Old 09-29-2011, 07:22 AM   #57
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
I posted a while ago the name of the place I bought a converter system for the rear air. It has been working great for 6 years. On the web, contact Power Solutions. The cost for the system not including a 20 amp rated cord was Approximately $100. Their cost for the cord is reasonable. It allows you to disconnect the gens 20amp feed and reroot it to an additional cord for the needed extra 20amps from the power poll.
raveson is offline   Reply With Quote
Old 09-29-2011, 07:38 PM   #58
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by AirRowan View Post
I plan on putting a switch in the generator compartment and wiring a 220v 50amp plug in or next to the generator door. I figure that if you are at a place that has 50amp service and it is hot it would be nice to run both AC units. For about $215 (50amp cord not included) one can wire up for 50 amp with out messing around in the Airstream just in the generator compartment
I like it! So it's a matter of cutting into the genset cord and wiring it up?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-18-2012, 07:46 AM   #59
It's been a while since I started this thread when our need to replace both air conditioners surfaced. Well at the time I managed to get one of the units to work so we postponed buying anything. Fast forward to this spring and before I started dismantling the 345 I tested both of it's air conditioners and they worked great.
So, instead of buying new units I parked the 310 right next to the 345, bought a couple of 2x10's and laid them across the roofs between the two units. I then procceded to remove the front air conditioner from the 310, slide it across to the 345 and then basically just pushed it off onto the ground. I then removed the front air conditioner from the 345, slid it across on the 2x10's and installed it on the 310.
Repeated the process for the rear air conditioner and bingo, working A/C on the 310
I'm sure I only postponed the need for new units on the 310 for a year or three but that means the money can be used for higher priority items.
Old 10-18-2012, 10:09 PM   #60
Nice Job Brad!
BTW, here is a link to the Powersolutions mod.
JTB Manufacturing
Old 10-21-2012, 05:22 PM   #61
Mike Leary's Avatar
Images: 11
Nice Job Brad!
JTB Manufacturing
A dream come true! Thanks all, we old duffers can learn much from you young 'uns. Has anyone installed one in a 310?
Old 10-21-2012, 05:37 PM   #62
crazeevw's Avatar
Saint Petersburg , Florida
Raveson, keep forgetting to ask, did you install your JTB Power Solutions unit? Thinking that this will be on my Christmas 'wish-list' this year....
Thanks, Derek
Old 10-22-2012, 10:32 AM   #63
Talking about replacing AC units...
Lewster made an interesting post about a new low profile unit that will be out soon....
http://www.airforums.com/forums/f206...a-c-96770.html
Fun time, African Events, Time running out to join in PeeWee Off Topic Forum 1 08-09-2009 09:12 AM
Time to Replace Water Heater? whitelight Water Heaters, Filters & Pumps 0 09-02-2007 10:52 AM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Time involved to replace floor? RichardT Repairing/Replacing Floor &/or Frame 4 11-24-2004 02:21 PM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 09:22 PM
