02-22-2018, 09:03 PM
#601
Foothill Ranch
I was, of course teasing/joking and the 370 I was referring to did sell for $5k.
02-23-2018, 07:15 AM
#602
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Must have missed that one, Steve. Thanks for not telling me about it
AIR #13
02-23-2018, 08:27 PM
#603
Foothill Ranch
It was on the for sale thread...
About page 155 I think.
$5k was the number I heard...
But you were probably out playing with your wood....
03-22-2018, 02:54 PM
#604
Airstream Driver
1994 30' Excella
Austin
Need your help guys. My Airstream Bvan shakes at 55-65 mph and I can't figure out why.
Its build on a Ford E350. This is what I have done so far:
1. Tires are new and as of a couple of month the front rotors are new as well
2. Steel rims/tires were balanced by tire company
3. I installed Centramatic wheel balancers on all 4 wheels.
4. I jacked up each wheel, and used a stationary device to check each wheel/tire combo for out of round, both on the thread and side wall.
5. I installed new U-joints front and rear, its a 1 piece driveshaft.
I have not had the driveshaft balanced
what else could it be?
AIR #13
03-22-2018, 03:44 PM
#605
Richmond
, Kentucky
Ball joints and tie rod ends come to mind but my guess is you've checked those already. What about the shocks?
Another possibility would be having the drive shaft balanced.
1975 24' Argosy Motor Home
03-22-2018, 03:54 PM
#606
1986 34.5' Airstream 345
Londonderry
, New Hampshire
1. If you feel the shaking without pressing the brake pedal then they are not at fault. I assume that you checked the wheel bearings for looseness when you did the brakes.
2. Balance is a suspect but if you just had them balanced then that should be good however the weights can get knocked off.
3. Whose wheel balancers do get good reviews here but I have my doubts.
4. Is the tread wear pattern even? Scalloping or other patterns can indicate an alignment or ball joint wear problem.
5. If the driveshaft is not damaged then it should not be your problem.
I suspect something is worn in your front end; ball joints, tie rod ends, steering stabilizer, shocks, etc. Any funny noises when this is happening? If you go about 20 MPH and swerve back and forth do you hear any clunking noises?
Hope this helps,
Pete.
03-22-2018, 03:59 PM
#607
1982 31' Airstream 310
champaign
I had similar symptoms years ago on a truck. Turned out to be the tail piece bearing on the tranny. I have no idea if that would apply to your tranny but the symptoms were the same. (I had the driveshaft balanced before I found the worn bearing.)
03-22-2018, 05:27 PM
#608
Dazed and Confused
Hillsburgh
, Ontario
It's not just you, but we need more info on how you feel the shaking; in the steering, does it feel like a constant buffeting; any increased noise associated with the shaking or buffeting?
https://www.vanning.com/threads/ubbt...ghway_vibratio
https://www.ford-trucks.com/forums/9...n-problem.html
It would seem that sidewall construction and air pressure can play a role in highway shaking. Too stiff a tire and a suspension too stiff can have the wheel go through up and down motions, even on flat tarmac; from the sounds of it, it builds up a resonance or harmonic imbalance.
Cheers
Sidekick Tony
03-22-2018, 07:52 PM
#609
Airstream Driver
1994 30' Excella
Austin
Thanks for all the replies!
Shocks are new, ball joints are good, front end is good, hardly any steering play. Its positively not caused by front end issues.
No unusual tire wear.
Best way to describe it would be its coming from the center behind me.
One of my first Motorhomes had a worn out yoke at the transmission that caused a wobble at a certain speed. I checked everything at the rear of the trans, all seemed fine, no leaking oil. Mike, your bearing scenario sounds interesting, i wonder what it takes to get to it? Does the third member have a bearing as well?
AIR #13
03-23-2018, 05:47 AM
#610
Airstream Driver
1994 30' Excella
Austin
This is the harmonic balancer mounted behind the trans. It showed no obvious wear or problems.Could it be the culprit?
AIR #13
03-23-2018, 07:06 AM
#611
Gunter
1966 24' Tradewind
Greenville
, Ohio
One other item to check are weak or broken motor mounts.
Gunter
2000 Land Yacht XL 355
03-23-2018, 03:50 PM
#612
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield
, Massachusetts
Somewhere on the forum, someone once described "universal joints" being installed "out of phase".
I forget the specifics, but maybe a possibility since "new" were recently installed??
03-23-2018, 04:01 PM
#613
Dazed and Confused
Hillsburgh
, Ontario
Very possible:
https://www.machineservice.com/techn...tional-issues/
Cheers
Sidekick Tony
03-23-2018, 07:17 PM
#614
Airstream Driver
1994 30' Excella
Austin
Yes, except the symptoms were identical after the new U-joints were installed.
Nice article, Tony, I am working on getting the driveshaft checked out soon.
AIR #13
03-28-2018, 05:27 PM
#615
Airstream Driver
1994 30' Excella
Austin
And the winner is:
The driveshaft was out of balance.
Brad you won a 1974 20' Argosy MH in need of a complete resto.
AIR #13
03-28-2018, 07:24 PM
#616
Richmond
, Kentucky
And the winner is:
Dang, if I'd known what the prize was I'd have kept my mouth shut
One 74 is more than enough for me
So is your vibration issue gone completely?
03-28-2018, 07:47 PM
#617
Airstream Driver
1994 30' Excella
Austin
for a 1996 Ford E350, yes, its gone. The place i brought it, also discovered a wobble in 2 wheels, despite my best effort to check it. So I will replacing those.
For those local to Austin or some of the locations in the midwest, the place is called Inland Truck Parts & Service and they mostly work on big rigs. They helped me out before and do a straight business.
https://www.inlandtruck.com/locations/
AIR #13
04-18-2018, 06:34 PM
#618
Airstream Driver
1994 30' Excella
Austin
Whilst some of you are contemplating the rescue of some Argosy in the Kentucky mountains and others eyeballing a 350 for their next restoration project, I am using my Airstream fleet to work on historical homes in the great state of Texas.
Now, if the right 300LE comes a long I may be very interested until then I continue using my talents on creating ceilings like these:
AIR #13
04-18-2018, 07:14 PM
#619
Dazed and Confused
Hillsburgh
, Ontario
Now if only you could put that ceiling into an Airstream......
As for Argosy's........I tried, but no dice, (even the DW was onboard. )
Cheers
Sidekick Tony
04-18-2018, 10:03 PM
#620
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Do you think that would look good in the 370LE ???
