Old 05-06-2011, 04:00 PM   #1
warrenivan's Avatar
1981 28' Airstream 280
Santa Barbara , California
To wood or not to wood?
So this is my second post as an actual airstream OWNER! We're terrified.
More on the purchase here here.
One of the bigger items on our wish list is to replace the carpet with a false laminent bamboo. I've done some digital sketching and come up with the below - which feels good to us.
But our main question is, what kind of insulation should we put beneath the new flooring to cut down on noise?
We're also doing our best to research what might be good for insulating the engine hood between the front seats to minimize engine smells and especially sounds (inside and outside).
current interior
quickly sketched future interior
warrenivan is offline   Reply With Quote
Old 05-07-2011, 12:39 PM   #2
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
quote
The soundproofing closed cell foam at the top of the page at
Super Soundproofing, Co.
works very well and it's very durable. It's sold off of bulk rolls, so the costs are as reasonable as can be....
More info on soundproofing generators at Soundproofing a Generator
BJ Nash - Senior Soundproofing Technical Specialist
Super Soundproofing Co
www.soundproofing.org
888-942-7723
You can also do a Google search for marine, engine, generator compartments and RV insulation, soundproofing material
for under the floor you may look into material used on airplanes and Yachts, house boats.
John H. is offline   Reply With Quote
Old 05-07-2011, 01:12 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
There are a variety of underlayments available for laminate floors. You get what you pay for so far as a sound and vapor barrier as well as for comfort. The most expensive laminate underlayment probably has to be ordered since the big box stores don't carry it on site.
But, we installed a laminate floor in our kitchen at home. It looked great and was easy to install. The dishwasher leaked, the water wicked through the underlayment, 8 boards swelled. We had to remove the floor, replace some of the underlayment and the boards, and now it's back together. Fortunately we had enough leftover materials to not have to order more. The locking parts did not lock as well as when we originally installed the floor. It looks fine, but although we thought we bought a better quality brand (Armstrong), it is not quite up to our standards. I am going to seal with clear silicone the edges close to water sources this weekend.
There is a lot of potential for water leaks in any RV—plumbing, shower, entry into the unit, leaks. I don't think a laminate floor is a good idea. If we install laminate in anything again it will be in a bedroom or other living space without any chance of water infiltration.
Our vinyl floor has humps in it because it was installed improperly. The factory runs the vinyl in first and then places the cabinets and partitions on top of it leaving no place for expansion. This seems to happen more often in places with very cold weather. We have discussed replacing the floor—cork and rubber tiles are a possibility. They should be lighter than laminate and provide some sound insulation. If they are pre-sealed on all sides that would work best, but you could seal on all sides before installation. They are easy on your feet. Rubber tiles are hard to find but a big floor store may have them—I like to see and handle things before I order them. Any floor needs space between cabinets and partitions for expansion. 3/8" is usually recommended, but it really depends on the expansion rate of the material. You have to put some sort of trim over that space and in some parts of an RV that may be tricky, but it probably can be done.
Also, your proposed interior shows the boards running from front to back. That makes hallways and narrow passages look narrower. The usual way to install is to run the board across the hall or passage to make it look wider.
Gene
Old 05-07-2011, 01:32 PM   #4
Master of Universe
Gene's Avatar
Warren', The three types of underlayment for laminate are foam (cheap), poly (combination of foam, vapor barrier and sound deadening—medium price), and cork. The cork is most expensive, but best. I don't know if it has a plastic sheet glued to it for a vapor barrier, but it is easy to add.
I just read your thread about searching for the right MoHo and am glad you waited for the right one. A rebuilt engine and transmission is a very good thing.
You can leave the throw rugs on the floor until you figure out what floor you want to install. Checking out all the mechanicals comes first and doing some camping to enjoy yourself. The floor can wait.
Gene
Old 05-08-2011, 01:31 PM   #5
Santa barbara , California
good ideas
Tks18 is offline   Reply With Quote
Old 05-08-2011, 08:38 PM   #6
warrenivan's Avatar
Thanks Gene & John. Great suggestions.
