Old 11-01-2015, 08:48 PM   #225
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by gaiaenviro View Post
If the weather is good I'll bring the cadyac (intentional spelling). I'm putting it on the calendar now. I had forgotten he moved the shop over there.....Attachment 251518
-Bill
Now you are talking . If you come for the Saturday Party and want to say hi, you can ask Charlie if the guy (me) that did his silver walls is around?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-11-2015, 08:06 AM   #226
Airstream Driver
1997 30' Excella
Images: 51
In case someone missed my post on the front centramatics special order:
http://www.airforums.com/forums/f159...ml#post1708809
Thanks Brad for suggesting to post it here as well.
1996 Airstream B190
AIR #13
Old 11-20-2015, 02:39 PM   #227
Airstream Driver
1997 30' Excella
Images: 51
I remember seeing discussions about fan clutch replacements, but failed to bookmark it.
Whats the consensus for the best replacement?
1996 Airstream B190
AIR #13
Old 11-21-2015, 08:15 AM   #228
chriscraw's Avatar
1991 35' Airstream 350
Peter..I've just replaced the "after-market" fan clutch in the 350LE with an original GM Delco unit but as far as I could tell, there was no physical difference! If you need let me know and i will give you the link to the Delco unit.
chriscraw is offline   Reply With Quote
Old 11-21-2015, 08:54 AM   #229
Airstream Driver
1997 30' Excella
Images: 51
Chris , yes please, if you have the part number
1996 Airstream B190
AIR #13
Old 11-22-2015, 10:20 AM   #230
chriscraw's Avatar
Peter,
AC Delco part number 15-4949 GM Original Equipment Engine Cooling Fan Clutch. Price was $109 and purchased through Amazon Prime (there may be cheaper suppliers but as I wasn't sure of the fit, i wanted the ease of return)
In meantime..my next project which we can discuss at Blanco!
Old 11-22-2015, 02:00 PM   #231
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Peter,
Is that a Banks & Maxwell or Franklin propeller??? Or perhaps car on fiber?
I would put a screen on it for jaywalkers..
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-03-2015, 07:44 PM   #232
Airstream Driver
1997 30' Excella
Images: 51
got the three new gauges installed, Ammeter not wired in yet, but got trans temp and coach batteries volt meter all wired up.
Next week, we have out 13th annual Christmas rally-non Rally at Blanco Statepark, outside of Austin.
This year we will participate in the Blanco Christmas parade, with the 310 being the Grand Marshal and a 17 Caravel covered in pink Flamingo and my Class LondonAire (now all polished up by the new owner ) being the Caboose.
I will try to post lots of pictures.
If you are interested, you can also check this thread:
http://www.airforums.com/forums/f288...-a-129912.html
1996 Airstream B190
AIR #13
Old 12-04-2015, 07:09 AM   #233
Looks good Peter!
I did notice that on mine a have an open gauge slot on the top row to the right of where your fuel gauge is... But the mask panel is blacked out. Wondered if it could be used?
Old 12-04-2015, 02:57 PM   #234
Airstream Driver
1997 30' Excella
Images: 51
Looks good Peter!
I have the same spot and considered using it. There are a couple of problems with that spot.
1. As you said its blackened out and i wouldn't know how to make it clear
2. the metal bracket all the other gauges are attached to, does stop just short of the open slot, so one could not easily attach another gauge without modification
One easy solution would be to drill a 2" hole and slip the additional gauge in that spot from the outside. Not sure if that would be a desired solution.
1996 Airstream B190
AIR #13
Old 12-04-2015, 05:09 PM   #235
I have the dash assembly from the 345 sitting on the shelf. When I get home next week I can dig into it to see if that spot could be made useful. Beats having you guys tear up your dashes trying.
Do diesel engine Classics have an extra gauge in that spot? Maybe a boost gauge or something similar?
Old 12-04-2015, 08:19 PM   #236
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mine has a pyrometer in that spot. but the PO used a hole saw to install it
shepherd57 is offline   Reply With Quote
Old 12-05-2015, 07:39 AM   #237
John, do you want the one I have from the 345? It would just be the bare dash as I will have removed the gauges and other hardware.
The only tricky part would be getting it to you.
Old 12-05-2015, 09:55 AM   #238
shepherd57's Avatar
Lindsay , Ontario
I would love to have it, I'll figure something out to get it. We are going to the spring get together in PA in May
John
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
