12-25-2015, 07:44 PM
#361
_
, _
Starting to look like a space shuttle!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
12-25-2015, 08:08 PM
#362
Richmond
, Kentucky
Originally Posted by PeterH-Airstreamer
Last post on the subject. Had to dig into the dash again, lost ground to the left seat switch, had to run a new ground wire.
Added switch to turn camera on at will and did the dvd override.
Now of to new adventures:
dual fan in front of radiator any idea where to look for them?
Peter, you can see a picture of the twin 10" fans that I installed on my Argosy radiator. Scroll down to post 20.
Are you adding fans as a precauction or are you having cooling issues?
1975 24' Argosy Motor Home
12-25-2015, 08:22 PM
#363
Richmond
, Kentucky
You may want to add this to your wiring diagram:
1. Ignition wire needs to have its own switch, if you don't wire to your ignition. (if you just turn to unit off, it will continue to get warm and run the fan)
I think thats pretty much true with all modern radios.
Which reminds me I need to add a switch to my F250 diesel. I don't drive it much anymore and the new radio tends pull the batteries down after a few months.
2. To operate the DVD player at all times, wire the handbrake (pink) to ground (disclaimer, its illegal to operate a DVD player while driving!)
3. The backup camera uses the green wire to turn on the camera in reverse. Wire that green wire to constant power using a toggle switch to trick it into thinking you are in reverse
Yep, made those mods to my two Fords. Well worth doing
12-25-2015, 08:24 PM
#364
Richmond
, Kentucky
I used 16 gauge, I hope that not too heavy?
Nope, 16 gauge is the right size.
12-26-2015, 05:25 AM
#365
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
No cooling issues, but I will need the fans for the AC.
AIR #13
12-26-2015, 05:34 AM
#366
Richmond
, Kentucky
To go along with the two fans you might also consider a radiator fan temperature control. I bought a Hayden 3647 for my TR4 and it worked well so I bought another one for the Argosy.
You might also want/need to add a Trinary switch in place of the Binary switch in the AC system. The second function of the Trinary switch is to cause the fans to turn on anytime the compressor clutch is engaged.
It's amazing how many different things you have to research and learn when working on one of these old rigs!
Have you picked out your fans yet?
12-26-2015, 06:10 AM
#367
Airstream Driver
1994 30' Excella
Austin
No, have to take measurements to pick a good size and also have to build support brackets.
I have to dig a little deeper into the EFI system, supposedly, the fan can be controlled by the ECU. The trinary switch sounds interesting, I would use it for the aux Switch I have on the dash to run the fan at my control, unless the trinary switch is pressure activated only?
You always have such valuable info, wished i would have asked you about the handbrake and reverse wires before going on this wild goose chase.
At least I came to the conclusion as you did, which could mean 2 things: Either we are both pretty smart or very stupid
AIR #13
12-26-2015, 08:46 AM
#368
Richmond
, Kentucky
Did you take that picture in my back yard?! Possibly between the two of us we'd end up with half a brain
Here's a couple of pages out of the P30 chassis manual showing the fan arrangement. The original installation used two 10" fans but sometime in 1990 GM supposedly switched to one 16" fan. I've not seen the 16" installed before and my preference would be two fans. That way if one fails you still have one fan working.
When wiring them use separate relays for each fan on separate fuses. If one fuse blows you'll still have the other fan running.
The Trinary switch is screwed into a port on the high pressure freon side of the compressor. The original Binary switch was used to disengage the clutch on high freon pressure. The Trinary switch was brought into service when the switch was made from R-12 to R-134a. R-134a runs at higher pressures so the additional contact in the Trinary switch turns on the fans to try and bring the head pressure down.
The Hayden controller I listed previously does something similar but the the Trinary switch works off of freon system pressure and the Hayden works off engine coolant temp. I plan on using both in my system.
12-26-2015, 09:05 AM
#369
Richmond
, Kentucky
Finally was able to go for a test drive with the new trans pan and trans temp gauge.
temp varies a lot with the range being around 160 -180, goes up at traffic stops drops down fast once you get moving.
