Old 06-29-2010, 04:39 AM   #43
Originally Posted by pdallas View Post
Fired up the unit and after slight delay, both units produced 12 volts.
PD,
I just noticed your reference to 12 volts. Did you really mean to say 120 volts?!
Just curious
Old 07-30-2010, 03:07 PM   #44
MaryContrary's Avatar
1984 31' Airstream310
on the road , CA and OR this summer!
Images: 41
hey PDallas.... you mentioned you found a good generator mechanic in the dallas area. i'm headed that way, and would love the contact info for the shop.
i went all the way to san antonio last year for a kolhr mechanic that wasted my time and $$$
1984 310 Limited Motorhome
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
Old 07-31-2010, 04:36 PM   #45
College Station , Texas
I may have mislead. This guy is in College Station, Texas. His name is Scott Hendrickson, 979-204-5568.
There is another excellent mechanic in Colorado Springs. I believe his shop is Macks Generators. I will try to round up his number.
Hope this helps!
PD
pdallas is offline   Reply With Quote
Old 08-06-2010, 10:10 AM   #46
Images: 41
yes thank you so much
my AS Moho blog
Old 09-27-2011, 07:58 PM   #47
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Can any of the 345 owners tell me where to look for the drain tubes outside on the 345? Fired up rear A/C a couple of days ago, and sure enough, water is draining on the outside of the Airstream. Or would I just be better to drop the inside shrouds and look for the drain tube, give it a short blast of air through it to clean it out and see if that works?
Thanks, Derek
Old 09-27-2011, 09:20 PM   #48
crazeevw's Avatar
Originally Posted by kmpro View Post
PD:
Look back at the thread on my 310 where the wiring was given to do thye rear a/c. It's simple, but you end up with 2 power cords when on shore power, but that's better than cooking inside the silver bus.
Mike
Looked and looked for this thread, and so far, no luck. If possible, can you post a link?
Thanks, Derek
Old 09-28-2011, 05:29 AM   #49
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Thanks, Derek
On my 1984 both exit on the Driver side; one approximately 2 ft. behind the front wheel and the other between the rear axle tire and tag axle tire.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 09-28-2011, 06:38 AM   #50
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
The Silver Bullet front drain is behind the left front mud flap and the rear is between the tag and main axle. They're right up against the skin, so hard to see.
choctawmel is offline   Reply With Quote
Old 09-28-2011, 10:01 AM   #51
Derek..
Here is mine... Street side, hanging down close to the outter skin, between the Dually and Tag Axle...
If it was a snake....
Old 09-28-2011, 06:46 PM   #52
crazeevw's Avatar
Thanks Steve, I'll go looking tomorrow when it's daylight. Need to get camera out and start snapping away pix like you have.
See that you've got same problem as me. Missing lug nut covers. I'm also missing the hub part on my tag axle. Has anyone ever come up with a good supplier yet?
Thanks, Derek
Old 09-28-2011, 06:55 PM   #53
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Thanks, Derek
I looked, too, and I'd love to get that stern ac on to shore power and still use the gen set when boondocking.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-28-2011, 07:52 PM   #54
crazeevw's Avatar
Mike,
I'm still looking, if I find it, I'll be sure to post here.
Thanks, Derek
Old 09-28-2011, 07:56 PM   #55
Mike Leary's Avatar
Images: 11
Mike,
Thanks, Derek
Thank you, fifty amps were unknown until a few years ago, can't blame AS.
Old 09-28-2011, 09:08 PM   #56
AirRowan's Avatar
Key West , Florida
I plan on putting a switch in the generator compartment and wiring a 220v 50amp plug in or next to the generator door. I figure that if you are at a place that has 50amp service and it is hot it would be nice to run both AC units. For about $215 (50amp cord not included) one can wire up for 50 amp with out messing around in the Airstream just in the generator compartment.
Amazon.com: Furrion F52INS-SS Stainless Steel 50 Amp 125/250V Round Inlet with Square Mount: Automotive
AirRowan is offline   Reply With Quote
Fun time, African Events, Time running out to join in PeeWee Off Topic Forum 1 08-09-2009 09:12 AM
Time to Replace Water Heater? whitelight Water Heaters, Filters & Pumps 0 09-02-2007 10:52 AM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Time involved to replace floor? RichardT Repairing/Replacing Floor &/or Frame 4 11-24-2004 02:21 PM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 09:22 PM
