Old 03-08-2014, 02:19 PM   #1
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Tire balancing question
I picked up a 19.6x6 rim and tire to use as a spare, and took it to a local tire shop. They got it installed, but we're not able to balance it. One guy said you put a small bag of sand inside? Should I take it to a truck tire shop and get it balanced?
SebasSF is offline   Reply With Quote
Old 03-08-2014, 02:38 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Sand balancing is what was in the aluminum wheels on my motorhomr when I replaced tires.
I was told that each tire should have certain amount of sand, not just an inderterminate amount. I purchased Centramatic's instead.
Good Luck, Derek
Old 03-08-2014, 04:10 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Are you sure it was sand or something like Dyna Beads? Tire Balancing Products
Sand has sharp edges and is abrasive. I don't think that would be good for the rim or tire. By the way I use Dyna Beads when I mount my tires.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-08-2014, 09:58 PM   #4
SebasSF's Avatar
Hey, that's cool...thanks!
Old 03-14-2014, 03:39 PM   #5
SebasSF's Avatar
Ok, so I took eh tire to a truck shop, and they used a bag of balancing material. Did not catch the brand. Thanks for the help.
Old 03-14-2014, 04:05 PM   #6
ottawa (greely) , Ontario
The best way to balance a tire is with a road force balancing machine ,most balance the tire wheel assembly in the air with no load on it,this is ok most of the time ,but do you drive down the road with your wheels not touching the ground! The best way is to balance the tire wheel assembly is with a load on it ( real world condition) this is done by a special wheel balancer called road force balancer it applies a load on the wheel and tire by a roller equal to a load on the road , the reason road force balancing is better is under load a tire changes deflection and when the tire is manufactured some areas of the tire stretch more then others under load so you end up with a oval wheel under load to optimize this the road force balancer will measure this out of round and try and offset the out of round with the rim ( because all rims are not perfectly round) to minimize the vibration then a minimum amount of weight can be installed as a patch inside the tire or outside traditional weight .
scamp is offline   Reply With Quote
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
A Bias to Radial Question Eagle & Bear Tires 9 10-05-2011 05:32 PM
Tire question? djgarcia Tires 1 09-28-2011 07:26 PM
Tire Rack $70 Reward Card my3sonsdad Tires 1 08-02-2011 11:22 AM
Need One Tire.. 1Rookie Tires 8 06-13-2011 06:09 PM
