxer.....thanks for the picture.....and the info. Paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 05-03-2014, 09:33 AM   #22
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sioux Falls , South Dakota
Send a message via Skype™ to Jenniflow
That Dane is adorable! Good thing we don't have pets.
I can see this is going to be a hard choice because I really love to drive and we do carry guitars with us a lot and, what with needing at least one suitcase for the two of us, the Insight and smart do feel too small. I really hate to overload the motor home tho! All the others I've found that feel safe are 2500 lbs. hmmmmm.
If I put a transmission cooler in there and rebuild the carb, can I get away with 2500 lbs again? Geez. I did manage to tow the Mini but I was single then and that was 10 years ago.
sent from my hipflask
Jenniflow is offline   Reply With Quote
Old 05-03-2014, 09:42 AM   #23
Jenniflow's Avatar
1982 34' Limited
I guess I should explain: When we travel, I am often picking Joe up at the airport and he has been traveling with a suitcase, a backpack and a travel guitar. Maybe we could squeeze all that into an Insight of a smart? Hmmmm.
Old 05-03-2014, 11:22 AM   #24
SteSpot's Avatar
2000 lb wt limit
I am curious as to why the 2000 lb wt limit? Is it because of the limit of the hitch or the limit of the 454. I have had people tell me that the 454 can pull anything. Thoughts? paula
Paula & Ed
Old 05-03-2014, 11:35 AM   #25
Jenniflow's Avatar
1982 34' Limited
Great question, Paula, I'd like to know the answer to that too.
Old 05-03-2014, 12:00 PM   #26
SteSpot's Avatar
P30 Service Manual
I googled the P 30 Chassis Service Manual and on page 1-3, there is a chart that shows the GCWR (Gross Combination Weight Rating) with includes the combined weight of the motor home, all of its contents and the total weight of what is being towed.
The 7.4 L (454) v8 gas shows either 12,500, 13,500, 14,500 or 16,000 pounds depending upon the rear axle ratios. I think my 24' motorhome weighs about 9000 pounds and my gear is probably ? 1000 pounds or more.....question is, what is my MH rear axle ratio?
Also, the hitch on my (1982)24' needs to be cut off and replaced. Doubt it could tow a bicycle. I really don't want to tow a toad and am hoping I can install side cameras and a rear camera that will make driving the MH easier. Paula
Paula & Ed
Old 05-03-2014, 12:34 PM   #27
Jenniflow's Avatar
1982 34' Limited
On the sticker on the headliner over the cab it says maximum vehicle weight 16,500. I have been thinking of that as the GVR and that the toad is extra. Having read someone else's post saying owners manual said 2000 max, I thought I was now looking at 18,500. Maybe now I AM looking at a bicycle.
Old 05-03-2014, 12:35 PM   #28
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Most of our coaches of that era came with a 4.56 gear ratio. I you want to crawl under the coach there is supposed to be a tag on the differential cover that indicates the ratio.
All parts of the drive train, the structure of the coach and hitch and the ability to stop the whole mess are part of the consideration. You can strengthen the weak links but you need to determine which link is weakest and is there more than one weak link to consider. Another point is the driver. Some think there is something wrong if you can't climb a 6% grade at 75 mph while others are happy at 40 mph. GM and Airstream take all the info and make what they think is the best choice for "Joe Public."
Jenniflow go look at a smart and take some suit cases with you. You will be surprised how much they can hold.
Cheers, Dan
~ Margaret Thatcher ~
Old 05-03-2014, 12:54 PM   #29
Jenniflow's Avatar
1982 34' Limited
Very interesting about the ratio. I'll check, or take some other 345 owner's word if I can't see it.
And about the weakest link, great point. I'll have to do some more research there but while we're at it, is the rust on this hitch receiver Click image for larger version
Name:	ImageUploadedByAirstream Forums1399143185.399965.jpg
ID:	211141Click image for larger version
Name:	ImageUploadedByAirstream Forums1399143233.259827.jpg
ID:	211142a weak link? Or is it just cosmetic?
