Throwing down some gravel isn't overly expensive, and will do you much better than plywood/grass. It won't rot, it will help drain water away from your undercarriage, and it won't grow up into your engine bay come spring! Plus it helps with aesthetics, property values, blah blah
Curious what others have to say about the jacks, if you're going to move a rew feet monthly to roll the tires anyway, I'd leave them up to keep them out of the weather. Just my $.02
1983 Airstream 310 Class A Motorhome
-Rob
