Old 07-14-2018, 02:15 AM   #141
1992 35' Airstream 350
Alpena , Michigan
There is some great info in this thread. I just bought a 1992 350LE. Anyone know where I can source the deadbolt lever that is inside the cabin? Mine is missing so I can currently only lock the door from the outside.
Robrings is offline   Reply With Quote
Old 07-14-2018, 04:24 AM   #142
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Airstream Supply, Out of doors mart, Vintage trailer supply or Inland RV. You are best to post queries to the Classic Motorhome thread.
Boom Sounds is offline   Reply With Quote
Old 07-16-2018, 11:22 AM   #143
Brad Kahler has forgotten more about these than I ever knew!
Keyair is online now   Reply With Quote
Old 08-05-2018, 07:01 AM   #144
Argosy 454 v-belts
I won't guarantee these belts will work on all Argosy's but they work fine on Peanut which is a 77 Argosy 454 with the original style of A/C compressor and original size alternator.
Gates 7630 - AC compressor belt
Gates 7405 - Power Steering pump belt
Gates 7460 - Alternator belt
If you're replacing all three belts then replace them in the following order:
Note: I would suggest getting all three belts in place before you do any tensioning.
1st belt - (7405) PS to Crank (Tension PS pump first using 1/2" ratchet connected to top of PS pump bracket)
2nd - (7630) A/C to PS to Crank to WP (Tension after PS pump has been tensioned, Tension via long screw on top of A/C compressor pump mount)
3rd - (7460) Alt to WP to Crank (Tension Alternator via top mounting bracket, Reminder: Lower alternator pivot bolt is accessible form underneath right front wheel well)
I'd highly recommend you always replace all three belts while you're in there.
Ignore the numbers on the diagram below. No sure what they are for but the layout of the belts is correct. Also ignore the smog pump, your Argosy shouldn't have one
Name:	74 mhpulleys.jpg
Old 09-03-2018, 02:23 PM   #145
TRUCK and MOTORHOME SERVICE Reference LIST (73-39)
http://www.bdub.net/manuals/Publications-Catalog.pdf
Reference numbers forvarious service catalogues (73-79)
Old 02-11-2019, 08:50 AM   #146
Madisonville , Tennessee
This is a terrific resource, especially for a newbie like me. Can someone confirm that from 1993 to 1997, the Classic was renamed Land Yacht with a sloped nose etc but still retained the aluminum skin? In my search for an Airstream motor home, I had narrowed it down to a Land Yacht but was reluctant to deal with a fiberglass exterior. Have had some unfortunate experiences with delamination on a motor home. Those 5 years, 1993-1997 with aluminum skin would be my preference by far, even though the Workhorse chassis on later Lank Yachts was better. Thanks
jimandtere is offline   Reply With Quote
Old 02-11-2019, 11:23 AM   #147
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The Land yacht was the fibreglass version of the Classic (aluminum) motorhome, built from 94-96. Only 24 or 27 of which were 5.9 Cummins powered rear pushers on a Spartan chassis. The rest, 454 powered P30 or 32 chassis's with a tag axle. No diesels had tag axles.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-11-2019, 12:32 PM   #148
In the sticky on the Classis, there is this:
"in 1993 there was a major facelift, with a sleeker nose, and flush windows, and it became known as Land Yacht. It still featured the clearcoated aluminum exterior panels, and this model continued until 1997."
The Land Yacht I'm referring to has a radically slopped nose and I think most if not all are gas powered. To confuse us, Airstream also made a diesel pusher they called a Land Yacht with a much squarer nose. I'm asking if any of the radically sloped versions had aluminum siding?
Old 02-11-2019, 01:32 PM   #149
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Take a look at Fred's ViewRvs website.
In 1993 the Land Yacht came in 30, 33, 34 (fiberglass) and the Classic 36 (aluminium)....the aluminum version is normally referred to just as the the Classic
http://www.viewrvs.com/motorhome/air...tream-1993.php
martin300662 is online now   Reply With Quote
Old 02-11-2019, 05:14 PM   #150
Dazed and Confused
Isuzusweet's Avatar
Don't know if this would interest anybody and be worth sticking into the sticky?
http://www.offroadtoybox.com/RV/P-Ch...entProcess.pdf
Cheers
Sidekick Tony