Old 05-03-2014, 12:58 PM   #30
SteSpot's Avatar
Since our 24' is a lot less motorhome than the 27, 31 or 34 ' I was hoping we could tow a Jeep.....and trust me, I don't go 75 in this motorhome. We also tow our 68 Ambassador with a Denali but we have disc brakes on the trailer and use our lower gears for helping to slow the rig down. That little tag seems to have disappeared from our differential cover and have not been able to get that number. I appreciate your posting here and sharing your knowledge. Thanks so much, p
Paula & Ed
Old 05-03-2014, 10:11 PM   #31
There is a relatively easy way to check your ratio. Find a spot that you can move your coach about 15' ahead. Put a chalk spot at the bottom of one tire where it meets the pavement. Now crawl under the coach and mark a spot on the bottom of the driveshaft. Grab about 5' of cord or light rope and tape it to the bottom of the driveshaft where you just marked it. Looking from the front of the coach the driveshaft turns clockwise when the coach moves forward. You want to tape your cord so that it will wind up on the driveshaft as you drive forward. Now it helps to have an assistant if you can find one.
Have your helper stand by the tire with the chalk mark. You want to drive forward exactly one revolution of the tire. Your helper can make sure you stop at exactly one tire revolution. Also your helper can keep and eye out to make sure your cord doesn't get caught under a tire. Now all you have to do is count the number of wraps of cord on your driveshaft. If you have about 4 1/2 wraps you have a 4.56 gear. a 4.10 ratio will give you just a bit more than 4 wraps and a 4.88 will give you nearly 5 wraps. As long as you stop right at one tire revolution it's pretty easy to tell what gear you have.
As for towing you ideally want to use your transmission to slow you enough that you don't need to use your brakes. There are long grades like the Sherwin grade north of Bishop on 395 that is 9 miles long. Using your brakes much on that grade will heat them up pretty hot.
Cheers, Dan
Old 05-03-2014, 10:16 PM   #32
And about the weakest link, great point. I'll have to do some more research there but while we're at it, is the rust on this hitch receiver Attachment 211141Attachment 211142a weak link? Or is it just cosmetic?
It looks more cosmetic. Scrape the paint off and hit it with a wire brush. If the steel is fairly smooth with no deep pits or signs of metal loss you are fine, just give it a coat or two of good paint.
Cheers, Dan
Old 05-04-2014, 06:24 AM   #33
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Dan's right about the rear end ratio. I'm not sure of the cut off but I'd imagine a 28' and lower with a 400 tranny would have the ordinary Dana 70 with 4:10's, like a friends Argosy. Once you get to the 300's and up in most cases, other than the pushers obviously, we're running 475 or Allison trannies with Dana 70HD (4" axle tubes) and 4:56 gears. The Dana 70HD can be mistaken for a Dana 80 as they do have the same size axle tubes, as I found out.
As for the hitch, maybe have a welder take a look at it for structual weaknesses. I do know Airstream did put a towing limit of 2000lbs, but I'm not sure if that was due to the limits on the hitch, or most likely, limits on the power train, (strain on the engine, tranny and brakes), especially for 325's and up. I personally think that Airstream did place a 2000lb GTWR (Gross Trailer Weight Rating) on our vehicles but have not seen anything written in stone.
The weight ratings above or behind the sun visor are GVWR (Gross Vehicle Weight Ratings). This is the maximum your coach can weigh with all passengers, freight and liquids, EXCLUDING trailers. Mine has a weight rating of 14,500 lbs, with the flooring out of it and a few cabinets ripped out with no freight, (clothing cookware etc). With a full tank and me inside, it weighed 12,850 lbs, the rest of my family will add 400 lbs. I still have to put a floor inside and cabinets so weight will be an issue.
