Old 09-01-2016, 02:07 PM   #155
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Hey, Girls & Guys!
Now i can show, what happend after this wonderfull Evening at the wineyard:
Attachment 270530
Attachment 270531
Attachment 270532
Attachment 270533
A snake-tomb! There was constantly "green water" leaking, i found the hose if the heater as "guilty" after removing Airfilter, many vacuumhoses and wires! This hose blew about 1 year ago, the clamp went loose since a while. Engine was "flooded" with "green stuff" (abti-freeze)
Attachment 270534
As you can see, my first thought was "quick fix", no need to get dressed...?
A Pyjama is a perfect "work-suit".
Once i was busy, i saw, why my volt-gauge was allways low and light while nightdrive weak:
The LESTEK-regulator is mounted on radiator frame, with just 2 screws. These became loose and corossive after 30 years, so i had a bad ground!
Cleaned it well, changed the screws and installed a thick wire from the regulator ground to chassis. Now i have constantly 13.4 Volts!
Thank's god, i have ALLWAYS the essential tools and some "fixing stuff" with me...!
After about 2 hours in the bright sun (Pyjama-Party!), it was done, could take may shower, had a second breakfast, day could start!
Attachment 270535
My son called this picture "Car-porn"...!
Attachment 270536Attachment 270537
proud Marcus, back on the road between Bernkastel & Kues
Name:	ImageUploadedByAirstream Forums1472760040.860107.jpg
forget to post this before, the exit of the campground, very steapy, felt bad to "push the hammer down" to leave with cold engine...😬!
Name:	ImageUploadedByAirstream Forums1472760311.967442.jpg
one of the countless guys, taking pictures of Bangles! If we could get just 50 cents per pic, a daily dinner for the family is payed...!
Next stop in Traben-Trarbach! Very impressive town, later more!
Sent from my iPhone using Airstream Forums!
Roquefort is offline   Reply With Quote
Old 09-01-2016, 02:11 PM   #156
Roquefort's Avatar
1975 29' Ambassador
'am not sure, if pics are visible, please lammy know!
Old 09-01-2016, 02:23 PM   #157
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Only the last two Marcus, the others show as invalid links.
martin300662 is offline   Reply With Quote
Old 09-01-2016, 02:42 PM   #158
Roquefort's Avatar
1975 29' Ambassador
Name:	ImageUploadedByAirstream Forums1472762126.838957.jpg
Name:	ImageUploadedByAirstream Forums1472762152.223301.jpg
Name:	ImageUploadedByAirstream Forums1472762181.194819.jpg
Name:	ImageUploadedByAirstream Forums1472762200.944847.jpg
Name:	ImageUploadedByAirstream Forums1472762219.311232.jpg
Name:	ImageUploadedByAirstream Forums1472762237.248779.jpg
These are the pics from "little fix",
hope the're now visible...!
Name:	ImageUploadedByAirstream Forums1472762315.620862.jpg
Old 09-01-2016, 02:46 PM   #159
Roquefort's Avatar
1975 29' Ambassador
Name:	ImageUploadedByAirstream Forums1472762636.615349.jpg
ID:	270548Click image for larger version
Name:	ImageUploadedByAirstream Forums1472762667.421677.jpg
ID:	270549Click image for larger version
Name:	ImageUploadedByAirstream Forums1472762683.290855.jpg
OK, pic's are "on" now! 'am sure, you will understand without coments...!
Bangles inmotkon is taken on the bridge between Bernkastel and Kues.
Old 09-03-2016, 03:28 AM   #160
Roquefort's Avatar
1975 29' Ambassador
The villages on our trip became closer now, our next stop was estimated in Traben-Trarbach.
