Old 10-27-2009, 08:02 PM   #1
ccetex's Avatar
Lubbock , Texas
Question To polish or not
To polish or not to polish, that is the question. I have searched and I am confused. Is an 89 345LE a candidate for polishing, and if so what is the procedure?
If not what makes it look goooooooooood?
Do you have to strip (the coach), then polish, then what?
Is there a procedure to follow for this?
Would love to have step by step instructions including products to use.
I have read stuff here and sure I am missing a bunch of threads on this topic, but it is hard to find a definitive answer.
Chuck
ccetex is offline   Reply With Quote
Old 10-27-2009, 09:53 PM   #2
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Since the question is: "To polish or not?" my canned response when folks ask about /suggest my polishing the Airstream is: "That will be a great project for the next owner"
snake is offline   Reply With Quote
Old 10-28-2009, 02:11 AM   #3
1989 34.5' Airstream 345
Silverton , Colorado
I would have to agree...it's ALUMINUM underneath...cosmetically 'damaged' has nothing to do with integrity, and that should be the main concern...the rest is personal preference, and relevant only to the current owner...some folks shine them up, some folks re-clear-coat them, some have the whole paint job done...your choice, obviously, but it is aluminum under all that cover...it's gonna last longer than you...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-29-2009, 03:39 AM   #4
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
34.5 feet is a lot of aluminum to poilish. I did the door on mine, it looks great but dammed if im doing the rest and then keeping it up every year or so. I've thought lots about painting it though as some of the clear coat is looking a bit shabby.
elbundi is offline   Reply With Quote
Old 10-29-2009, 07:38 AM   #5
Still aluminum under the shabby...ours is quite 'weathered', cosmetically challenged is the term I use, but it gets down the road, and we call it home for 9 months of the year...our home without wheels has a rusty-looking roof, but it doesn't leak...m
Michael & Tracy
1989 345 Motorhome
Old 10-29-2009, 07:47 AM   #6
Chuck
Chuck.
1. Yes, you must strip the coach.
2. Then polish.
3. "Then what ?" Be prepared for a ton of work, keeping the coach looking nice, after the polishing.
Raw aluminum oxidizes. You must establish a routine to
keep the shiney look.
That means a wash and polish job, every 30 to 60 days.
And that's ok, if you have nothing better to do with your time.
For openers, you should make sure the coach is water tight.
20 year old gaskets take a beating in that west Texas climate. Window, door, access door, and sewer vent pipe gaskets, all give out over time, especially sewer vent pipe gaskets which only last 2 to 3 years.
Old 10-29-2009, 07:58 AM   #7
ccetex's Avatar
Lubbock , Texas
Great points everyone, gives me some things to think about.
Andy, thanks for your input. These are things I have not thought of. The points about the gaskets really have me thinking. I get the coach tomorrow and that is the first thing I will check out.
Chuck
Old 10-29-2009, 08:46 AM   #8
Reno , Nevada
clean up
havnt touched my trailes exterior skin yet but was thinking of just semi polishing it, remove 50 yrs of oxidation but stop when it looks clean and still has that "look" of a new airstream and not go so far as to turn it into a mirror finish. that way I wont have to be re polishing all the time, maybe just spring and fall hand buff it a bit and call it good.
skittles is offline   Reply With Quote
Old 10-29-2009, 09:49 AM   #9
tallytwo1994's Avatar
tallahassee , Florida
Originally Posted by Inland RV Center, In View Post
3.Raw aluminum oxidizes....
No one polishes every 60 days, and I can't imagine the circumstances that would require such a routine.
Yes, it's true that aluminun oxidizes and it starts as soon as it's exposed to air. But the oxidation actually protects the finish too.
Take some time to go through some of the threads in the polish sub-forum for much more specific answers to your questions.
http://www.airforums.com/forums/f441/
Carol
tallytwo1994 is offline   Reply With Quote
Old 10-30-2009, 09:18 PM   #10
"Cosmetical Challenge" is good enough for us...IT"S ALUMINUM...cloudy or shiny...IT"S ALUMINUM...leaks are another issue, but so far we've had leaks at the TV antennae and the rear AC...not bad for a 20 year old...and the leaks aren't bad, so far...wish I could say the same for myself, and I'm over 60...freezing weather compromises seals, so we're headed for AZ, but it was 11 this am, although our neighbor's gauge was 1...maybe the time to leave is yesterday!!!m
Michael & Tracy
1989 345 Motorhome
Old 10-31-2009, 08:14 AM   #11
Jamestown , Kentucky
Images: 13
Has anyone used Olive Oil ??? to clean and polish the aluminum skin ???
I use it some on anodized aluminum on our Houseboat and it does an amazing job of cleaning, removing oxidation !!! and it is a natural product !
John H. is offline   Reply With Quote
Old 10-31-2009, 08:39 AM   #12
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Never heard of this but I found this on the web "An emulsion of equal parts of rum and olive oil can be used for cleaning aluminum."
Two parts rum for me...
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-31-2009, 09:30 AM   #13
Images: 13
I prefer Kentucky Bourbon Myself Silverleeper !
I was quite surprised at the acid and cleaning abilities found in Olive oil alone, But along with the alcohol blended in ???? I will give that a try !!! Thank You
Old 10-31-2009, 09:52 AM   #14
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I'm a paint fan myself. The original two tone paint job on most of the AS Moho's was very nice indeed. Back in 1984 mine was done with Dupont materials and has weathered well.
You can paint with new technology chrome paint if you really want shine, it's not cheap but in the long run would be cheaper than a strip, polish, maintain routine.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
half polish, dull, or matte, polish techniques ? greenrig Cleaning, Stripping & Polishing 9 07-11-2009 10:11 PM
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 11:15 AM
Need Help with Polish rebel beck Cleaning, Stripping & Polishing 5 06-13-2007 03:40 PM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 11:28 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
