01-06-2019, 02:37 PM
#641
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by Boom Sounds
Peter - I like the flooring. I need to do similar this year. I planned to use 'luxury vinyl plank'. When you say yours is floating, what did you use as the subfloor? Over here, I think we just the get plank e.g. Karndean which is about 3-4mm thick (I think). I had planned to just glue that straight to the floor of the Airstream, but I would like to better understand the options/your approach, which sounds better.
many thanks
Nick
Nick,
Try to find some LVP that is 8 mm thick (measured without the already attached backing on some products). If there is no attached backing, you would use very dense foam, they sell along with it.
I can't imagine using 4 mm, since I used 6mil before and did not like its performance. They snap into each other, like Pergo style flooring.
They say leave a little space on the edges for expansion, but that applies to bigger rooms and not narrow hallways, like in an Airstream.
AIR #13
01-07-2019, 04:11 PM
#642
1984 27' Airstream 270
West Chester
, Ohio
Since our floors are not insulated, have you any thoughts regarding an underlayment/pad that would help with the cold floor in winter? I am leaning toward LVP as well but since I’m currently replacing subfloor due to water damage, I’m hesitant to use a material that would trap moisture.
Regarding insulating the floor, has anybody tried insulating material to the undercarriage of the Moho? I’m thinking aluminum faced polystyrene glued and screwed onto the belly pan
01-07-2019, 07:26 PM
#643
Airstream Driver
1994 30' Excella
Austin
The material attached to the LVP is padding and not really meant to insulate the flooring. Could it trap moisture if the floor is totally sealed, sure. But I would never seal the floor of an Airstrean trailer or motorhome. I would want it to breeze and absorb/transfer moisture if needed. Mold and mildew happen if moisture can not escape.
AIR #13
01-07-2019, 08:01 PM
#644
Churubusco
, Indiana
I have enough mineral wool on hand with a plan to do just that. I haven't gotten around to it, been a mild winter, had other priorities.
Aluminum faced poly would be way easier (and cheaper) than the semi flexible mineral wool, but it's flammable. Not what I want 2" from my exhaust with 70 mph winds whipping by.
01-09-2019, 06:56 AM
#645
West Chester
, Ohio
Flammability...good point. The mineral wool board looks like a better product if adding under the vehicle between frame outriggers. To do my entire floor space would add about 200 pounds and cost appx $500. Any thoughts about insulating layer above the subfloor? Wouldn’t want anything too thick or heavy. My front runner is Pergo Gold floor underlayment.
01-10-2019, 05:33 AM
#646
Churubusco
, Indiana
Going up from the subfloor poses challenges
When you go down, it's currently mostly wasted space, and you get an easy 2" of it
Going up from the subfloor requires redoing the whole floor, and you wouldn't want to go to thick, but I'm sure it's doable. Even the little padding under carpet was way warmer last winter than my current uninsulated vinyl floor.
If you plan to replace your furnace, do it while the floor is out! Once you install an extra-thick floor, you'll have to mess with the cabinets in order to service the furnace, because it won't slide out anymore
1983 Airstream 310 Class A Motorhome
-Rob
11-04-2019, 02:00 PM
#647
Airstream Driver
1994 30' Excella
Austin
continuing this from another thread ( 1992 350LE questions):
Originally Posted by bkahler
Is this a inspect and buy and drive trip or have you already inspected and just buying and driving?
been working on it for a while. It will be a jump in the cold water...
Here is something rather curious, 4l80e with gear vendors. i would like to hear some opinions about :
AIR #13
11-04-2019, 06:32 PM
#648
Richmond
, Kentucky
Hmm, what's with the dual range? I thought the gear vendors was just a bolt on overdrive to reduce the rpms.
If that thing let's you increase or decrease the rpms and can be combined with the 4L80e od then you could probably climb the Himalaya's!
1975 24' Argosy Motor Home
11-04-2019, 06:40 PM
#649
1982 28' Airstream 280
Port Angeles
That looks like a US Gear set up. They are out of business but the units live on. I believe they were available as either an underdrive or an overdrive unit.
Cheers, Dan
~ Margaret Thatcher ~
11-06-2019, 09:52 AM
#650
Richmond
, Kentucky
The picture seems to indicate it has over AND under drive. Was the US Gear setup based on Laycock components?
11-06-2019, 10:20 AM
#651
Port Angeles
I think it was a sliding gear type of trans rather than a planetary gear with cone clutch like the Laycock/Gear Venders. Don't quote me on that as this is really hurting my old brain.
Cheers, Dan
11-06-2019, 10:46 AM
#652
Airstream Driver
1994 30' Excella
Austin
found this :
The U.S. Gear Dual Range is the only American-made, electric-operated auxiliary transmission in the industry. It has the heaviest GVCW rating (35,000#) and is the only auxiliary transmission available as either overdrive or underdrive.
AIR #13
11-06-2019, 11:16 AM
#653
Airstream Driver
1994 30' Excella
Austin
AIR #13
11-06-2019, 04:34 PM
#654
Airstream Driver
1994 30' Excella
Austin
a picture of a US Gear
AIR #13
11-06-2019, 07:38 PM
#655
Airstream Driver
1994 30' Excella
Austin
Brad, it is an Over/under drive unit. I found the ratios:
AIR #13
11-07-2019, 08:15 AM
#656
Richmond
, Kentucky
Wow, that sounds like the cat's meow! Nothing like having a bunch of extra gears to play with.
Of course you live in Texas where it's flat so you probably won't even use it......
11-07-2019, 01:30 PM
#657
Airstream Driver
1994 30' Excella
Austin
Flat? View out of the window of my current place of work (Austin skyline in the distance).
AIR #13
11-07-2019, 01:32 PM
#658
Richmond
, Kentucky
Are you sure you're in Texas?!
11-07-2019, 01:51 PM
#659
Airstream Driver
1994 30' Excella
Austin
Last I checked, yes! Austin is right at the edge of the Texas Hill country, plenty of steep grades to try all kind of gears. I drive over this bridge almost daily, pretty flat, huh?
AIR #13
11-19-2019, 07:59 AM
#660
Dazed and Confused
Hillsburgh
, Ontario
I have a US Gear in my rig; unfortunately it's just an underdrive. Just make sure when switching ranges that you preload the unit; apply power, hit the switch to the range you want, then let off the gas to allow the unit to complete the transfer. Changing ranges with unit unloaded will damage it.
My unit is also lubricated by the engine oil system, so no oil changes to the unit itself.
US Gear is still in business, but no longer manufactures under/overdriven; they make toad braking systems.
A lot tougher than a Gear Vendors.
Cheers
Sidekick Tony
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
