Old 03-13-2016, 11:46 AM   #113
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
All auto and truck tires have a DOT manufacter date code. Youll want to try and work with your tire supplier to try and find the "newest" tires that you can out of their stock. With motorhomes, you rarely wear out the the tread on a set of tires before they "age out". There is some arguement in regards to this but I believe the DOT recommends that motorhome tires be replaced at 7-8 yrs REGARDLESS of tread wear. Most folks dont put enough mileage on their tires to wear out the tread before they age out. Some folks swear by this recommendation of tire replacement and some folks will run their tires longer. Thats up to you to decide. The principle is based on the fact that the rubber in the tire deteriorates and becomes unsafe even though the tire may "look" just fine. I cant remember off hand how to read the date code but just Google "DOT tire date code" and youll find the answer. Many tires may sit on the shelf for quite some time, months or even years. If you were to purchase a set that had been sitting on the shelf for a year then essentially your "new" tires are already a year closer to needing replaced. So you want to find the newest tires you can off the shelf. Tires will be one of your biggest expenses off the bat so this is important. I also bought Hancook tires and they were 4 to 5 months old when I bought them. Best I could find at the time as far as age is concerned. Ive run them for 5000+ miles now and have had no problems at all. I had them bead balanced. To answer your original question....yes, that should be all the info they need. 8r 19.5, AH11 for Hancooks.
Mike
mayco is offline   Reply With Quote
Old 03-13-2016, 12:09 PM   #114
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
You can wrap it in 6 mil Plastic until you find out if it is working if it works get a cover for it.If it is a coleman I have a used cover that should fit I will check
shepherd57 is offline   Reply With Quote
Old 03-13-2016, 02:08 PM   #115
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Reading tire manufacturer codes.
While the DOT number appears on both sides of the tire, the four numbers that will give you the manufacturing date will appear on only one side of the tire in an embossed area at the end of the DOT number. As I posted before the first two numbers are the week, for example 35 for 35th week of the year, followed by the year, 15 for 2015.
http://www.tirerack.com/tires/tirete...jsp?techid=172
As far as the A/C unit is concerned, find out the make and getting a new cover should be easy, but as John stated, its at the end of your priority list.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-16-2016, 10:41 AM   #116
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Want to see a beautiful sight?
Name:	ImageUploadedByAirstream Forums1458146267.006611.jpg
My Airstream finally has beautiful new windshields! No more smashed glass. I'll finally be able to actually drive it!!
Name:	ImageUploadedByAirstream Forums1458146416.289877.jpg
Name:	ImageUploadedByAirstream Forums1458146428.974732.jpg
Name:	ImageUploadedByAirstream Forums1458146452.294967.jpg
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 03-16-2016, 10:47 AM   #117
Tap
Tap's Avatar
Tap's 1981 280 Motorhome (Purchased January 2016)
It sure wasn't cheap!
$2,300 for the windshields, rubber gasket, crating, and shipping.
And then an additional $650 to have it professionally installed.
Ouch!
But at least I can see out the windshields and rain can't get in.
Now on to spend a lot more money on a few side windows and a full set of new tires. 😬
Old 03-16-2016, 10:48 AM   #118
mayco's Avatar
Saweet
Old 03-16-2016, 10:51 AM   #119
Tap
Tap's Avatar
Here are the huge shipping boxes and the old, removed rubber gasket:
Name:	ImageUploadedByAirstream Forums1458147074.486849.jpg
Name:	ImageUploadedByAirstream Forums1458147090.556194.jpg
Old 03-16-2016, 10:54 AM   #120
Tap
Tap's Avatar
Name:	ImageUploadedByAirstream Forums1458147215.254146.jpg
Old 03-16-2016, 10:54 AM   #121
mayco's Avatar
So did you order directly from Coach Glass?
Old 03-16-2016, 10:55 AM   #122
Super!
How long did it take them to do the install once they got there?
Old 03-16-2016, 11:06 AM   #123
Tap
Tap's Avatar
No, I actually ordered them through Andy at Inland RV, but from the boxes, it looks like the must be supplied by Coach Glass.
Old 03-16-2016, 11:06 AM   #124
Tap
Tap's Avatar
Originally Posted by bkahler View Post
Super!
About an hour and a half.
They had a lot of old broken glass to vacuum up, hehe!
Old 03-16-2016, 11:13 AM   #125
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Fantastic!!!!
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-16-2016, 11:13 AM   #126
Wow, that's a lot faster than I expected for such large glass sections.
I'll be you're looking forward to the first drive!
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
