Old 02-01-2017, 11:40 AM   #99
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Welcome!
In the meantime, a couple of thoughts:
1). If it's in the Austin area, try to get member PeterH Airstreamer to do the inspection.
2). Make sure the inspection includes the subfloor, especially in the cockpit area. Some of this era have osb subfloor instead of plywood, and it doesn't take much of a leaky window to ruin the osb.
3). If you buy it, get good roadside assistance insurance for the trip. If you need a tow, insist on a flatbed if possible. I try to stay off the interstate as 55-60 mph is the sweet spot for this drivetrain.
Otherwise, delusional is just a given here. Sounds like you were made for each other.
Waipio Rim is online now   Reply With Quote
Old 02-01-2017, 02:17 PM   #100
Hi There.
Post your question down in the Classic section, as that is where you will get the most traction for the vehicle you are looking at and for!
We will be kind, but we will be honest, and I think you will prefer that!
Steve, he has an Argosy not a Classic...
Oops, my mistake. He owns an Argosy trailer and is looking at a Classic. I think I just need to go back to bed......
bkahler is online now   Reply With Quote
Old 02-01-2017, 03:30 PM   #101
I think you just have Argositus, Brad.
Rub some $100 bills on it regularly, and it will get better in the short term, but apply liberally, or it will come back!
Old 02-02-2017, 01:36 PM   #102
I only have one $100 dollar bill and I'm lucky to have that one so. Between the Argosy and the TR6 I'm living in the poor house
Old 03-24-2017, 10:41 PM   #103
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This is the motorhome sticky thread right?
Found what seems to be an excellent article describing and troubleshooting a hydroboost system with also an explaination of what impact it can have on the brakes.
http://www.brakeandfrontend.com/oper...ssist-systems/
Your input as to wether this article is relevent, or if certain sections don't apply to us is needed.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-25-2017, 06:26 AM   #104
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Cheers
Tony
Tony, nice find!!
This is the first article I have seen that deals with the dreaded brake pre-load condition that can kill your transmission and cause you to go into a full breaking at Highway speed.
Another more shade tree mechanic way to check for it, is to raise an axle and if the wheel is not spinning freely, slowly unbolt the master cylinder, whilst your buddy checks a wheel for rotation.
from the article>>>>>>
5. If brakes are self applying and pedal is free, check for obstruction in the return line or a kinked connection between hydo-boost and pump reservoir. If obstruction or kink is found, go to step 6, otherwise go to step 7.
6. Remove obstruction or replace line as required. If condition remains, check for a damaged reaction end. If damaged the hydo-boost should be replaced or repaired.
7. If brake pedal is free of any binding conditions and return line is free of obstructions, remove the master cylinder cover.
8. Observe the brake fluid in the reservoir while rapidly depressing the brake pedal one inch.
9. Fluid surface should have some movement or spout in the forward reservoir section. Minor spouting may occur in the rearward reservoir. If no movement or spouting of fluid occurs in forward reservoir, the hydro-boost unit is defective and must be replaced or repaired.
1996 Airstream B190
1997 30' Excella Wide Body Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 03-27-2017, 03:51 PM   #105
I'm getting ready to replace the cockpit window seals in Peanut and my Argosy so I've been reading through all the threads on the topic and found various bits of information. The parts information I'm posting here was gleaned from an earlier post (can't remember who!) and I just added too it some part numbers from Out of Doors Mart and Vintage Trailer Supply along with a link to Peter's favorite Schlegle supplier
Oh yeah, I added a few pictures that show each part so you know what's being referenced.
Name:	window parts.jpg
ID:	282191Click image for larger version
Name:	window part pictures.jpg
Old 03-27-2017, 06:57 PM   #106
Ok, I found one error in the list above. For the 74 - 76 and possibly all Argosies, the 30" x 30" side windows need two 10' pieces of Fuzzy Schlegle. Unfortunately that means the stuff Peter recommends won't work unless it can be had in longer than 8' lengths
For the record the lengths I need for each cockpit windows are:
96" - fuzzy schlegle
33" - vertical lip seal
33" - fin seal
60" - trim seal
For the 30" x 30" side slider I need:
20' fuzzy schlegle (2 10' sections)
60" - trim seal
33" - real fuzzy (technical term!) vertical seal between the two panes
It's interesting the the real fuzzy seal wasn't provided on the list in my previous post.
Old 03-27-2017, 07:27 PM   #107
Airstream Driver
1997 30' Excella
Images: 51
33" - fin seal
60" - trim seal
60" - trim seal
Brad, you dont need a continues piece for the coach slider windows. I put the join under the fixed window, using 3m Black weather stripping at the splices. You only want a continues pieces where all the sliding action is.
The fuzzy schlegle with the metal inside makes the windows operation even harder. 1 8' per sliding window plus 2' per window.
1996 Airstream B190
AIR #13
Old 03-28-2017, 06:01 AM   #108
Peter, I guess that makes sense. Of course I just got done ordering some of the Hitechglazing schlegle about 20 minutes ago for the cockpit windows
I need to order some for all of Peanut's side sliders so I'll order more for me at the same time.
Thanks!
Old 03-29-2017, 05:24 AM   #109
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Thanks!
Just started thinking about this. I've read about this front cockpit window replacement over and over, seen pix as most have gone through the motions. Has anyone every tried to do a video? I'm almost to the point of doing my windows, have had the fuzzy schlegle for months now, but would really love to see this from beginning to end. Maybe I'll go 'Google' that now......
Old 03-29-2017, 06:40 AM   #110
Derek, I doubt there's a video out there but nothing says you can't make one for us!!
I removed the two sliders from my cockpit windows last night. In the 10 years I've owned the Argosy the sliders have never moved, couldn't budge them at all. So last night I sprayed each side of the fuzzy schlagle where the glass sits with WD-40 and waited about 10 minutes. I then used a small pry bar wrapped in rubber and got them to slide forward. Probably took about 10 minutes total after that to get both sliders out and the rest of the fuzzy schlegle removed. I was actually somewhat surprised at how much of a non issue it really was to remove the glass.
I'm waiting on the new fuzzy schlegle from Canada to arrive and once it does I'll start putting the windows back together.
Old 03-29-2017, 07:51 AM   #111
1982 31' Airstream 310
Henniker , New Hampshire
Thanks!
I am getting ready to tackle my front sliders also. The PO redid mine with schlegle from VTS but it has deformed and the windows don't work well. I am planning to try Peter's suggestion. I purchased mine from Amazon for slightly less money (actually a higher price with cheaper shipping). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 03-29-2017, 09:42 AM   #112
Dazed and Confused
Isuzusweet's Avatar
While curious on what crazy person came up with the term "fuzzy schlegle", I'm more interested as to where in Canada of all places you're buying this stuff from? Can-am RV?
Cheers
Tony
