Old 01-25-2016, 12:29 PM   #43
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Guys, what is this, and what does it do? I obviously need a new one:
Name:	ImageUploadedByAirstream Forums1453750158.507225.jpg
ID:	256296Click image for larger version
Name:	ImageUploadedByAirstream Forums1453750174.527720.jpg
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 01-25-2016, 01:02 PM   #44
1986 34.5' Airstream 345
Alliance , Ohio
It looks like a home made windshield washer reservoir. Trace the hose and see where it leads.
mehes is offline   Reply With Quote
Old 01-25-2016, 01:18 PM   #45
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Its the OEM 12v charcoal starter, it was an option..........
mayco is offline   Reply With Quote
Old 01-25-2016, 02:13 PM   #46
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Attachment 256296Attachment 256297
Clearly it was a Flux Capacitor.
Tells us when you find windshields, how much and where available.
Ours are OK, just fear when need new ones.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 01-25-2016, 02:56 PM   #47
If the hose routes down to the radiator then it's a mister to aid in engine cooling.
Although as klattu suggest, flux capacitor would be more appropriate
Old 01-26-2016, 06:12 AM   #48
You guys... Lol.
Looks like the coolant overflow/expansion bottle to me! Mine was not that shape, but similarly disintegrated!
If it is a Flux Capacitor, I think it will take Tap forward to when he gets his Rivet Master status very quickly!
Old 01-26-2016, 06:28 AM   #49
1978 28' Argosy 28
That's an odd one. Expansion tank looks to be below in the 1st picture. The white canister. You can see the overflow line coming from the radiator neck that heads down there. Leads me to believe its a windshield wiper fluid reservoir. However, that is one SERIOUS orange hose up top to be used for washer fluid. And I have no idea why a PO would install double overflow tanks. Nothing there really makes sense.. Curious to see how this one ends up!
bpg_austin is offline   Reply With Quote
Old 01-26-2016, 06:44 AM   #50
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
More pictures ???
bobmiller1 is offline   Reply With Quote
Old 01-26-2016, 06:47 AM   #51
The windshield washer reservoir is shown just above and to the right of coolant reservoir. You can see the little pump on top of it.
I'm still betting on it being a radiator mister tank
Old 01-26-2016, 07:12 AM   #52
Tap
Tap's Avatar
Here are two other similar questions that may shed additional light.
Two other cracked tanks in front:
On the left (while facing it):
Name:	ImageUploadedByAirstream Forums1453817506.315522.jpg
And on the right (probably the windshield wiper fluid tank):
Name:	ImageUploadedByAirstream Forums1453817546.536421.jpg
Old 01-26-2016, 08:14 AM   #53
mayco's Avatar
Another oddity from the pictures, look at the long shaft that is protruding out of the blower motor on the left. Looks like the motor was replaced with one that was meant to have a double squirrel cage, one on either side of the motor.
Old 01-26-2016, 08:17 AM   #54
mayco's Avatar
The PO gots some 'splainin to do
Old 01-26-2016, 09:33 AM   #55
Henniker , New Hampshire
I am guessing that is some kind of water injection system and that the big hose coming off it leads to a vacuum connection on the carb or manifold. Purely a guess however!
The cracked tank nearest the center is the radiator overflow and the smaller one toward the drivers side is the windshield washer reservoir.
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 01-31-2016, 04:18 PM   #56
Tap
Tap's Avatar
Hi guys, I'm excited, I'm moving forward with replacement glass! In the past week I've been talking with Andy at Inland RV, he's great, and this week I'm ordering both replacement windshields and the rubber gasket from him.
I also already ordered the driverside window on eBay.
Getting the Aluminum Falcon sealed up with no more gaping holes is my number one priority, so as to keep out critters and moisture. Then I'll move on to getting it started, tested and tuned up. I did buy a replacement starter already, so I'm excited about that.
My how my life has changed, I never thought I'd be excited about a starter. Hehe!
I can't wait to have a clean, working, and moving machine!
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
