Old 08-09-2015, 08:57 AM   #113
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Peter, if you use copper line instead of the plastic hose, it will help cool the air before getting to the tank. It is not hard to bend. You can use side of a plastic soda bottle or paint can...to help keep a nice arc.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2015, 04:45 PM   #114
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Got the system all tight now, even got a removable pressure gauge.
Got my seat cushions back from the upholstery shop (thanks, Channing for the referral, they do excellent work). This completes my custom dinette.
ID:	245069   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-16-2015, 11:15 AM   #115
Airstream Driver
1997 30' Excella
Images: 51
Woody
Never been too fond of the wood decal and even less once it starts peeling.
If the surround decal is still in good shape, here is a fairly simple way to deal with it, without going through all the stripping mess:
To remove the top layer, use white masking tape 1 1/2 or 2 inch, the cheaper the better, since the cheaper stuff sticks even more. Use a sharp razor for some of the stubborn stuff. Works very fast and its very clean. It did those 2 sections in about 2 hours, removing the top layer and installing new decal.
Then just decorate the center to your hearts desire.
ID:	245601   Click image for larger version
1996 Airstream B190
AIR #13
Old 08-16-2015, 11:50 AM   #116
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I like the look Peter. Ive conteplated doing something along those lines at some point. Mine is still in pretty good shape so no hurry. What is the new decal all about? What material, how is it applied, where did you purchase(what kind of vendor, local, on line, what type of business)? Did you apply the new decal,yourself? Id like to start some research but not sure what the options are. I have assumed a sign shop or a vinyl wrap business. Does a decal like that come in standard widths? Thank you for anything you might want to share. Yours really looks nice, good choice I think. Really goes well with the part you left in place and with the aluminum shell. There might be some negotiations with the wife on this one..........she has grown to really like the classic look of the wood grain. Me....Im not so sure, especially as ours starts to deteriorate more. The worst part on ous is the black and silver stripe along the front "hood". Its faded bad. Man it would look sooooo great to replace all the striping and the little rubber/vinyl insert all the way around.
Mike
mayco is offline   Reply With Quote
Old 08-16-2015, 02:02 PM   #117
Airstream Driver
1997 30' Excella
Images: 51
Mike,
I did put in new rub rail, cost for the small dark gray and the wide black was right at $215.-
The decal I using is part of my inventory I have from rebuilding Airstreams for 20 years. Some you can only buy in 150' rolls, so have a many partial rolls.
I do install it myself. Main thing is not to worry about small air bubbles, since they will evaporate in a few weeks.
Ebay is the a good source for any type of decals, my suggestion is not to buy the cheapest. Quality varies a lot and you want something that will last a few years.
for example check these:
TRACKER MARINE 103790 SILVER CLEAR CHARCOAL 1 3 4 INCH BOAT PINSTRIPE TAPE | eBay
1996 Airstream B190
AIR #13
Old 08-16-2015, 02:09 PM   #118
mayco's Avatar
Ahhhhhhh, didnt know you had been at it so long! Should have after reading your posts. Thanks for the link Ill check it out
Old 08-22-2015, 07:15 PM   #119
Airstream Driver
1997 30' Excella
Images: 51
The Bath window and the rear emergency exit window use a different type of gasket. I had a hard time figuring out, how to remove the bath window. There are 2 screws on the bottom of one of the brackets, but they are frozen solid. So I found the easiest would be to drill out the rivets of the bracket that is attached to the window.
The gasket material is available from inland RV as part number 45370 and you will need 20' for the bath and rear window. I use the black weatherstripping Adhesive from 3M for these types of gaskets. Its inland Rv part number 51991
1996 Airstream B190
AIR #13
Old 08-23-2015, 06:35 AM   #120
Peter's been at this long enough he can do the repairs in his sleep...
Old 08-27-2015, 05:43 PM   #121
Airstream Driver
1997 30' Excella
Images: 51
Airstream Root canal
so the fun started. Center panel is out without pulling the window.
ID:	246480   Click image for larger version
1996 Airstream B190
AIR #13
Old 08-27-2015, 07:17 PM   #122
Airstream Driver
1997 30' Excella
Images: 51
hidden rivets
We all have heard that the interior of Airstreams were built from the rear forward. So were the panels. I suppose one guy just went around with a pop rivet gun and attached the panels and then buck rivet guys came.
It takes a little bit of prying to get the panels loose from those hidden rivets. I marked the location, so I can clean the remnants later or else they will really mess with me trying to slip the new panels in.
No window and only the main awning hold down bracket have been removed to get the rear three panels out
ID:	246491   Click image for larger version
Name:	hidden rivets.jpg
1996 Airstream B190
AIR #13
Old 08-27-2015, 07:32 PM   #123
Airstream Driver
1997 30' Excella
Images: 51
Here is the astonishing part:
I have not found any sealant. They must have run out of Vulkem the day they put this 310 together. Its actually a lot easier for me to not have to deal with the vulkem, but these windows were leaking badly, so were some of the seams.
If you can't stand Olympic rivets and only believe that buck rivets should be used, please don't read any further, because I don't want to tick you off.
I know that my installation using Olympic Rivets and Vulkem 116 will outlast any of these buck rivet factory jobs I am finding. If you do all your drilling and clean the grease of the panels prior to installing new panels with vulkem 116 and Olympic Rivets, you will have a water tight rig that will last many years.
Look at this seam, no sealant, zero, nada
1996 Airstream B190
AIR #13
Old 08-28-2015, 08:42 AM   #124
Peter,
Now you've got me wondering about the 1986 345 that I dismantled a few years ago. I don't recall looking closely at the seams because when I cut the shell up I just used a sawzall to cut it into smaller chunks. I've got a few sections left sitting beside my shop. I'll take a closer look to see if any sealant was used on those seams.
I know Shepherd57 dismantled an Argosy and he indicated there was no sealant used between the seams. There is a product called Acryl-R that is applied externally to the seams that will wick in and seal. I actually have some of it on the shelf and used some around the back seams and it seemed to help. I think typically it needs to be applied multiple times before a seam is totally sealed.
I do plan on applying Acryl-R to all the seams on my Argosy before it gets painted.
Old 08-28-2015, 12:59 PM   #125
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by bkahler View Post
Peter,
If I would have access to the interior walls, I would use Vulkem116 on all the seams, rivets and windows. Actually any window I ever removed had lots of Vulkem applied from the inside. Thats why they are so damn hard to remove.
1996 Airstream B190
AIR #13
Old 08-28-2015, 04:51 PM   #126
Airstream Driver
1997 30' Excella
Images: 51
I forgot to make clear which panels I am replacing
1996 Airstream B190
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