I have never heard of a motorhome being weighed and taken off the road for being over weight, but that's not to say that the Rogers, Bulls or five-O can't do that if given the chance too. So when renovating, adding bling or loading your motorhome it would be a good idea for you to find a local weigh scale (garbage or transfer station, a place that sells rocks or bulk landscaping supplies or like I found, a local grainery or feed lot) and weigh your coach fully loaded…………I think you may be shocked at how much STUFF we can add.
Cheers
Tony
Old 05-04-2014, 11:02 AM   #34
Mont Vernon , New Hampshire
Anyone tow a Jeep Wrangler? I have a 98 with a standard transmission. I have added a Banks System to the MH. Thought on towing the 98 Jeep? The hitch has been improved as the prior owner towed a fully loaded 4 place motorcycle trailer.
Thanks,Kate
bugsbunny is offline   Reply With Quote
Old 05-04-2014, 11:31 AM   #35
Tony my 280 has the Dana HD 70 with 4.56 gears. I think all of the coaches with rear disc brakes have 4.56 gears. The rear disc brake indicates the HD 70. With rear drum brakes on the 70's coaches I'm not sure what they used.
The hitch on my 280 was pitiful. With the rear bath it gets pretty tight with the tanks just inside the bumper. There is a thread a couple of years ago on how I rebuilt mine. I still want to do some more work on it. The coaches with a center bath have a lot more room to work with in the rear. There are several threads of hitch work on these coaches.
There is a GVWR that rates the weight limits of the coach. There is also a GCWR which is Gross Combination Weight Rating. There is a chart in the Chevrolet Motor Home Chassis Service Guide that lists the 454 engine with a 4.56 rear having a GCWR of 19,000 lbs.
As you say nobody checks but the scale is your friend to keep you on the safe side of the limits.
Cheers, Dan
Old 05-04-2014, 12:42 PM   #36
woodja's Avatar
1982 31' Airstream 310
Dayton , Tennessee
When we (she) decided to discontinue towing the motorcycle/trailer combo,
I started trolling the internet looking for my options.
What I stumbled onto at Craig's List & in my area was a Chevy Tracker. The guy had been towing it behind his moho so it came with tow bar, wiring, safety cables & everything but a braking system. 2003, 100,000 mi, 4WD automatic so suited for towing 4 down. A very nice vehicle at slightly under 3000#. And I was able to buy a Brake Buddy, also on Craig's List for $200.
Couldn't be happier with the choice. I have a back up camera or I wouldn't know it's back there.
It's my understanding that the difference between my Tracker & the Suzuki is that my power train is all GM. -------Pete
woodja is offline   Reply With Quote
Old 05-04-2014, 09:12 PM   #37
Dazed and Confused
Isuzusweet's Avatar
Au contraire mon ami. As a 2003 Tracker LT 2.5 V6 owner and lover, the only thing GM was the Chevy badge and the AC Delco battery. These rigs were assembled down the road from me in Ingersoll Ontario Canada at the CAMI plant. GM could never build a truck as well built as these rigs are.
The trims differences and levels were as follows
Grand Vitara had the V6, 320mm disc brakes and 16" rims with 235/60R16 tires under wheel well cladding, painted body cladding, mirrors, bumpers and power everything.
Next was the Tracker LT with the V6 but the 280mm discs found on the base Vitara, 15" rims with 215/75R15 tires, no wheel well cladding but body coloured bumpers, cladding, door handles, mirrors and power everything.
The Vitara came next with the 4 cly motor 280mm discs but 16" steel rims with a 225/60R16 tire and with the LT power package, but black bumpers, moulding and door handles.
Last was the base Tracker with the 4 cly, 280mm brakes and no power package, black bumpers, mirrors and door handles.
There was an XR2 package with skid plates I do believe somewhere in the mix.
The US base tracker MAY have had power windows but the Canadian ones didn't.
Mine is almost in showroom condition and has cost me less than a G note in repairs over the last 150,000 kms, however I think the steering rack is on the way out. If you had the V6, MAKE SURE YOU USE SYNTHETIC OIL AND CHANGE IT REGULARY. The timing chain needs good oil for lubrication, if the oil is dirty it will destroy the chain guides. If you hear a ticking coming from the front of the motor you need to get a timing chain kit with chain and new guides very soon. The motor is an interference design, so a loose chain skipping teeth on the cam cogs will cause all 24 valves to impact pistons.