Brad, you will be very happy with the new fan clutch. Very smooth and quiet operation. Best I had.
Peter, if you have one of those laser temperature readers you should go for a "spirited" drive and take a quick laser reading and compare it to the gauge on the dash.
I'm curious if you notice any difference in readings.
12-27-2015, 08:58 AM
#370
Airstream Driver
1994 30' Excella
Austin
Picked a license plate camera, for ease of wiring, since I didn't want to drill any holes on the roof.
Very pleased with the performance, its BOYO VTL16.
Only issue i am having is that the instructions call for clipping a small wire to reverse the image if used as a rear view camera. I did it, but the image did not flip. left is right
AIR #13
12-27-2015, 09:37 AM
#371
Richmond
, Kentucky
Rotate the camera 180 degrees Just kidding.
Did the instructions say how to turn the parking lines on & off? The camera I bought for my F250 has the lines but I don't think they can be turned on & off. However the camera at least oriented the picture correctly.
Where'd you mount the camera?
12-27-2015, 10:12 AM
#372
Airstream Driver
1994 30' Excella
Austin
One tiny wires supposedly controls the left/rgiht orientation and the other the parking lines. I only cut the left/right wire so far.
Another odd thing:
camera comes with RCA wire for video signal and another 2 wires for 12V+/-.
When I tried to connect the negative to ground it sparked , so I thought WTH and tried the camera without connecting that ground wire and all works as intended????What gives on this??
I mounted camera to the right side of the license plate and just modified the mounting bracket.
AIR #13
12-27-2015, 10:32 AM
#373
Richmond
, Kentucky
Wow, talk about a stealth camera
Was the +12vdc connection made?
I'm assuming you had the radio on and the camera on as well so when you touched the ground to chassis you completed the circuit which allowed it to complete the configuration change (cutting the wire). I have no idea if that's how it works but it's the only explanation I can come up with.
My radio arrived today
I've already backed up the GPS software and am in the process of downloading the updates.
12-27-2015, 02:10 PM
#374
Airstream Driver
1994 30' Excella
Austin
Yes camera was on and unit was on when I tried to connect the ground.
12v ground mystery solved:
Camera will work with RCA cable only, but to use some of the cameras options , like reverse image, it has to be connected to 12v +/-. Now the image is correct.
Now, connecting laptop to update GPS. Too bad it does not use SD cards
AIR #13
12-27-2015, 02:46 PM
#375
Richmond
, Kentucky
+12 to the camera makes sense. Glad you got it working.
The GPS does have a microSD card. It's located in the lower right front. There's a little door you pull open and the microSD card is located at the bottom.
I didn't know you could update the software using a laptop.
12-27-2015, 05:18 PM
#376
Airstream Driver
1994 30' Excella
Austin
How do you get the info on the SD card? The toolbox program I downloaded is looking for the device.
Here is a picture from the license plate camera.
BTW, cameras like this come with a 25' non shielded cable. Fortunately, I used mostly 4 strand shielded as the extension.
AIR #13
12-27-2015, 05:39 PM
#377
Richmond
, Kentucky
You will need to remove the microSD card from the radio and using an adapter plug it into the computer that has the Toolbox software. If you have the Toolbox software open and running as soon as you plug in the microSD card the program should recognize it.
Be sure and back up your card when it prompts you.
Also pay attention to the message that pops up after it is done updating the card.
Do you have a microSD card to SD card adapter?
The backup video looks good!
12-27-2015, 05:58 PM
#378
Airstream Driver
1994 30' Excella
Austin
Thanks for the info, I really thought you had to connect to the Jensen.
Updating now. All I got with the unit was the wiring diagram, no manual (not that I would read it anyway)
AIR #13
12-27-2015, 06:18 PM
#379
Richmond
, Kentucky
12-27-2015, 06:27 PM
#380
Airstream Driver
1994 30' Excella
Austin
The monitor has a tilt angle adjustment, so you are good
AIR #13