Name:	ImageUploadedByAirstream Forums1472893540.292053.jpg
another "sexy vieuw" of Bangles! Just before we left in the bright morning sun, Anja began to took -again- "Bangles-promotion-pictures"! See some:
Name:	ImageUploadedByAirstream Forums1472893688.514282.jpg
Name:	ImageUploadedByAirstream Forums1472893756.605700.jpg
Name:	ImageUploadedByAirstream Forums1472893807.236975.jpg
See the wonderfull morning clouds in the glass reflected!
Name:	ImageUploadedByAirstream Forums1472893886.529688.jpg
Bangles travel-ready, the "bikers" on the go, i left a bit "in a hurry" and....:
CRACKED a taillight of the bikerack 👹! There was a hidden pole in the "green", invisible with back-up camera. the rack got a bad hit, but -thank's god- no hit to the body!!!! (bike racks in Germany are mounted ON THE HITCH BALL!)
Because of the cracked light, i blew some fuses, there was a short circuit now!
I took of the lights and left go a local repairshop for car-electrics:
Name:	ImageUploadedByAirstream Forums1472894221.716559.jpg
The shop was far too small for Bangles, we "fumbled" on the road!
Quick fix, cool mechanic, just insulated the wires finally, because the needed light was not in stock. He asked for nothing, wished a pleasant journey and wanted to see Bangles from inside...!
Name:	ImageUploadedByAirstream Forums1472894419.965666.jpg
Entering Traben-Trarbach, the "splitted" Town: Traben (left riverside) and Trarbach (right riverside).
There are impressive old buildings from the "Art nouveau" style, the town was very wealthy in the "golden times" (1870-1914), it was the second biggest wine stock exchange after Bordeaux (France) in Europe! There are Wine-caves from more than 2 1/2 km long!!!!
Name:	ImageUploadedByAirstream Forums1472894709.332515.jpg
Name:	ImageUploadedByAirstream Forums1472894762.852805.jpg
Name:	ImageUploadedByAirstream Forums1472894846.974774.jpg
This is the awsome "castle-bridge"! Never saw something similar, a VERY impressive building!!!
Old 09-03-2016, 04:05 AM   #161
Roquefort's Avatar
1975 29' Ambassador
Traben - Trarbach is a cozy old town, many, many spots to discover, but FULL of tourists and a bit crowdy....! Click image for larger version
Name:	ImageUploadedByAirstream Forums1472895189.099821.jpg
a vieuw actoss the Moselle ftom Traben to Trarbach. look's so "calm & cozy"...!
Name:	ImageUploadedByAirstream Forums1472895292.255936.jpg
Name:	ImageUploadedByAirstream Forums1472895455.534889.jpg
While it was -again- impossible to find a nice and big enough spot for the coach, we decided to move further for the "afternoon-coffee" break.
A few miles furthe, next to ferry boat was a big RV park anounced, i had to hurry up, my "bikers" were quick!
Name:	ImageUploadedByAirstream Forums1472895666.082247.jpg
RV's lined up the rivervieuw!
I found a spot (1/2 - legal!), set up the awning, it was very hot, made the patio ready, just in time!
They arrived and screamed for icecream, cake and ice-tea!
Name:	ImageUploadedByAirstream Forums1472895851.212373.jpg
it was soooo hot this day!
Name:	ImageUploadedByAirstream Forums1472896137.679231.jpg
The patio awning is pretty wide, but pulls out not very deep. We could have either "river-vieuw" with deep & hot sun, or "backyard-vieuw" in the shade. We got lined up with chairs under the awning, "chicken on a barbecuepin-like" and enjoyed the nice vieuw.
After a few moments the first neighbours came "along", took pictures, asked for "guided tours" inside....! (Now i know, how monkeys in the Zoo may feel!)
Time to leave and cool down in the river a bit!
