Old 12-07-2015, 06:02 PM   #1
1979 28' Airstream Excella 28
Boynton Beach , Florida
Thermostat housing repair parts
So since the motor home is overheating, started with a thermostat replacement first, What I can not find is what these two parts are called and what is their purpose? The first few pictures shows a sensor of some sort I believe, It was mounted to the housing of the thermostat on an bracket and connected to some wires, The other comes out second opening in the housing itself and is connected by tubing to the carburetor. Can anyone help to identify these parts? Thank you for your help.
ID:	253516   Click image for larger version
ID:	253518   Click image for larger version
Chris.barbar is offline   Reply With Quote
Old 12-07-2015, 07:02 PM   #2
Hi Chris, I know this stuff for my '84, as I have to have it all in place and functional to pass smog here in CA.
Here is the vacuum diagram that I believe to be correct for a Federal emissions 1984.
Pic #1:
That part is a vacuum switch and part of the original emissions setup.
I believe it is called the "TRC Solenoid Control Valve".
It controls or is part of the AIR injection smog pump control...
And here it is as my '84 should be...
Pic #2:
That is a coolant controlled vacuum switch.
On mine is called EFE/TVS switch.
Here it is on my setup.
I have 2 of those... on in the thermostat housing, and another on the fwd part of the cylinder head...
The other is called the "Spark/TVS switch.
Mine.
Old 12-07-2015, 07:13 PM   #3
Thank you, we do not have emissions here in Florida so I assume I can bypass replacing that part. Thank You very much, This is very helpful.
Old 12-08-2015, 01:11 AM   #4
mattpalmeris's Avatar
nanaimo , British Columbia
That solenoid is part of the throttle return control system. I know because when taking off my thermostat housing rust on the bolt hole twisted my solenoid and broke the wiring connector and vacuum hose fitting.
| Repair Guides | Gasoline Engine Emission Controls | Throttle Return Control (trc) System | AutoZone.com
mattpalmeris is offline   Reply With Quote
Old 12-08-2015, 07:06 AM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Awesome pictures of the vacuum control system.... They say a picture is worth a thousand words !
bobmiller1 is offline   Reply With Quote
Old 12-08-2015, 08:51 AM   #6
Yes, I am a visual person... More "Monkey see Monkey do".
I have weeks of research into it, with books, diagrams, and parts. It's been amazing tough to figure it out what should be there, and its not over yet. There are apparently multiple thermostatic switches with different temperature settings and finding out which one is correct is tricky!
Old 12-08-2015, 03:53 PM   #7
If I can find the part I will replace it, did you happen to purchase a new one? If so where did you get it?
Old 12-08-2015, 04:24 PM   #8
I got my "new" part from the junkyard.
Not sure where to find them new, and I have looked.
Old 12-08-2015, 08:28 PM   #9
1977 31' Sovereign
Lynnwood , Washington
All those vacuum-operated valves?? You can toss them all. They're probably not working any way. Or, you can leave them in place and by-pass them with new vacuum hoses.
BTW, I'll bet those old "vacuum harnesses" are leaking. That's probably a major part of your problem.
FYI - The only vacuum hose you really need is from carb to vacuum advance.
Tom
TomKirk is offline   Reply With Quote
Old 12-09-2015, 06:43 AM   #10
bobmiller1's Avatar
They are called Thermal Vacuum switches......Replaced "all" of the vacuum line when I rebuilt my 1989 325....was not difficult, but time consuming...thank goodness for the original vacuum wiring diagram on the side of the air cleaner ! Regards, Bob
Old 12-09-2015, 11:31 AM   #11
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Thermal Vacuum Switch-
OE No. 3043015
AC Delco No. 212-618
Available from auto parts store or Amazon.
Bethany533 is offline   Reply With Quote
Old 12-09-2015, 11:51 AM   #12
1977 31' Sovereign
.....AND.....if you've got a smog (aka, AIR) pump, you can dump that too - along with the diverter valve and that Qudra-Jet Carb. Replace it with an Edlebrock. Trust me. Your rig will thank you for it many times over.
Tom
Old 12-09-2015, 12:05 PM   #13
Bethany533's Avatar
My MH also used to overheat. I've since:
Had radiator re-cored
Replaced/installed-
New hoses
Jeg's water pump
Stewart/Robertshaw #309 195degree thermostat
Swapped mechanical fan for a Flex-a-lite 295 electric fan
So far, so good. I suspect the radiator was the culprit.
If a radiator is otherwise good, a clogged core can be "rodded out" by a radiator shop. Mine had too many pinholes and needed to have the core replaced.
Ray J.
Old 12-10-2015, 08:04 AM   #14
Thank you all!!!!! I will let you know how it goes from here on out!
Taillight housing corrosion and repair rjack General Repair Forum 1 10-22-2015 02:12 PM
Repair water filter housing? dolphin44 General Repair Forum 8 04-14-2014 07:55 PM
'69 Tail light housing...how best to repair/reinstall? 1966DDart Lights - Interior & Exterior 2 03-13-2014 06:45 AM
Tail light housing on '65 Overlander 65 overlander Lights - Interior & Exterior 5 01-20-2013 05:28 PM
Thermostat repair or bulb replace bridor15 Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2009 12:06 PM
