Old 09-10-2016, 01:48 PM   #463
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
He Peter,
it "calms me down", as i see, there is something in an Airstream you DO NOT KNOW imediately...!
Hat off, you fid it final !
Our Generatort runs, but it "s "stinking rich", my neighbours "hate's" me often...
I am converting Bangles to LPG soon, also the generator will be converted to Propane. ("Nash-fuel").
I did, what i could do with the generator, there is ONE (!!!) Onan service here, about 200km away, allways "overloaded"....!
Keep on, my friend!!!
Roquefort is offline   Reply With Quote
Old 09-11-2016, 09:20 PM   #464
chriscraw's Avatar
1991 35' Airstream 350
Peter...just to say Carmen and have enjoyed the Airstream at the Johnson City Ranch right through the hottest days this summer with both air-conditioners working at full speed thanks to your re-engineering skills wiring-up both units!!
We'll be there weekends through October if you and Cindy feel like a drive into the Hill Country...just let me know.
Again our thanks
chriscraw is online now   Reply With Quote
Old 09-29-2016, 05:54 PM   #465
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
As i mentioned in another thread, the rebuilt Jasper Trans I had installed had a leak. Jasper wanted me to bring it back to the original installer, which I declined. They send me a gasket Kit and I replaced the Governor cover gasket myself and it still leaked.
After talking to Jasper again, they were ready to swap the trans out , but again only by the original installer or I would have to pay part of the labor.
Since the leak was right at one of the cover bolts, I asked the tech if those threads went all the way through. They were 99% sure , that they did not.
So, I took it onto myself and removed the cover again (so happy I have a pan drain bolt on that derale deep pan) and checked the threads. Bingo the lower 2 went all the way through and even with sealant on thread the bolts used would not seal it properly.
So I cleaned it all up and replaced the 4 bolts with oil pan type bolts that now I have a leak free cover.
ID:	272587   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-29-2016, 07:08 PM   #466
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Great success story, Jasper is probably the best rebuilding company around, their quality control is second to none...I'm happy to see you took the bull by the horns and did it yourself ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 09-30-2016, 04:58 AM   #467
Airstream Driver
1997 30' Excella
Images: 51
Thanks, Bob! After my first attempt failed, it became personal and I wanted to find the cause.
Jasper is an employee owned company that takes pride in their work and they even reimbursed me for some labor expenses.
On a different note, who knows what this "thing" is? It is located mid ship behind the trans and protrudes through the floor?
1996 Airstream B190
AIR #13
Old 09-30-2016, 05:52 AM   #468
bobmiller1's Avatar
Looks like it might be the pocket for the removable table leg....if you have a removable table that is....however it might be a better question to ask what is above it ??? Regards, Bob
Old 09-30-2016, 05:55 AM   #469
bobmiller1's Avatar
Yes, now that I magnified the picture I can see the rivets for the re-enforcing plate to hold the table leg. Regards, Bob
Old 09-30-2016, 03:37 PM   #470
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hey Peter,
Somewhere I read that you recommend adding a supplementary latch to the generator compartment door. I cant find the thread. I think you had said a latch from Zip Dee? Would you mind repeating that for me?
Mike
mayco is online now   Reply With Quote
Old 09-30-2016, 04:31 PM   #471
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by mayco View Post
Hey Peter,
Mike
Mike, that only does apply to the 78-81 (some of them) model with a single latch and removable generator door. The 310 have the stationary flip down with 2 latches.
Here is a picture of the latch I used on the 79 model
1996 Airstream B190
AIR #13
Old 09-30-2016, 04:34 PM   #472
Airstream Driver
1997 30' Excella
Images: 51
Bob, that makes sense, finally I can sleep again..
If there was a table at some point, it's long gone and wood flooring was installed over it.
1996 Airstream B190
AIR #13
Old 10-01-2016, 09:11 AM   #473
mayco's Avatar
Actually Peter my 82 310 has the single latch centered at the top of the door like the one in your picture with the removable door, two spring loaded pulls at each bottom corner of the door. So I think your solution will apply to mine and I like it! Been working on my generator and your post kept popping up in my brain. Lord dont want to potentially lose the door. Soooo, I like the looks of what youve done there. What is that latch called on Zip Dee's parts list, do you recall off hand? Im going to do SOMETHING to supplement the single latch at the top. Im sure there a number of latch solutions but I like yours.
Thanks Peter, (as always there Peter)
Mike
Old 10-01-2016, 09:15 AM   #474
mayco's Avatar
Here is mine Peter
Name:	ImageUploadedByAirstream Forums1475334896.956250.jpg
Name:	ImageUploadedByAirstream Forums1475334917.249042.jpg
Thanks again
Old 10-01-2016, 11:40 AM   #475
Airstream Driver
1997 30' Excella
Images: 51
Mike
Ha, Mike, so they used the single door into the 80's and even on the 310. Got to deplete that inventory...
Here is one link to the "hook" (zipdee awning travel latch)
I think I ground the loop off, so I can be used on left or right side
What P..d me off on mine that it would unlock turning it to the right, so when I went around to check all the locks, I unlocked it
http://woodlandtravelcenter.net/prod...-travel-latch/
1996 Airstream B190
AIR #13
Old 10-01-2016, 12:20 PM   #476
mayco's Avatar
"Travel Latch".... Ok Peter, thanks so much. Im gonna get a couple, I think its a worthy little investment as youve noted before.
Adios and thanks again,
Mike
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