Name:	ImageUploadedByAirstream Forums1472896497.020214.jpg
Name:	ImageUploadedByAirstream Forums1472896546.987082.jpg
Name:	ImageUploadedByAirstream Forums1472896636.059894.jpg
Next stop and the overnight spot was planned in eigher Ediger or in Bremm. Those two villages are known for the best Riesling wine out of the Moselle Valley, STEAPEST winehill is in Bremm: "Bremmer Calmont", the name comes from the roman age : "Mons caldus", means "hot Mountain". this Mountain is in a river elbow, so the sun surrounded the wineyards at maximum and heats up the stoney ground. The result is a fantastic rich & fruity Rieslingwine! (Very good!!!)
Name:	ImageUploadedByAirstream Forums1472896968.371143.jpg
On the go to Bremm, crossing the Moselle in Bulay, this Bridge (build in about 1900!) has two levels. up the railroad, down the road! Not very common here!
We planned a Restaurant dinner in Ediger, we know this town from work, but......?!
Stay curious!
Old 09-03-2016, 04:13 AM   #162
Roquefort's Avatar
1975 29' Ambassador
Arriving in Bremm! right side the ruins of a monastere from 1450, left the fabulous "Bremmer Calmont", only handlabour here for the winemakers, to steapy for any machine. (i guess, "high-heel" shoes will work great here, the you stay "levelled"!)Click image for larger version
Name:	ImageUploadedByAirstream Forums1472897439.114676.jpg
Name:	ImageUploadedByAirstream Forums1472897484.517985.jpg
Name:	ImageUploadedByAirstream Forums1472897565.906319.jpg
My plan was to stay overnight again in a winery....!
Hmmmmm......! You'll see!
Old 09-06-2016, 06:45 PM   #163
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I am so very much enjoying your sommer urlaub! Please keep posting! And the pictures are fabulous! Looks like everybody is having a wonderful time. And a bonus, you found a mechanic to work on the lights "for free". That's hard to find!
Enjoy!
www.nesa.org
Air No. 6427
Old 09-08-2016, 12:32 PM   #164
Roquefort's Avatar
1975 29' Ambassador
Thank you Jim!
So, on my way to find a nice spot for the night, we went further "river down". I looked in Ediger-Eller, but....:Click image for larger version
Name:	ImageUploadedByAirstream Forums1473357459.930628.jpg
Name:	ImageUploadedByAirstream Forums1473357551.988739.jpg
This very well equipped RV park in a winery was for 7 Metres (25') maximum, no way to enter with Bangles. We wanted a clean and cozy spot for the night, so "boondocking" on a truck park, beside the road was not an option.
Some other RVers told me, in Neef, on the other side of the river, a few miles back (&#128556, i''ll find a spacious and well equipped RV park, a bit far from the town, but "nice"! So, i bought some VERY GOOD Moselle-Riesling wine (called "Neefer Frauenberg" and "Bremmer Calmont") and took again the "wheel", to look for this place.
Name:	ImageUploadedByAirstream Forums1473358063.632990.jpg
crossing again the river!
It was absolutely a perfect idea! Wonderfull and cozy spot, AC hook up, dumpstation, rivervieuw and evening sun! (9,- only a night, all-in!) That's Airstreaming!!!!!
Name:	ImageUploadedByAirstream Forums1473358269.581718.jpg
Name:	ImageUploadedByAirstream Forums1473358380.740514.jpg
Geraniums in "Flamingo pink"! 👍🏻
Name:	ImageUploadedByAirstream Forums1473358457.475687.jpg
The neighbours (very kind dutch couple!!) far away, very spacious place! Mats could make an impressive Campfire, without bothering anybody!
Name:	ImageUploadedByAirstream Forums1473358659.306558.jpg
Icecold whiteine, Barbecue, Kids and "Bangles", we spent a great evening!
Name:	ImageUploadedByAirstream Forums1473358775.055202.jpg
ID:	271198Click image for larger version
Name:	ImageUploadedByAirstream Forums1473358904.686869.jpg
It was the last sunny day....! But we did not knew about!
Next morning, it was raining "Cats & Dogs"!
Name:	ImageUploadedByAirstream Forums1473359249.927830.jpg
Nobody wanted to bike in heavy rain, so we packed the bicicles and went only by "Bangles" to the next target Cochem.