We'll do some more research and let you know what we find. In the meantime, I think Gene is right about taking her camping. We're going to do that as soon as we put the new blinds in for some privacy (we already pulled out the old stuff ).
Old 05-09-2011, 08:27 AM   #7
Master of Universe
Gene's Avatar
Keep us posted on what you do—I'm in no hurry to replace the vinyl even though the hump in the middle of the floor is ugly, so I want to see what you discover about alternatives. Every time I have a problem like that I often find waiting until I think through each possibility makes for a better result.
Gene
Old 05-11-2011, 09:56 PM   #8
1984 31' Airstream310
College Station , Texas
WVan: Just for your info: I split the floor coveing in my unit in three. 84 310. I carpeted the back half (even with the accordian privacy door) because it is warmer and quieter and used a laminate floor w/underlayment in the middle. Finished out (up front drivers area) with same carpet as the back.
pdallas is offline   Reply With Quote
Old 05-11-2011, 11:54 PM   #9
pdallas
Do you have pics of your flooring? Would love to see.
Old 11-02-2011, 06:27 PM   #10
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I'd like to see some photo of your floor to. I'm going to try an put some in my 82 Airrsteam this winter
alfalsetto is offline   Reply With Quote
Old 11-04-2011, 09:01 PM   #11
1987 34.5' Airstream 345
Milton , Florida
Be careful that whatever soundproofing you use doesn't hold moisture. You may not have leaks now, but the histories on this site say you will eventually. Laminates do not like water and will swell up...most say, don't use in bath or kitchens. We're gonna use a marine vinyl that looks like teak, Underway Marine Flooring, Custom Marine Flooring, Tampa Florida Boat Decking, Marine Carpet, Boat Flooring, Marine Decking or a similar product. Looks like wood but is water proof and easier to remove. Our reason for not using laminate was too slippery for dogs when we're moving and Florida sand too abrasive for finish.
Pdallas, good idea splitting them up. I'm gonna do that myself.
navyspook is offline   Reply With Quote
Old 11-05-2011, 10:52 AM   #12
alfalsetto's Avatar
Thank's, I'll try it this winter. I hope!!!!
Old 11-05-2011, 01:08 PM   #13
Yes, get those pics flowing, as I was looking at Laminate flooring at Home depot this morning...
I calculate I need about 65sqft to do my from the cockpit back to the bedroom entrance in my 345.
Money is tight, so it will have to be a lower budget fix.
Someone put horrible carpet down in the bedroom, and halfway down the galley, which i will be replacing soon with some nice carpet I got from a neighbor. That will leave me a 6' length of floor bare between the vinyl kitchen floor and the new carpeted bathroom threshold.
I saw some laminate with good reviews for $0,68/sqft.
With the comments about moisture in mind, is there something I can do to the joints on the cheaper laminate to extend its resistance?
Old 11-05-2011, 01:19 PM   #14
1986 25' Sovereign
Plant City , Florida
We had carpet from the door to the galley when we got our stream. We hated it because it was difficult to keep clean. I purchased wood flooring from lowes @ 1.25 per sqft and we love it. I will post pictures later.
ck21084 is offline   Reply With Quote
interior, sound insulation, wood floor
1975 Excella 500 what kind of wood veener I have? Mypanhead Cabinets, Counter Tops & Furnishings 3 04-27-2011 08:38 PM
Feast of Spring Rally at Penn Wood Airstream Park PA Camper WBCCI Rallies & Events 0 04-06-2011 06:14 PM
Workamping Opportunity At Penn Wood Airstream Park DEITZ645 Working on the Road 0 03-14-2011 11:58 AM
Wood backing in replacement cushions? Camp Upholstery, Blinds, Walls & Interior Finishes 5 02-02-2011 04:02 AM
Bending wood Splitrock General Interior Topics 0 01-21-2011 08:05 PM
