Old 09-25-2015, 05:44 AM   #169
Originally Posted by PeterH-Airstreamer View Post
Today, I used my 15 year old ramps again, Martin .
We both could fit under there
Peter, I just noticed that you have two air vents above the front wheels instead of the typical one. Did you do that or did the PO do it?
I wonder how much it really helps. I managed to find identical vents in cream color that I will be using on my Argosy.
Old 09-25-2015, 06:21 AM   #170
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Those certainly beat $75 plastic ramps into a cocked hat! I like the beaver tail, to stop the ramps slipping out. I would worry about driving off the front, and I think I'd add a wedge or block to bump up against.
1989 345LE
Punch is offline   Reply With Quote
Old 09-25-2015, 06:26 AM   #171
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Any hints on where you found them Brad?
martin300662 is offline   Reply With Quote
Old 09-25-2015, 06:35 AM   #172
I bought these Tan 17" louvers and they look identical to the silver louvers I removed from the 345 except for color.
Price was reasonable and quality seems to be just fine.
Old 09-25-2015, 06:43 AM   #173
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks, I just ordered a pair.
Old 09-25-2015, 07:09 AM   #174
Somewhere I have the dimensions written down for the opening cutout. Let me know if you need them.
Old 09-25-2015, 07:11 AM   #175
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
The 345 I owned a few years had both vents missing, the PO "misplaced" them along with all the Airstream emblems. I had a real hard (and expensive!) time trying to find the original size louvres and emblems.
You may remember me scratching at your door and begging, when you dismantled the 345.
Figures that this 310 has 2 on each side, which appears to have been installed many years ago.
If you ask me, the more chrome/aluminum the better
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-25-2015, 07:13 AM   #176
Airstream Driver
1997 30' Excella
Images: 51
But they are Plastic
Here are chrome ones @15 7/8"
http://www.ebay.com/itm/CHROME-BOAT-...3c83bb&vxp=mtr
1996 Airstream B190
AIR #13
Old 09-25-2015, 07:16 AM   #177
Airstream Driver
1997 30' Excella
Images: 51
The other side has a wedge to stop me from ruining my day.
1996 Airstream B190
AIR #13
Old 09-25-2015, 08:12 AM   #178
I never looked for chrome louvers as I wanted to match the color of my Argosy. The chromed ones are slightly different but not enough to notice. Probably the major difference is mounting hole location.
Martin, if you decide you want chrome louvers I'll buy the ones you just bought and keep them as spares.
Old 09-25-2015, 08:13 AM   #179
...You may remember me scratching at your door and begging, when you dismantled the 345.
I hope you realize I didn't have a say in about those louvers
Old 09-25-2015, 08:20 AM   #180
Airstream Driver
1997 30' Excella
Images: 51
quick dimensions for safe wood ramps:
48" long, 11 1/2" wide
Materials needed for 2 ramps
2x 8' 12"x1 1/2 treated lumber (or get 10' boards to have the option to raise the deck another 1 1/2 ")
2x 8' 6"x4" treated lumber for the deck support
some 3" deck screws
ID:	248913   Click image for larger version
ID:	248915   Click image for larger version
1996 Airstream B190
AIR #13
Old 09-25-2015, 08:22 AM   #181
Rivet Loser
Punch's Avatar
Having read the thread on making a fender well shield on the right side to match the left side, to channel air flow past the exhaust manifold, I wonder if you then want to make it easier for air to exit the fender well? Wouldn't there be a chance that by fitting the extra vents you'd then reduce cooling flow across the manifolds? I feel sure that would be the case if you have no shield on the right side.
1989 345LE
Old 09-26-2015, 06:45 PM   #182
Airstream Driver
1997 30' Excella
Images: 51
pulled the drivers side tire today to change the plugs and check the brake fluid. The access hole cut into the sheetmetal for the Master Cylinder is very helpful.
Fluid looked great and clean, just a little discolored. The previous owner did a fine job rebuilding the brakes, including replacing the rubber brake lines. (thanks Bill )
Powersteering pump looked good , so did all the lines.
Plugs all looked great, love the EFI
Watch out Brad, Kentucky here we come..
ID:	249058   Click image for larger version
1996 Airstream B190
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
