Old 10-14-2012, 09:37 AM   #29
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Thanks Keyair; I pm'd you. I am about 70% committed at this point, and from what I have read if I get it I will need to be committed!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 10-14-2012, 01:56 PM   #30
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Great sticky....Just to add, along with a truck GM service manual covering the P30, a 1983 310 service manual, I have the original Isuzu service manual for the 6B If anyone wants it I will try to get it scanned.
Old 10-16-2012, 05:33 PM   #31
Yes, please scan the Diesel motor manual...
I just added the Official GM vaporlock cause and cure PDF form 1984.
Chevy P-30 VaporLock Fix 1984.pdf
Please note that comment on the last page about adding a hose to pipe air from the front of coach to air filter snout and how that improves fuel cooling...
Old 10-16-2012, 07:51 PM   #32
Here are some Onan generator manuals. Most are for the Emerald plus 6.5 which is the genset that came in the 1986 345 that we dismantled.
Onan Emerald plus Operators Manual
Onan Emerald plus 6500 Genset spec sheet
Onan NHE-NHEL Genset Service Manual
Onan Installation Guide 6.5 NH Genset
Onan Operators Manual 6.5 NH Genset
Onan Installation Replacement for Crank Ignition Relay
Onan RV Troubleshooting Guide from Flight Systems
Onan Installation of Control Board Replacement
Old 10-16-2012, 07:52 PM   #33
This is some great information! Getting some good stuff posted here
Old 10-16-2012, 08:04 PM   #34
Yes indeedy Brad... I will post them!
Old 10-17-2012, 02:56 PM   #35
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Front windshield moulding.
Had both our windshields replaced a few years ago and the glass shop said they could no longer get the black moulding. Cracked another one down here and saw a mobile glass shop guy who confirmed what they said. There is a generiac moulding available he said is a bearcat to install. What he did say, was to coat the moulding from time to time with petrolatum jelly to keep them soft. Thought all might appreciate his advise.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-17-2012, 03:38 PM   #36
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I disagree Mike, I had my windshields replaced last year with new gasket and talked to the glass shop last month and he can still get the gasket.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 10-17-2012, 04:11 PM   #37
Mike, are ya talking about the rubber gasket, or the black locking moulding?
Old 10-17-2012, 05:59 PM   #38
Mike Leary's Avatar
Images: 11
It's the black two-piece locking moulding I'm told is no longer made. The gasket is easy money.
Old 10-18-2012, 03:13 AM   #39
My lock strip came with the gasket. The gasket wouldn't be much good without the lock strip. By gasket I mean the rubber moulding and lock strip that holds the glass. I'm not sure what the big deal is but I stood there as they removed both pieces of glass and all the gasket material down to bare aluminum and then installed all new gasket and glass. The gasket is a single unit vulcanized and holds both pieces of glass. I talked to the guy about 2 months ago for current prices and availability and everything is available with an installed price of about $2500. The glass went up about $100 per side since I did mine about two years ago.
Cheers, Dan
Old 10-20-2012, 10:53 AM   #40
Mike Leary's Avatar
Images: 11
Someone at the camp had a question I could not answer: Did AS make the 345 mo/ho in a diesel version, or was it just the 328/310 and 36 footer?
Old 10-20-2012, 12:36 PM   #41
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Never seen a 345 factory Diesel, only 280, 310 and 360
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-20-2012, 12:53 PM   #42
1991 345 with a 5.9 Cummins....
1991 Airstream Motor Home 350 LE - Airstream Trailer Classifieds - Airstreams Trailers For Sale