Also change diff and transfer case oil with some Amsoil severe gear oil. It does call for 80 weight for the diffs but the 75 weight of the Amsoil is just fine. The original spec oil for the transfer case is 75 weight. This is very easy project for you as all diffs and transfer case have drain plugs. DRAIN PLUGS, a 10 cent part that seems to elude GM, Ford and Chrysler.
Whatever you do DON'T take your rig to a Chevy dealer as he will not have any parts, or will charge you an arm and leg for what parts he has. None of the mechanics at my local GM dealer have a clue on how to work on these great trucks. I have allways taken my rig to the local Suzuki dealer for scheduled maintenance that I couldn't do myself.
Suzuki unfortunately has bailed on NA, but some of the dealers are still working on these rigs as warranty service centres and supplying parts for them.
I have thought of using mine as a toad and did buy a US Gear braking system for it but have not hooked it up yet.
PS If towing the Tracker 4 down with the transfer case in neutral and you have the automatic tranny; you still need to start the engine and with the transmission in neutral, run it for a couple of minutes to get the oil circulated every 300 kms.
Happy motoring
Cheers
Tony
If you have any service questions I have the GM work shop service manual for that model year and it covers all Trackers 4 and 6 cal.
Old 05-05-2014, 09:39 AM   #38
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
We love our 2014 Fiat 500 L Trekking. Six speed manual. Fun to drive and tows simply (out of gear, parking brake off. Period.)
3,000 pounds, however. 30 MPG. Very roomy and easy to get in and out...it is high.
Since our motorhome experiment is coming to an end and we have purchased another Airstream, the Fiat needs a home.....interested? Six months old and 5K miles. Roadmaster base plate, Roadmaster Sterling All Terrain tow bar and Air Force One brake. Turn key. Perfect toad IMHO.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 05-05-2014, 09:53 AM   #39
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
I believe the 2,000 lb. limit is based on the hitch. My original hitch broke loose on one side while towing a bass boat luckily I was doing 20 miles per hour going through a small town. I have since replaced this hitch with a 10,000 lb. one and tow a 1999 Jeep Wrangler or a large Fiberglass Open Bow Boat depending on the situation and don't know they are even back there.
Gunter
2000 Land Yacht XL 355
gunner is online now   Reply With Quote
Old 05-05-2014, 10:17 AM   #40
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
From what I can gather, Gunner has it correct, the hitch on the Airstream Classic motorhome is rated at 2000lb. Have seen at least one thread where the original hitch was upgraded to tow considerably more weight, as well as where others have gone to a higher rated hitch.
I'd just like to know this. Who tows a new car behind their Classic? With all of us driving at least a 20 year old (some even quite a bit older in years) motorhome, I really don't want two vehicles that will require me to carry along extra parts.
Looking at Motorhome Magazine that lists towable cars, I'm more interested in 4-down towing, but really don't want to pay a TON of money for the car.
I've always liked the smart car, would truthfully want a 4-door car though.
No need for a Jeep, or anything 4-wheel drive.
Does anyone have the new Ford Fiesta? Chevy Sonic? Or even Dodge Dart?
Thanks, Derek
« 1983 300 | Top | RV covers? »
TOADS (toweds) Smart Car jpalamaro Land Yacht/Legacy Motorhomes 7 08-24-2010 08:35 PM
Toads - maybe a Beetle? gypsychris General Motorhome Topics 25 04-02-2008 01:45 PM
Any Saturn Toads out there? Jim & Susan General Motorhome Topics 11 06-17-2007 11:04 PM
Kissing Toads Alumaholic Buyer Guidelines 24 07-04-2006 11:55 AM
Toweds, Toads, or Dinghys and stopping. thenewkid64 Airstream Motorhome Forums 13 02-16-2003 07:06 AM
