Old 07-29-2015, 08:31 PM   #99
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My new viair pulls up to 29amps, the model you had mentioned is similar
I believe. I think the safest and most reliable method to wire that compressor is with your ignition wire activating the relay only and then a heavy gauge wire direct to the battery with inline fuse or breaker of appropriate size. Airstream used a very small oem compressor and ran a #12 wire from the ignition all the way back to power it. No bueno.
mayco is offline   Reply With Quote
Old 07-29-2015, 09:52 PM   #100
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Here is the page from my Airstream manual and you can see the air bags, a/c heater and wipers are 20 & 25 amp fuses through the ignition switch.
Name:	Fuse block #1.jpg
And yes I run my compressor from the battery through a relay triggered by the yellow wire from the fuse box.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 07-30-2015, 05:01 AM   #101
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Rivet The collective knowledge is impressive
Thanks everyone and thank you Dan for posting the fuse block layout.
The chassis on my 83 is an 82, but the Coach appears to be a very late 83 according to the Airstream vin. It has the later model dash, aluminum rims, powerseats and even some oak upper cabinets in the rear that were not used until 84 as far as I know.
By then they may have realized the weakness of the spade type fuse protected compressor circuit and installed a circuit breaker fuse.
I will follow every ones recommendation and only use that existing circuit for the relay and run a #8 from the chassis Bat to small 12v distribution block in the rear.
onward through the fog...
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-30-2015, 07:32 PM   #102
Airstream Driver
1997 30' Excella
Images: 51
Digging deeper
Originally Posted by mayco View Post
Is your tank still in place or are you going to have to install a new tank also? Not sure if you know or not but the oem set up had 2 air lines from the tank to the compressor set up. One line was supply from the compressor to the tank and the other line was from the tank to the pressure switch.........
Mike
Yes, Tank is in place, but what a mess someone made
Instead of a drain valve on the bottom, its been used for the manual supply line. Tank is prob half full of water.
One side of the T on top goes to the air bags the other side goes to ...drum roll....back into the tank via the original compressor input fitting
check out the plumbing on that fitting.
who sells hose and different fittings? home depot ?
ID:	244297   Click image for larger version
1996 Airstream B190
AIR #13
Old 07-31-2015, 04:44 AM   #103
Now that's ugly
Some PO did the same thing to the bottom of the tank on the 310. I thought that was rather odd since there was a quick connect in the electrical compartment that could have been used just as easily.
Old 07-31-2015, 05:22 AM   #104
mayco's Avatar
I havent tried these but was tempted when I was redoing my compressor system.
Plastic Push-To-Connect Tube Fittings | MSCDirect.com
Or,
http://www.summitracing.com/search/p...-hose-fittings
Or,
Pneumatic Fittings and Couplings - Pneumatics - Grainger Industrial Supply
I had a difficult time finding proper tube fittings locally. Our "Do it Best" had some fittings but limited selection.
Mike
Old 07-31-2015, 05:59 AM   #105
After reviewing the installation that I did on the 310 for the compressor wiring upgrade I realized that I didn't run a wire from the coach batteries to the compressor I ran the wire from the generator compartment to the compressor.
I used a #10 wire connected to the starter solenoid of the generator and ran it across the chassis to the compressor. For some reason I didn't fuse the #10 wire so I will be doing that this weekend. Not sure how I missed adding a fuse inline
Old 07-31-2015, 12:15 PM   #106
Mike try a truck parts supply house. They have lots of tubing stuff for air suspension and air brake systems. The push on fittings are just an air version of a Shark bite fitting.
Cheers, Dan
Old 08-01-2015, 07:01 AM   #107
Airstream Driver
1997 30' Excella
Images: 51
I may be overthinking this:
Would it not be better to let the ignition power first go to pressure switch, which then will power the relay to open the new bat circuit for the compressor?
Otherwise the relay would get a lot more use and would be energized at all times.
1996 Airstream B190
AIR #13
Old 08-01-2015, 07:45 AM   #108
mayco's Avatar
Yes, if you use a separate pressure switch and relay. You power the pressure switch and it triggers the relay. If you run power direct from the battery, one side of the relay is hot all the time, when the pressure sw calls for air it will trigger the relay to close and contact is made sending the batttery power to the compressor. Another reason I like the pressure switch/relay combo from viair. Very simple to wire, compact design, sealed unit so resists moisture.
Mike
Old 08-01-2015, 07:47 AM   #109
mayco's Avatar
Viair 85 105 PSI Pressure Switch Relay Combo Train Horns Load Support | eBay
Old 08-01-2015, 09:20 AM   #110
The only extra use it would get is if you have a slow leak. The compressor would run periodically to keep the suspension up.
With that said, Airstream powered the compressor from the ignition circuit on most rigs. Not sure why yours went to that particular circuit breaker as I think that one has power all the time.
Personally I prefer to power the relay or pressure switch (doesn't matter which) from the ignition circuit and the N.O. contact gets power from either the chassis or coach battery which then feeds the compressor.
Old 08-01-2015, 09:30 AM   #111
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by bkahler View Post
... Not sure why yours went to that particular circuit breaker as I think that one has power all the time...
Haven't had time to trace that orange wire feeding the circuit breaker, but it only gets power with the ignition on.
1996 Airstream B190
AIR #13
Old 08-08-2015, 08:55 PM   #112
Airstream Driver
1997 30' Excella
Images: 51
Finally got all the parts together to complete the compressor install. I found compression fittings and air line at Home Depot and they work great.
The only problem I had with the fittings was at the compressor. The braided compression line ViAir supplied was not long enough to go from the Tank to the mount location and I made the mistake to use it on the tank side and add plastic line to the compressor. At 90 pounds the hose will just blow off, because of all the heat generated close to the fitting. I will have to reverse that tomorrow or find a longer hose.
ID:	244975   Click image for larger version
1996 Airstream B190
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
