Old 12-23-2015, 09:03 PM   #337
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Had to add a switch to kill power to the unit, since I am not wiring it through the ignition. Just pushing the off button turns the unit off but it stays warm and causes the fan to run.
Still cleaning up wires and messes. I found these 4 wires connected to the rear 4 speakers, which I separated. Any clue what they could have been for ?
its the red,white,light blue and light green ones
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-24-2015, 06:50 AM   #338
Peter, I'm a little confused now. I thought you had the rear speakers working. If so how could these 4 wires also becoming from the speakers?
Old 12-24-2015, 06:53 AM   #339
Airstream Driver
1997 30' Excella
Images: 51
I separated the rear 4 speakers and at the same time found these 4 additional wires to be connected to that circuit
These additional wires do not power any of the rear speakers.
I could imagine that they were at some time external speaker connections ??
1996 Airstream B190
AIR #13
Old 12-24-2015, 07:16 AM   #340
Have you looked in your owners manual. I seem to remember the manual had extensive wiring diagrams for the sound system which surprised me since they seemed to leave out all sorts of other more important information!
I'll browse through the 84 310 manual that I have and see if it has what I remember.
Old 12-24-2015, 08:33 AM   #341
Peter, this is what I was able to find in the 310 service manual for the Sony installation. Note the comments on the second page.
ID:	254528Click image for larger version
Old 12-24-2015, 08:35 AM   #342
Peter, I keep forgetting to ask. Did you figure out a way to support the back end of the radio?
If not I have an idea that might help.
Old 12-24-2015, 09:43 AM   #343
Airstream Driver
1997 30' Excella
Images: 51
Attachment 254528Attachment 254527
Thanks for the diagram, Brad.
The issue with connecting speakers together as they did in the factory is that it changes the OHM. The new system requires 4 ohms only. That's why I went through the trouble to separate them deep under the dash.
1996 Airstream B190
AIR #13
Old 12-24-2015, 10:10 AM   #344
Yeah I understood why you were re-wiring. I was hoping the documents might shed light on the wiring coming from the rear speakers that you were asking about.
I haven't sorted the speaker wiring on my Argosy as yet so that ought to be an interesting challenge
Old 12-24-2015, 12:01 PM   #345
Airstream Driver
1997 30' Excella
Images: 51
Yes I did. Since i am keeping the Sony amp above and its fastened with a strong bracket to the dash, I can tie the 2 together, I think. Lots and lots of wires to have to deal with and the Jensen wants good ventilation.
1996 Airstream B190
AIR #13
Old 12-24-2015, 02:42 PM   #346
Good idea. I won't have that option on my Argosy but I think I've got a solution that will work.
Glad the radio is working out
Merry Christmas!
Old 12-24-2015, 03:13 PM   #347
Peter, when you have an opportunity would you mind snapping a couple of pictures giving a side view of the radio when the screen is retracted and also when the screen is up and in position. I'd like to see how much room is behind the screen when its extended (open). The dash top on my Argosy sticks out past the aluminum extrusion some so I'd like to see what kind of interference I might have.
Thanks!
Old 12-24-2015, 04:21 PM   #348
Airstream Driver
1997 30' Excella
Images: 51
Thanks!
Yes, Brad, happy to do so once I install it for real. Keep on finding stuff I have to do, like these Flexible Air hoses waiting to short stuff out. I also have to wire all the way to back for the camera and "whilst" I was doing that I ran another wire for a compressor light on the dash. At least I will know when the compressor is running continuously.
Just thought about your dash issue. You could always pivot the radio a little when you install the first bracket.
1996 Airstream B190
AIR #13
Old 12-24-2015, 05:02 PM   #349
Wow, that hose is badley deteriorated, I don't think I've seen one that bad before.
Have you bought your rear view camera already? If so what did you get?
Thanks!
Old 12-25-2015, 08:27 AM   #350
Airstream Driver
1997 30' Excella
Images: 51
Thanks!
No, didn't decide on the camera yet, just did the pre wiring
I must be easy to get Christmas presents for me (Airstream Motorhomes were the only way to go after VW micro busses)
1996 Airstream B190
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
