Old 08-29-2015, 10:21 AM   #127
Peter, I looked at the 345 pieces that I had left and I couldn't draw any conclusive results. In some places it looked like their might be some sealant and in other places I don't think there was any.
When I dismantled the 74 Excella trailer last year I don't remember any sealant on any of the seams.
Now you have me thinking I should pull the interior skin and seal all of the joints with Vulkem 116 as you suggested.
More work...
Old 08-29-2015, 10:50 AM   #128
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
More work...
Brad, start thinking like Tom Sawyer and invite all your Forum friends over
Actually I stand corrected on the sealant. Upon closer inspection of the back of the panels, they did apply a vulkem type sealant to the seams. Just none on the mating surfaces of the panels, which obviously is a lot more work.
Using a sealant on the exterior seams when you are all aluminum is a no brainer. If you plan on painting, its a different story. Any type of sealant would always be starting point for peeling paint.
ID:	246695   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 08-29-2015, 11:06 AM   #129
Airstream Driver
1997 30' Excella
Images: 51
a few considerations for anyone that might be so foolish to try this at home :
The panels come pre-formed but not pre-cut to size. I found it to be the easiest to try to match the curve of the old panel. I made a real effort to NOT line it up with the old holes of the adjacent panel that remains, because it may cause some undesired big holes. Vulkem will permantly seal the old holes.
ID:	246697   Click image for larger version
1996 Airstream B190
AIR #13
Old 08-29-2015, 01:38 PM   #130
Airstream Driver
1997 30' Excella
Images: 51
Amazing how thin and missing the insulation was back there. I added 15 feet 16" wide R13, I am sure it will make a lot of difference.
After carefully fitting and adjusting the first panel (passenger side), I dry hung it with clecos, giving all my attention to this seam, because it will bite you later if you don't do it now. The panels came with a clear protective plastic sheeting that will remain until later.
ID:	246711   Click image for larger version
1996 Airstream B190
AIR #13
Old 08-29-2015, 01:45 PM   #131
Airstream Driver
1997 30' Excella
Images: 51
Here is something to really watch out for. Depending on how far you slide the panel under the roof panel and the windows in the back, you can have different heights of all three rear panels, which can result in a humpback look. I have seen rigs (and trailers) repaired like that and its not desirable. One way to check it is (besides taking care not to cut them to long abviously) by looking down the roof from the back and making sure that the panels are not higher than the plane of the roof
1996 Airstream B190
AIR #13
Old 08-30-2015, 12:02 PM   #132
Airstream Driver
1997 30' Excella
Images: 51
drivers side panel and center panel are dry hung, ready to drill and cleco all the holes.
Then all 3 panels have to come back down, cleaned up and the final installation can begin
1996 Airstream B190
AIR #13
Old 08-30-2015, 12:07 PM   #133
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
LOT-O-WORK Peter, great job.
Mike
mayco is offline   Reply With Quote
Old 08-30-2015, 12:08 PM   #134
mayco's Avatar
Looks like you've got a nice shop to work in! Makes a HUGE difference.
Old 08-30-2015, 12:28 PM   #135
Airstream Driver
1997 30' Excella
Images: 51
Yes Mike, it really does make a difference to have a dry, shady place to work. The real 30x40' shop is behind the covered RV parking, but the door is too small for the Airstream.
Ok, back to drilling a few hundred holes.
1996 Airstream B190
AIR #13
Old 08-31-2015, 04:04 PM   #136
Peter, good information on replacing panels!
For a job like that I don't imagine you could get by with 5 or 10 clecos
Old 08-31-2015, 07:33 PM   #137
Airstream Driver
1997 30' Excella
Images: 51
Thanks Brad, I figured that I was boring everyone to death with the step by step , but who knows maybe someday it could be helpful to someone.
Yesterday I completed the dry hanging and drilling all the rivet holes. I carefully marked the three panels for location and took them down. This evening I installed panel 1 after removing the clear plastic coating under the seams and at the row of rivets. I applied a very liberal amount of gray Vulkem 116 under all the seams and started to set the rivets.
I do not use Olympic rivets with washers, since the washer will disintegrate in a few years, due to the extreme heat. I let the vulkem 116 be the washer and also the sealant and adhesive for the panels.
If you zoom into my second picture, you will see vulkem under every rivet head and a thick beed squeezing out at the seam.
The third picture shows it all cleaned up and the rivets ready to be clipped and shaved, which will not happen for a few day to give the vulkem time to set.
ID:	246922   Click image for larger version
1996 Airstream B190
AIR #13
Old 09-01-2015, 01:00 PM   #138
I'm proably more into the technical aspects of these motorhomes than the social aspects. I frequently sit in my recliner in the evenings reading various technical manuals
Definitely keep posting this info. I have to replace a couple of lower panels so any insights you provide will be put to good use!
Old 09-01-2015, 09:18 PM   #139
Airstream Driver
1997 30' Excella
Images: 51
Less is more
Almost got in trouble with the final install of the center panel today. I misjudged what the thickness and setup time of the vulkem under the seams could do to the alignment of all the pre drilled holes.
Lesson learned: do not use too much vulkem
It was a struggle, but I got it all together. This pictures shows why it is a good idea to leave the protective plastic sheeting on until the very last (except for under the rivets and under the seams)
1996 Airstream B190
AIR #13
Old 09-02-2015, 04:39 AM   #140
mayco's Avatar
Looking really good Peter. Good deal that the vulkem didnt bite you in the rear. That would have been a real PITA to have to pull that panel and scrape it off.
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
