Old 11-09-2013, 09:54 AM   #1
1991 30' Airstream 30
Lake Luzerne , New York
Tires - 8R19.5 to 225x70x19.5 thoughts?
As the older tires are getting harder to find for our Classic motor homes (mine is a 300LE) I am wondering if anyone has switched to the 225x70x19.5 or the 245x70x19.5 tires and if there seems to be any difference in driving, safety, etc.
Thanks in advance for any thoughts or suggestions.
"Polishing away in FL"
ADK Jim is offline   Reply With Quote
Old 11-11-2013, 04:58 AM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I recently bought tires and was told under NO CIRCUMSTANCES would the 225x70 would fit on the dually axle. Tires would be much too close at sidewall area.
Good Luck, Derek
Old 11-11-2013, 06:16 AM   #3
CapriRacer
CapriRacer's Avatar
I'm in the , US
OK, here's the scoop:
An 8R19.5 is 8.0" wide on a 6" rim (with an allowable rim width range of 5.25 to 6.75", a diameter of 33.8" and a minimum dual spacing of 9.1", and a load carrying capacity of 3525# at 110 psi (single, Load Range F)
A 225/70R19.5 is 8.9" wide on a 6.75" rim (8.6" on a 6" rim), with an allowable rim width range of 6" to 6.75" and a diameter of 31.9", a minimum dual spacing of 10.0" ( 9.7" for a 6" rim) and a load carrying capacity of 3640# at 95 psi (single, Load Range F)
A 245/70R19.5 is 9.8" wide on a 7.50" rim with an allowable rim width range of 6.75" to 7.50", and a diameter of 33.3", and a minimum dual spacing of 11" with a load carrying capacity of 3860# at 95 psi (single, Load Range F)
Summary:
I think the 225/70R19.5 is a much better choice. It is much more likely to fit.
- BUT -
- If the rim is 5.25", then the 225/70R19.5 is a No Go.
- The 225/70R19.5 needs 0.3" more clearance between the frame and tire. This can be difficult to check as the worst condition is when the steering wheel is fully turned AND the suspension is fully collapsed. I'd advise getting someone who is knowledgeable about truck suspensions to look at this.
- And the minimum dual spacing could be a problem and needs to be checked.
CapriRacer is offline   Reply With Quote
Old 11-11-2013, 07:56 AM   #4
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I am running Michelin 225/70R19.5 on mine except for the Tags ( not enough clearance). Have had no problems. Tires are wider than the old Goodyears and handling seems to be slightly better.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
