Old 03-19-2016, 10:59 AM   #421
Originally Posted by bkahler View Post
Did it say somewhere in your instructions that you can't electrically reverse the fan?
I don't think mine came with any such info and I know I've reversed the direction on other fans that I've purchased. A little googling indicated that some fans can be electrically reversed and others can't.
I'll have to see if the ones I put on the Argosy are reversible. I'll let you know...
Peter, yesterday after powering up my test stand I found that the fans were blowing away from the radiator. I swapped the + and - connections and the fans started blowing air through the radiator. I guess I got lucky with mine.
Old 03-19-2016, 01:42 PM   #422
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
1991 35' Airstream 350
Images: 51
Yes, indeed, you are a lucky dog.
But do you think the air volume was the same blowing the other way? When I reversed the blades on mine, I would only get a slight breeze...
Did you fire up your engine, too and i missed it? Please tell me that is not so.
1991 350LE
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-19-2016, 03:07 PM   #423
Check out post 75
I reversed the wires right after shutting the engine down then turned the fans on. I believe I had a pretty good volume of air flowing through the radiator with the fans blowing towards the engine. The air was hot and I watched the temperature on the gauge start to drop. I might play with swapping the fan blades just to see what kind of flow I get. Can't hurt to try.
Old 03-20-2016, 09:22 AM   #424
Airstream Driver
1997 30' Excella
Images: 51
When I am not tearing Airstreams apart, I still take my passion to my daily job in a much different way.
This Library needed some "magic" and we know that silver often does the trick. Here is the before, note all the different type of woods
3 month later, a "secret" formula to darken the wood and make it look like aged Ebony, thousands of small silver strips to gild all the highlights
and you have a one of a kind library
with a matching wallcovering to highlight the inside of the bookshelves
ok, back to the 310 and the 30' Excella
1991 350LE
1996 Airstream B190
AIR #13
Old 03-21-2016, 05:54 AM   #425
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A true master of all trades and jack of none.
Salute
Tony
Old 03-21-2016, 06:59 AM   #426
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Looks awesome Peter. I recently did a basement room with my limited skills, took a sad concrete walled room and painted the ceiling tiles black, left the white grid.
Repainted the walls a nice earth tone. Polished the concrete floor and added repurposed planks from pallets to 1 and a part of another wall. Built a bar to match. The pic is of the smaller wall with pallet wood..and a pool cue rack to match
Looks so much better now..fun project that took me a week. Retirement is awesome.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 03-21-2016, 08:24 PM   #427
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Really cool Peter!
Gregsch is offline   Reply With Quote
Old 03-21-2016, 09:46 PM   #428
Airstream Driver
1997 30' Excella
Images: 51
Alan,
Wouldn't know about the retirement thingy , but you sure use your time well. Nice little pad down there in the basement. Now I know to stop by next time I am in the neighborhood.
1991 350LE
1996 Airstream B190
AIR #13
Old 03-22-2016, 07:07 AM   #429
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you better! We have lots of room and you can even hook up your trailer or whatever you bring ...I actually am working full time for a few months, but I have enjoyed my time a lot.
Life is still good.
1966 Overlander
AIR #005
Old 03-25-2016, 07:15 PM   #430
Airstream Driver
1997 30' Excella
Images: 51
Just about to finish the interior of my most recent "project", the 1997 30 Excella trailer, I bought AS IS.... This was a lot of work, all new plumbing, new flooring and fresh upholstery and blue leather accents.
To take the bathroom cabinet apart is a major job and even bigger to put it back together. I stayed with the original decor, just made it like its new from the showroom (or better ). Lot's of room in these wide bodies.
The 310 has been patiently watching and is ready and eager for our first spring campout in a couple of weeks.
ID:	259366   Click image for larger version
1991 350LE
1996 Airstream B190
AIR #13
Old 03-26-2016, 07:03 AM   #431
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
as usual fine work there Peter. Those are nice models, heavy as heck though.
1966 Overlander
AIR #005
Old 03-26-2016, 10:35 AM   #432
Looks good Peter
I'm sure the 310 missed you....
Old 03-27-2016, 01:05 PM   #433
Dazed and Confused
Isuzusweet's Avatar
John and I are jealous as we had a Colorado low go through our area leaving almost 3/4" of ice on everything, including "The Mistress". A bunch of limbs down, including a number of trees down; lost power for a number of hours and internet/cable for days. It could be worst as our friends power is not back on yet after five days.=== No work done on our projects.
Good work Peter.
Cheers
Tony
Old 03-27-2016, 02:40 PM   #434
Good work Peter.
Cheers
Tony
Hmm...I just finished 2-1/2 hours of mowing. I'm not sure whether I would prefer the ice or the constant mowing
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
