Old 01-24-2016, 06:06 PM   #29
Originally Posted by Smartstream View Post
You may want to check the roof air before moving. On mine bolts through the inside grill is all that holds the unit on. Without the inside grill mounted the rooftop unit is just sitting there and will slide right off.
Yep, that air conditioner is just sitting on the roof with nothing holding it in place. As soon as you hit a good headwind it will be gone.
I hate to say this but it's probably a good thing you didn't get the coach running as you could have had a mess on your hands.
By the way, welcome to Airforums!
Old 01-24-2016, 06:17 PM   #30
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Wow, good points guys! I had no idea! Thanks!
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 01-24-2016, 06:24 PM   #31
Tap
Tap's Avatar
Is this the thing the roof air conditioner bolts to? It's just laying on the bed:
Name:	ImageUploadedByAirstream Forums1453681427.693489.jpg
ID:	256266Click image for larger version
Name:	ImageUploadedByAirstream Forums1453681442.359921.jpg
Old 01-24-2016, 07:11 PM   #32
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Attachment 256266Attachment 256267
That does not hold the roof AC on, just a diverter for air flow.
The bolts that hold roof on/down are long and can only be seen after that is off.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 01-25-2016, 08:13 AM   #33
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Looks like $6,000 worth of broken glass- hard to replace glass-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-25-2016, 08:21 AM   #34
Tap
Tap's Avatar
Which is 3 times what I payed for the whole motorhome!
Old 01-25-2016, 08:28 AM   #35
To expand on what klattu said, there is a sheet metal plate that is placed against the ceiling that the long bolts pass through. The plate should have the controls mounted on it. It should look something like this:
Keep in mind when installing and tightening the long bolts they only get torqued to something like 5 foot lbs. My suggestion is find the plate and install it for the trip home and then once home you can verify the air conditioner works then buy a new roof gasket and install appropriately with the proper torque.
Old 01-25-2016, 08:36 AM   #36
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
its too bad about those windshields. MIght be tough to find them but in the meantime you have lots to work on. Knowing that this will be a labor of love you seem to have the right attitude.
When I got my Classic 280 in 2001, I had searched every limited web resource I could for one.
It took a flight from Atlanta to Dayton, Ohio and a crazy winter time drive home alone to bring it South.
I truly have enjoyed fixing up these old Airstreams through the years, and have my 4th now. Its an addiction that has only one cure, getting them usable and enjoyable and then doing just that.
Will look forward to your progress. You will have this forum as a great tool to access and plenty of willing assistance.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 01-25-2016, 08:46 AM   #37
If it runs and drives then you got a deal
Old 01-25-2016, 09:57 AM   #38
m.hony's Avatar
2013 30' Classic
That being said, it sure appears that it could hit the road with new windows.
TAC #MS-10
Airforums #70955
Old 01-25-2016, 10:24 AM   #39
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
You may want to reach out to Jerry Stritecky who lists as runamuck12 on eBay (he is currently parting out a 310. A few folks have got windows from him recently and I have just done a deal on the three rear windows (two panos and center) as spares for our Argosy.
The front screens are still available new (I got some last Summer) from Airstream, who get them from Coach Glass, and Airstream Supply company have the side cockpit windows (driver and passenger side), and all the other glass sliders (which come driver or passenger side, and in 30" or 24" height) (Airstream Classic Motorhome parts). They are advertising a 30% off sale until the end of the month for anything they have in stock.
Basically you are looking at $750 a screen then approx $900 per slider (about $450 for the fixed part and the same for the sliding part) from Airstream supply - front screen gasket is of the order of $300.
martin300662 is offline   Reply With Quote
Old 01-25-2016, 11:20 AM   #40
Tap
Tap's Avatar
Thanks so much for mentioning all of that martin. I've been actually looking at that exact 30% off sale. It's perfect timing for me and would make a big difference.
Old 01-25-2016, 11:25 AM   #41
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
There is one of these for sale in Wellston Michigan.
No broken glass.
I've seen it by the side of the road between Manistee and Cadillac.
Dingo Girl is offline   Reply With Quote
Old 01-25-2016, 01:17 PM   #42
Tap
Tap's Avatar
No broken glass.
Wish I were nearby it.
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 01:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 12:42 PM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 09:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 02:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 07:29 AM
