Old 12-18-2015, 04:34 PM   #267
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by bkahler View Post
What are your future plans?
Actually, I need to reward myself and see if I find a good radio/Gps/Cd that fits in my dash. I am pretty beat up from the last 2 days. I just finished replacing the front brake pads and the rattle is gone. More on that in my next post.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 12-18-2015, 04:43 PM   #268
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by PeterH-Airstreamer View Post
Now that I have eliminated some of the front rattle, I am wondering if there are better fitting front brake pads. I always use the blue disk quiet when installing the pads, but they don't always seem to fit tight.
Is the caliper worn or are their higher quality, better fitting pads?
Listen to this short video to hear and see the front pad rattle I am talking about
1996 Airstream B190
AIR #13
Old 12-18-2015, 04:47 PM   #269
Airstream Driver
1997 30' Excella
Images: 51
I replaced the old pads (which were fairly new) with these and they fit much tighter. No more rattle
ID:	254084   Click image for larger version
1996 Airstream B190
AIR #13
Old 12-18-2015, 04:49 PM   #270
Peter, I've been looking at a unit like this to fit in the dash of my Argosy.
Single Din GPS radio
I have a 2-din Android radio similar to this that I really like. I also have a 2-din Windows CE radio that I hate! As far as reliability and easy of use the Android unit beats the Windows CE unit hands down.
The single din radios have a pull out screen that handles the GPS and videos and if you install a rear view camera it can display the camera feed.
This particular radio does not include the actual GPS software such as IGO but has the GPS system built in. You need to purchase IGO software separately. There are plenty of other models to chose from that do have the IGO software pre-installed. I just linked to this one as an example of what's available.
As a disclaimer I have not purchased one of the pull out screen radios before so I can't vouch for reliability but I do plan on using one in mine.
Old 12-18-2015, 04:51 PM   #271
Quite a rattle! I'll have to check out the ones on my Argosy once I actually install them
Old 12-18-2015, 05:32 PM   #272
Airstream Driver
1997 30' Excella
Images: 51
and the new pads (yes the sound is on!)
1996 Airstream B190
AIR #13
Old 12-18-2015, 05:36 PM   #273
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Peter
Are the rear pads the same as the front pads
shepherd57 is offline   Reply With Quote
Old 12-18-2015, 06:17 PM   #274
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by shepherd57 View Post
Peter
Good question, John. I tried to verify it but it just says Front. If you go to other sites like rockauto.com , the front pad always say rear as well
1996 Airstream B190
AIR #13
Old 12-18-2015, 07:22 PM   #275
Good Job Peter!
Great to talk to you today!
You ROCK, and I will elaborate over on my thread!
Nice Radio Brad, I like the idea of loosing that brick on the top of the dash for the RVC...
Old 12-18-2015, 07:42 PM   #276
Something to keep in mind, this new solenoid does not handle the large cable from the battery to the starter. It only handles the cable that energizes the solenoid that is built into the starter.
Seems like an odd arrangement but that's how GM set it up. If I remember things correctly the problem with hot starts was due to the long undersized wire ran from the ignition switch to the starter solenoid. As the small wire got hot from being close to the exhaust system the resistance went up and the amount of current making it to the starter solenoid was reduced so there wasn't enough current to actually get the solenoid on the starter to engage.
So the ignition switch now energizes the solenoid on top of the valve cover. There is a heavier gauge wire from the battery (or some +12vdc source) to the new solenoid which then goes down to the original solenoid. Larger wire and more current allows the original starter solenoid to engage.
I'll look around for the service bulletin. It's been posted on Airforums before I just don't remember where.
Here's a site that can explain the hot start problem and solution better than I can.
And here's one from airforums.
Old 12-19-2015, 06:20 AM   #277
Airstream Driver
1997 30' Excella
Images: 51
Got me going on this subject now, Brad
I probably would have room for a 2din since there is a radio and an equalizer currently. Just have to check the room behind the dash.
Why would you prefer an Android system to something like this:
Jensen A/V Receiver w/ DVD-Built-in NAV-Built-in Bluetooth Technology-Sirius-XM Ready-Pandora-USB-HDMI Multi VX7012 - Best Buy
1996 Airstream B190
AIR #13
Old 12-19-2015, 06:32 AM   #278
I believe that is an Android system and looks to be a good one so I'd be interested in that one as well
Being name brand would put it towards the top of my list. When I posted the link yesterday I just grabbed the first link that came up. I actually haven't looked at them for a while as I'm not ready to buy. I figured when I actually have the dash back in place then it's time to find the right radio.
Old 12-19-2015, 08:43 AM   #279
Dang it Peter!
After looking at the Jensen reviews (all positive by the way) and looking around at prices I convinced myself to go ahead and order one!
I found the best price at Amazon for $283 with free shipping. I had a coupon to use so I got it for even less. I think I'll look at this as a Christmas present to myself
Jensen XV7012
Old 12-19-2015, 08:52 AM   #280
Airstream Driver
1997 30' Excella
Images: 51
Dang it Peter!
Jensen XV7012
get the one with the little remote camera and be done with that part. Besides, you should install it right away with the dash so you can have tunes and a GPS to find your way around your shop.
I will order one myself, but still trying to find one locally, because I have time this weekend to install it (no patience here)
1996 Airstream B190
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