Name:	ImageUploadedByAirstream Forums1473359443.473436.jpg
Old 09-08-2016, 12:34 PM   #165
Roquefort's Avatar
1975 29' Ambassador
By by sunny weather...!
Wanted to post more pictures, but went not thru...?! "Exxeded ...KB...?)
Old 09-08-2016, 06:24 PM   #166
2016 28' Pendleton
East central , Illinois
I have just finished reading your thread and thoroughly enjoyed it. My mom is from Germany (Wiesbaden) and I spent a summer outside Frankfurt (Bonigheim) with my school. We went to school in the morning and traveled in the afternoons. We were also in West Berlin for two weeks before the wall came down (1972). What an interesting town for a 16 year old!
Your castles and small towns bring back many memories. Now I would like to travel it once again but with a camper. Don't think I could afford to bring my airstream (Pendelton 28ft) and f250 pickup.
Keep posting and I will continue to view Europe once again thru your eyes! Love the wine references also.
Gina
GinaNBob is offline   Reply With Quote
Old 09-09-2016, 03:45 AM   #167
Roquefort's Avatar
1975 29' Ambassador
Hey Gina!
thank you very much for joining Peter's & our thread! It make's me allways a bit proud, once i see, HOW MANY followers we allready have!
If you wish to travel again thru Germany with an Airstream, you should better rent one here...! The rates to ship an Airstream from East coast to Germany are VERY HIGH , we just shipped Anja's new "toy", an 29' Ambassador, for about 3500,-$ 😬!!!! Also, you will need some significant remodel for AC etc to use the US trailer here.
To follow "our" trip with a RV is not very difficult, but keep in mind, i used to drive "big toys" into "narrow spots"! Any road here is far smaller than the highways in the US. Sometimes it was a challenge, even for me, to manouver "Bangles" cross these villages and "cozy spots"...! (Peter told me once, either i am foolish or genious, to do so 😀!
There are MANY RV's to rent here, mostly (ugly!) Class-C, some smLl "Class A), but we will find something "funny" for you! These are travelready, affordable in "side-seasons"!
If you ever plan to travel here, let me know, i could help you to find a nice tour, following your requests. (wine, castles, food, nature....?!)
Unfortunatelly, i am not allowed anymore to post pictures for now, my "free volume ecceded", i was 't aware of the fact, there is a limit....!
'am not sure, if i am willing to pay for, if i wan't to share "AIRSTREAM-fun" with my "Aluminium-friends"....! I still have a bunch of nice Airstream pics etc.
We'll see!
By for now, happpy Airstreaming!!!!!
Old 09-09-2016, 01:32 PM   #168
Roquefort's Avatar
1975 29' Ambassador
Name:	ImageUploadedByAirstream Forums1473449134.600381.jpg
Flamingo, trying to escape the "wet weather"....!
Name:	ImageUploadedByAirstream Forums1473449238.074871.jpg
The heavy rain was really a bad thing...!
We decided to make the best of it, cruising down the river to Cochem and visit the fabulous "Reichsburg" in Cochem!!!!
The wipers were in "full speed", we had a "silent trip", my "bikers" missed their "daily challenge"!
You will be REALLY pleased, once you see the pictures fron this "pure-german-tow "!
Be curious!!!!
Europe you can help me ....towing in europe puppybear Global 'streaming 2 12-04-2008 09:32 AM
The adventures of Brett and Edie III thenewkid64 Airstream Motorhome Forums 54 02-14-2005 04:25 PM
Adventures in Plumbing (with Pics) R&SZinser Fresh Water Systems 27 08-11-2004 05:07 AM
Adventures of Brett and Edie Part II thenewkid64 Airstream Motorhome Forums 28 12-01-2003 01:36 PM
Adventures of Brett and Edie Part I ViewRVs Argosy Motorhomes 69 07-08-2003 07:06 PM
